    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 155.6k Views 25 Watching
      samydp
      I have the folder node_modules in MMM-Pir folder .
      should I delete the folder?
        Bangee Module Developer
        Can you post a printscrenn from this folder?
        you can also try to go use these commands:
        cd ~/MagicMirror/modules/MMM-PIR-Sensor/
        git pull
        npm rebuild
          samydp
            That looks fine.
            Did you try to remove your folder MMM-PIR-Sensor an reinstall the modul?
              samydp
              yes but i dont have the folder node_modules in the PIR Folder :/ i have install WrinPi but nothing works :/
                ok so lets go step by step:
                now we will remove the PIR folder:
                rm -rf MMM-PIR-Sensor
                and from here, we’re going to reinstall the MMM-PIR-Sensor modul:
                git clone https://github.com/paviro/MMM-PIR-Sensor.git
                cd MMM-PIR-Sensor
                run the following cmd here:
                npm install and wait, this can take a few minutes.
                Now you’ll have to add pi to gpio
                sudo useradd -g pi gpio
                and reboot your Raspi:
                sudo reboot
                You’ll have to connect your PIR Sensor the right way with your Raspi.
                I’ve connected my PIR Sensor on the following Pins:
                GPIO
                I’ve got a Pi2 and use Pin 2 for power, Pin 6 for Ground and Pin 15 for Data.
                – correctin grn pin
                PIR Sensor
                and dont forget to add the config :-)
                D 1 Reply Last reply
                Reply Quote 3
                  samydp
                  you are the best !! i dont become no a with screen !
                  but the sensor dont work
                  i have
                  vcc: Pin 2
                  Data: Pin 7
                  Ground: Pin 6
                  and my config in the config and MMM-PIR-Sensor data is:
                          		module: 'MMM-PIR-Sensor',
                  			sensorPIN: 7,
                  			relayPIN: false,
                  			powerSaving: true,
                  			relayOnState: 1,
                  the sensetiv is max and the time is min
                    If you use pin 7 in your config its nr 4
                    You have to use the gpio nr.
                    P 1 Reply Last reply
                      samydp
                      Thank you it works fine !!
                        phantomlight @Bangee
                        @Bangee I tried everything regarding the white screen issues. I’m a noob. was able to get magic mirror installed, I also installed the PIR motion detection and can confirm motion is detected.
                        Downgraded Node JS
                        Installed the electron
                        made sure module was added in config.js
                        I am using the Raspberry PI 3 mode b.
                        Can somebody confirm this module is working with Raspberry Pi 3.
                        Any help would be greatly appreciative…
                        Thanks.
                          can you restart the magicmirror an check what errormessage you have:
                          pm2 logs mm
                          P B 2 Replies Last reply
                            @Bangee Thank you so much for responding. I removed magic mirror completely reinstalled… then installed the module.
                            All is well now… Thank you so much!
                              bibi @Bangee
                              @Bangee hi ! thx for your nice tuto, i have proceed with it but i got a warning as below:
                              pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
                              npm WARN prefer global npm@3.10.9 should be installed with –g
                              do i have to do smt specific or it’s just ok to leave it without any action?
                              ps: my config file is also not working with PIR module implemented… maybe that is the reason? thx you very much for any feedabck guys!!
                                @bibi did you try it with the instructions from paviro:
                                I don’t think that this warn is your problem. I have so many times these warnings :-D
                                You sould send us whats in your pm2 logs mm
                                  bibi @Bangee
                                  @Bangee yes i follow his and yours… quite the same… regarding this npm warning I do nothing then as understood?
                                  I will send you the log later when I’m home
                                  Thx bangee! Appreciated!
                                    bibi @Bangee
                                    @Bangee so as expected the pm2 log mm just show that the file has syntax error… here is my config file, i put the module at the end…
                                    thx again :)
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @bibi
                                      @bibi powerSaving: true
                                      B 1 Reply Last reply
                                        bibi @strawberry 3.141
                                        @strawberry-3.141 right was a typo but still the config file is “not created” :((
                                        • strawberry 3.141S
                                          @bibi can you post your whole config file?
                                            @strawberry-3.141 here you go and many thx in advance - i struggling with this now (sorry i don’t know why only few parts of the code is with the color background)
                                            /* Magic Mirror Config Sample
                                             * MIT Licensed.
                                            var config = {
                                                    port: 8080,
                                                    language: 'en',
                                                    timeFormat: 24,
                                                    units: 'metric',
        module: 'alert',
        module: 'clock',
        position: 'top_left'
        module: 'calendar',
        header: 'US Holidays',
        position: 'top_left',
        symbol: 'calendar-check-o ',
        module: 'compliments',
        position: 'lower_third'
        module: 'currentweather',
        header: 'xxx',
        position: 'top_right',
        locationID: 'xxx',  //ID from http://www.openweathermap.org
        appid: 'xxx'
        module: 'newsfeed',
        position: 'bottom_bar',
        feeds: [
        title: "New York Times",
        showSourceTitle: true,
        showPublishDate: true
        sensorPIN: 22,
        powerSaving: true
                                            • 3 / 5
