Electron Browser outdated?
@rudibarani cool. can u post the node and npm versions? thanks
@sdetweil: I only updated electron without changing npm and node - so I am still using Node v11.6.0 and npm 6.9.0 on my Mac Mini (24/7 since 2009 :slightly_smiling_face:)
@rudibarani just wanting to know what the levels were. Thank you
@rudibarani how can I update electron?
@rudibarani I have a Mac mini
@Stoffbeuteluwe go into the MagicMirror home folder and execute
npm install electron@latest -
Testing now electron@6.0.10 on a
Raspberry Pi 4 with
npm@6.10.2 and
node@10.15.2Will report back as soon as I have something
@lavolp3 thanks
@lavolp3 works fine on Mac
This post is deleted! -
I have submitted change to upgrade to version 6.0.12 on next update
@lavolp3 said in Electron Browser outdated?:
Hi all,
i have updated the electron like above written (because i had the same issue)
After update nothing worksError code
pi@raspberrypi:~/MagicMirror $ npm start dev > magicmirror@2.9.0 start /home/pi/MagicMirror > sh run-start.sh "dev" /home/pi/MagicMirror/node_modules/electron/index.js:14 throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again') ^ Error: Electron failed to install correctly, please delete node_modules/electron and try installing again at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/index.js:18:18) at Module._compile (internal/modules/cjs/loader.js:778:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10) at Module.load (internal/modules/cjs/loader.js:653:32) at tryModuleLoad (internal/modules/cjs/loader.js:593:12) at Function.Module._load (internal/modules/cjs/loader.js:585:3) at Module.require (internal/modules/cjs/loader.js:692:17) at require (internal/modules/cjs/helpers.js:25:18) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16) npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! magicmirror@2.9.0 start: `sh run-start.sh "dev"` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.9.0 start script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2019-11-22T22_16_40_595Z-debug.logCan please somebody help me
Thanks a lot
Regards -
yes, lets try something not so new…
do
cd ~/MagicMirror rm -rf node_modules/electron npm install electron@6.0.12note that for other modules, you may also have to run electron-rebuild
Sorry about reviving an old thread but I thought you and others might want to know
Bro, I went ahead and installed
npm install electron@latest(11.3.0) as an experiment. Both my MMM-ISS-Live and EARTH-Live modules were affected by electron. It appears the latest version of electron has fixed the problem, at least with these two modules -
@mykle1 the current mm develop branch has a number of changes, including moving up to electron 11.2.1
i would suggest trying that too…
there is already a pull request which includes the update to 11.3.0, should be merged within the next days into
develop
