    How to find and use key commands in MM. For absolute beginners.
    6 Posts 2 Posters 13.1k Views 4 Watching
      • Some very useful key commands that often go unnoticed in MM.
      It is common enough that a new user will successfully install and run MM,
      only to be left wondering how to stop the MM process. Y’all know who you are. :^)
      The Alt key! And sometimes the Control key
      There are so many different platforms and OS’s being used for MM, but in MOST cases
      the Alt key will drop a Menu Bar at the top of MM while it is running. From there
      you can execute a host of commands by clicking through the menus. Here I have
      provided the key commands that have been most useful to me. They don’t even require that
      you to press the Alt key. Simply execute the key command while MM is running.
      Simultaneously means at the same time ;^)
      • Minimize MM = Control and M
      • Reload MM = Control and R
      • Open Dev Tools = Control and Shift and I (That’s an i)
      • Default Display Size = Control and 0 (That’s a zero)
      • Zoom In = Control and Shift and = (That’s an equals sign)
      • Zoom Out = Control and - (That’s a dash/minus sign)
      • Toggle Full Screen = F11
      Other “Absolute Beginner” tutorials
      How to MANUALLY install MM on your Pi. For absolute beginners.
      https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
      How to create a working config. For absolute beginners.
      https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
      How to check your config for errors. For absolute beginners.
      https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
      How to add modules. For absolute beginners.
      https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
      How to post code on the forum. For absolute beginners.
      https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
      Install MagicMirror on a PC Windows 7/10 - Complete walkthrough
      https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7
      1 Reply Last reply Reply Quote 8
        @brandonbrown asked about toggling fullscreen today so I thought I would bring this topic to the attention of those that may not know about it. Someone will find it useful, hopefully.
          sdetweil @Mykle1
          @Mykle1 ctrl + will also zoom in steps, ctrl - reverses that
          Mykle1M 1 Reply Last reply Reply Quote -1
            @sdetweil said in How to find and use key commands in MM. For absolute beginners.:
            Yes, Ctrl and - zooms out. However, I believe it’s Ctrl Shift + to zoom in. I have that listed above as Control and Shift and =. ( = and +, same key)
              sdetweil @Mykle1
              @Mykle1 never had to push shift too
                That is odd. My Pi mirror, running MM 2.1.0, requires the Shift key to Zoom In, but not out, as does my dev machine running MM 2.5.0 and Ubuntu 16.04 LTS. I just tested both. Go figure.
