    (2.1.0, API) Revising the Show/Hide mechanism
    Scheduled Pinned Locked Moved Upcoming Features
    14 Posts 5 Posters 15.4k Views 4 Watching
    • MichMichM Offline
      MichMich
      Yeah, but I think that is the exact reason why this method should be implemented. One can argue what the desired result is. But by implementing the force option, both scenarios will be possible. Implementing a force function isn’t really a big deal.
      Thanks for your input!
      • I Offline
        ianperrin
        Agreed.
        And perhaps best practice should be that any module wishing to show/hide other modules should include a config option to toggle the use of the force flag.
        Let the user decide!
        "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
        • MichMichM Offline
          MichMich
          Agee! I’ll make sure to add that to the documentation.
          • MichMichM Offline
            MichMich
            Method is implemented. See documentation:
            https://github.com/MichMich/MagicMirror/tree/develop/modules#thishidespeed-callback-options
            https://github.com/MichMich/MagicMirror/tree/develop/modules#thisshowspeed-callback-options
            https://github.com/MichMich/MagicMirror/tree/develop/modules#visibility-locking
            J 1 Reply Last reply Reply Quote 4
              Jopyth Moderator @MichMich
              @MichMich Did you have any concerns about making this an opt-out instead of an opt-in? I.e. make the default options {this.identifier} instead of {}. Or is there a specific reason against it? The overall concept seems reasonable, if we assume the meaning of the hide() method always was to “keep this module hidden until I want it to reappear”.
              I do not think anyone does something like hiding module A from module B and then purposely showing module A again from module C. This is the only way I think of, which would make the default option using the modules identifier weird.
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @Jopyth
                @Jopyth one way would be hide a module with the scheduler and show it again with the remote control or voice or something else
                • MichMichM Offline
                  MichMich
                  @Jopyth: The problem is that there is no way to find out which module requested the hide method. Therefor I can’t use that identifier by default. This must be provided by the module itself.
                    Jopyth Moderator
                    Oh, I see. My this.identifier would have been the identifier of the module to be hidden.
                    MichMichM 1 Reply Last reply Reply Quote 0
                    • MichMichM Offline
                      MichMich @Jopyth
                      @Jopyth exactly. Wich wouldn’t make much sense.
