Tilting the display by a couple of degrees to make it straight
I have managed to install the display behind my mirror a bit tilted. It is off by a couple of degrees only, but it still shows.
Is there anyway to tilt the whole interface a couple of degrees?I have already searched quite a bit of the display of the raspberry pie can be tilted but it I have not found a solution, so I am really hoping that the MM interface can be tilted! The display is already glued so that is difficult to change now.
@alborzs it probably is possible, but it will look terrible, if not blurry it will create artifacts.
I think your best bet is do remount your display to be square. As @broberg said, if you can do it, it won’t look very good due to the nature of the line up of the pixels. Small text will probably be un-readable.
@alborzs
I rotated my screen from landscape to portrait using custom.css.
Cannot find the topic in this forum, but this is the body in my custom.css file:body { margin: 0; position: absolute; transform: rotate(-90deg); transform-origin: top left; width: 100vh; height: 100vw; object-fit: cover; top: 100vh; visibility: visible; }Perhaps you give it a try with different degrees in the rotate() parameter.
This reminds me of a joke.
Q: How many software engineers does it take to change a light bulb?
A: None. It’s a hardware problem.
Q: How many hardware engineers does it take to change a light bulb?
A: None. Just tell the software engineers to code around it. -
You know what, @evroom s solution might just work.
Tried it and it isn’t half bad, it gets blurry, but not overly so. (disclaimer, tried this on a 24" 1440p display)
body { transform: rotate(0.2deg); transform-origin: top left; } -
