    MacMirror
    15 Posts 4 Posters 14.7k Views 5 Watching
      Johans @Mykle1
      @Mykle1 - fantastic job man!!!
      I like it
      • T Offline
        trividar
        Hi @Mykle1, what an amazing and fantastic work! I’ll try to rebuild it on my Mac Mini.
        One question I have already now, is there a way to disable te Monitor/HDMI output/SleepMode with voice on Mac with ubuntu?
          Mykle1 Project Sponsor Module Developer @trividar
          @trividar said in MacMirror:
          I think mmm-voice has that ability by default. However, using mmm-voice with the Hello Lucy enhancement you can simply issue the voice commands “Go To Sleep” to put your monitor in standby/sleep and “Please Wake Up” to turn it back on.
          There are other voice modules that may do the same thing.
          • T Offline
            trividar @Mykle1
            @Mykle1 What do you think, would it also work on Mac OS x or do I have to install ubuntu on the Mac mini? THX !!
            Mykle1M S 2 Replies Last reply Reply Quote 0
              @trividar
              I don’t really know as the MacMirror is the only Mac I’ve dealt with. There are Mac users here. Perhaps they will chime in and provide you with an answer.
                sdetweil @trividar
                @trividar mmm-voice/hello Lucy use pocketsphinx for voice reco. It is supported on osx and Ubuntu.
                And those modules support ‘go to sleep’. Which can launch a command to turn off hdmi, or whatever.
                My MMM-SleepWake does motion detection via camera and can do the wakeup when they do sleep
                T 1 Reply Last reply Reply Quote 2
                • T Offline
                  trividar @sdetweil
                  @sdetweil woow amazing! Thank you very much for this info! I will try to build my MM V2 with Mac mini, mmm-voice/hello Lucy & MMM-SleepWake and my standard modules, which I already have with my first Raspi build! Maybe I will write a step-by-step guide if I succeed.
                  • T Offline
                    trividar @Mykle1
                    @Mykle1 Hi, I got it to work on my Mac mini… wooow it’s fantastic!!! Just a question/problem, it will not recognize “go to sleep”, it will recognize “go sleep”, sleep, sleep, go… but never “go to sleep”. Is there a way to change the command “go sleep” or just “sleep”, thank you!
                      @trividar
                      The reason I made the command “GO TO SLEEP” is that I had the best results with that phrase. You can see in some of my videos that feature that command that it does work for me. Some people that with accents have had trouble with mmm-voice/Hello-Lucy due to this. A close friend of mine that lives in Norway has trouble with Lucy due to his accent.
                      Please try this:
                      Try saying the command as one word, GoToSleep instead of 3 separate words
                      • T Offline
                        trividar @Mykle1
                        @Mykle1 Thanks, but unfortunately it also doesn’t work if I say it as a word ;o( It’s difficult to change this formulation? I would try what works best for me.
                          @trividar
                          Not terribly hard to change the command. Feel free to make any changes that work best for you. However, I won’t be making any changes to the repo at this time.
                            @trividar
                            I don’t know if you’ve seen this video but it clearly shows the ‘GO TO SLEEP’ command working.
                            https://www.youtube.com/watch?v=Zsm_hi7XvM4
                            • T Offline
                              trividar @Mykle1
                              @Mykle1 Hello, I tried to play your Youtube video, the funny thing is, every command is perfectly recognized by your voice ;o) just “go to sleep” not! But I’ve managed to realize a few times “go to sleep”, but nothing happens on my Macmirror, so I have to find out what I did wrong (or try mmm-sleepwake module with motion project and my camera)!
                              But apart from this, your module extension is amazing! I love it! Thank you for your work!
                                @trividar
                                Well, unless you’ve changed something it should work. Yes, @sdetweil’s sleepwake module is excellent.
                                Are you using this config option?
