    MMM-Ring: Displays a video stream of your Ring doorbell when someone rings your doorbell.
    38 Posts 9 Posters 19.7k Views 12 Watching
      sithlordhood
      Hi I cant get the module to work - it comes up with the following error in the logs, can you advise?
      MMM-Ring at (06/10/2019, 22:22:19): Found 1 location(s) with 1 camera(s).
      MMM-Ring at (06/10/2019, 22:22:19): Location Home has the following 1 camera(s):
      MMM-Ring at (06/10/2019, 22:22:19): - 7076807: Front Door (doorbell_v3)
      MMM-Ring at (06/10/2019, 22:22:19): Location Home has the following 0 device(s):
      MMM-Ring at (06/10/2019, 22:22:19): Actively listening for doorbell presses
      MMM-Ring at (06/10/2019, 22:22:45): Front Door had its doorbell rung! Preparing video stream.
      { Error: spawn ffmpeg ENOENT
          at Process.ChildProcess._handle.onexit (internal/child_process.js:229:19)
          at onErrorNT (internal/child_process.js:406:16)
          at process._tickCallback (internal/process/next_tick.js:63:19)
        errno: 'ENOENT',
        code: 'ENOENT',
        syscall: 'spawn ffmpeg',
        path: 'ffmpeg',
        spawnargs:
         [ '-hide_banner',
           '-protocol_whitelist',
           'pipe,udp,rtp,file,crypto',
           '-f',
           'sdp',
           '-i',
           'pipe:',
           '-acodec',
           'aac',
           '-vcodec',
           'copy',
           '-preset',
           'veryfast',
           '-g',
           '25',
           '-sc_threshold',
           '0',
           '-f',
           'hls',
           '-hls_time',
           '2',
           '-hls_list_size',
           '6',
           '-hls_flags',
           'delete_segments',
           '/home/pi/MagicMirror/modules/MMM-Ring/public/stream.m3u8' ] }
        DustinBryant
        You’ll need to install ffmpeg. I’m assuming you’re using a pi with Raspbian. If so, you can run the following in the terminal:
        sudo apt-get install ffmpeg
        If not, you’ll need to find how to install ffmpeg with whatever OS you’re running.
          dwntwn87
          I’m running MM via Docker on a NAS and can’t seem to figure out how to get Docker to use ffmpeg from the OS. Does anyone have any ideas on how to do this?
            sithlordhood @DustinBryant
            @DustinBryant Thanks, i have installed but still not working. I get the files in the public folder but still no video
              DustinBryant
              Interesting, are any errors printed in the terminal and if none there, are there any errors in the Electron debugger log after running?
                @DustinBryant This is what the mm log shows:
                MMM-Ring at (10/10/2019, 20:59:55): Found 1 location(s) with 1 camera(s).
                MMM-Ring at (10/10/2019, 20:59:55): Location Home has the following 1 camera(s):
                MMM-Ring at (10/10/2019, 20:59:55): - 7076807: Front Door (doorbell_v3)
                MMM-Ring at (10/10/2019, 20:59:55): Location Home has the following 0 device(s):
                MMM-Ring at (10/10/2019, 20:59:55): Actively listening for doorbell presses
                Then i press the doorbell:
                MMM-Ring at (10/10/2019, 21:00:04): Front Door had its doorbell rung! Preparing video stream.
                MMM-Ring at (10/10/2019, 21:00:26): Front Door video stream has ended
                Whoops! There was an uncaught exception…
                TypeError: Cannot read property ‘stop’ of null
                at Timeout.setTimeout [as _onTimeout] (/home/pi/MagicMirror/modules/MMM-Ring/node_helper.js:153:36)
                at ontimeout (timers.js:427:11)
                at tryOnTimeout (timers.js:289:5)
                at listOnTimeout (timers.js:252:5)
                at Timer.processTimers (timers.js:212:10)
                No video is displayed on the MagicMirror.
                Also I have specificed a 2 minute stream time in the config.js but as shown above, the video only shows it runs for 30 seconds…
                config.js:
                                    module: "MMM-Ring",
                                            ringEmail: "EMAIL",
                                            ringPwd: "PASSWORD",
                                            ringMinutesToStreamVideo: "2", //default is 2 mins
                                            ringVideoWidth: "600" //default is 600px
                  DustinBryant
                  Ok, so I 've fixed the error you’ve run into. The reason the stream could have stopped is because someone on the account looked at the ring event on the ring app and then stopped/closed it. Unfortunately, it’s basically a “shared” stream in that if applications are looking at the event at the same time one ended could potentially end the other viewing it prematurely. I’ve only had this happen once and that seemed to be what that was.
                  I made some other small changes which may help here as well. I’d like for you to update all your software first though just to rule that out as well.
                  Before doing any of the following I would recommend backing up.
                  1. Update your pi OS to the latest version
                    sudo apt-get update
                    sudo apt-get upgrade
                    sudo reboot
                  2. Update MagicMirror to its latest version by using a Terminal to navigate to your MagicMirror folder and running
                    git pull && npm install
                  3. Navigate to the module/MMM-Ring folder and run
                  This will update everything, hopefully. Now try running MagicMirror again, giving it a couple seconds to a minute, and then ring your doorbell again.
                  Hope this helps!
                  S S 2 Replies Last reply Reply Quote 0
                    sdetweil @DustinBryant
                    @sithlordhood you should use my update script… takes care of a bunch of problems
                    see here for instructions
                    https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                      @DustinBryant Thanks for all of the suggestions, I have followed this and now do not get any errors but i see no video on the mirror!
                      Anything else i can check?
                        DustinBryant @sithlordhood
                        @sithlordhood this one is a bit tough because I can’t recreate the issue you are having.
                        We can look at if the video is actually showing anything at all to determine if this is a sip session/ffmpeg issue or an issue on hls hooking into the video control and playing the stream. Try this:
                        1. Run MagicMirror
                        2. Minimize it
                        3. Using file explorer navigate to the MagicMirror/modules/MMM-RING/public/
                        4. Go ring your doorbell
                        5. Once a .ts file gets dropped into the public location open/play it. Maybe check a couple as well.
                        Is there video of your doorbell camera when you play those?
                        BTW, they will all be like 2 second long videos each. The stream (m3u8) is what ties them into a continuous video by playing them serialized.
                        • 1 / 4
