    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 153.4k Views 25 Watching
      samydp
      hello is not working!
      i have downgrade the node.js version from v6 to 5v and i dont now why i become a white screen.
      my pm2 logs
      [TAILING] Tailing last 10 lines for [all] processes (change the value with --lin        es option)
      /home/pi/.pm2/pm2.log last 10 lines:
      PM2        | 2016-09-21 20:18:32: Starting execution sequence in -fork mode- for        app name:mm id:0
      PM2        | 2016-09-21 20:18:32: App name:mm id:0 online
      PM2        | 2016-09-21 20:21:28: Stopping app:mm id:0
      PM2        | 2016-09-21 20:21:28: App [mm] with id [0] and pid [1071], exited wi        th code [0] via signal [SIGINT]
      PM2        | 2016-09-21 20:21:28: Starting execution sequence in -fork mode- for        app name:mm id:0
      PM2        | 2016-09-21 20:21:28: App name:mm id:0 online
      PM2        | 2016-09-21 20:24:05: Stopping app:mm id:0
      PM2        | 2016-09-21 20:24:06: App [mm] with id [0] and pid [1250], exited wi        th code [0] via signal [SIGINT]
      PM2        | 2016-09-21 20:24:06: Starting execution sequence in -fork mode- for        app name:mm id:0
      PM2        | 2016-09-21 20:24:06: App name:mm id:0 online
      /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
      0|mm       | No helper found for module: alert.
      0|mm       | No helper found for module: clock.
      0|mm       | Initializing new module helper ...
      0|mm       | No helper found for module: compliments.
      0|mm       | No helper found for module: currentweather.
      0|mm       | No helper found for module: weatherforecast.
      0|mm       | Whoops! There was an uncaught exception...
      0|mm       | MagicMirror will not quit, but it might be a good idea to check why        this happened. Maybe no internet connection?
      0|mm       | If you think this really is an issue, please open an issue on GitHu        b: https://github.com/MichMich/MagicMirror/issues
      0|mm       | Launching application.
      /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
      0|mm       |     at Error (native)
      0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_AS        AR.js:168:20)
      0|mm       |     at Object.Module._extensions..node (module.js:583:18)
      0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR        .js:168:20)
      0|mm       |     at Module.load (module.js:473:32)
      0|mm       |     at tryModuleLoad (module.js:432:12)
      0|mm       |     at Function.Module._load (module.js:424:3)
      0|mm       |     at Module.require (module.js:483:17)
      0|mm       |     at require (internal/module.js:20:19)
      0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_m        odules/bindings/bindings.js:76:44)
        Bangee Module Developer
        @samydp did you maybe reneamed this folder:
        modules/MMM-PIR-Sensor/node_m odules <- is there a space in this name??
        you’ll have to remove this
          samydp
          I have the folder node_modules in MMM-Pir folder .
          should I delete the folder?
            Can you post a printscrenn from this folder?
            you can also try to go use these commands:
            cd ~/MagicMirror/modules/MMM-PIR-Sensor/
            git pull
            npm rebuild
              samydp
                That looks fine.
                Did you try to remove your folder MMM-PIR-Sensor an reinstall the modul?
                  samydp
                  yes but i dont have the folder node_modules in the PIR Folder :/ i have install WrinPi but nothing works :/
                    ok so lets go step by step:
                    now we will remove the PIR folder:
                    rm -rf MMM-PIR-Sensor
                    and from here, we’re going to reinstall the MMM-PIR-Sensor modul:
                    git clone https://github.com/paviro/MMM-PIR-Sensor.git
                    cd MMM-PIR-Sensor
                    run the following cmd here:
                    npm install and wait, this can take a few minutes.
                    Now you’ll have to add pi to gpio
                    sudo useradd -g pi gpio
                    and reboot your Raspi:
                    sudo reboot
                    You’ll have to connect your PIR Sensor the right way with your Raspi.
                    I’ve connected my PIR Sensor on the following Pins:
                    GPIO
                    I’ve got a Pi2 and use Pin 2 for power, Pin 6 for Ground and Pin 15 for Data.
                    – correctin grn pin
                    PIR Sensor
                    and dont forget to add the config :-)
                    D 1 Reply Last reply Reply Quote 3
                      samydp
                      you are the best !! i dont become no a with screen !
                      but the sensor dont work
                      i have
                      vcc: Pin 2
                      Data: Pin 7
                      Ground: Pin 6
                      and my config in the config and MMM-PIR-Sensor data is:
                              		module: 'MMM-PIR-Sensor',
                      			sensorPIN: 7,
                      			relayPIN: false,
                      			powerSaving: true,
                      			relayOnState: 1,
                      the sensetiv is max and the time is min
                        If you use pin 7 in your config its nr 4
                        You have to use the gpio nr.
                          samydp
                          Thank you it works fine !!
                            phantomlight @Bangee
                            @Bangee I tried everything regarding the white screen issues. I’m a noob. was able to get magic mirror installed, I also installed the PIR motion detection and can confirm motion is detected.
                            Downgraded Node JS
                            Installed the electron
                            made sure module was added in config.js
                            I am using the Raspberry PI 3 mode b.
                            Can somebody confirm this module is working with Raspberry Pi 3.
                            Any help would be greatly appreciative…
                            Thanks.
                              can you restart the magicmirror an check what errormessage you have:
                              pm2 logs mm
                              P B 2 Replies Last reply Reply Quote 0
                                @Bangee Thank you so much for responding. I removed magic mirror completely reinstalled… then installed the module.
                                All is well now… Thank you so much!
                                  bibi @Bangee
                                  @Bangee hi ! thx for your nice tuto, i have proceed with it but i got a warning as below:
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
                                  npm WARN prefer global npm@3.10.9 should be installed with –g
                                  do i have to do smt specific or it’s just ok to leave it without any action?
                                  ps: my config file is also not working with PIR module implemented… maybe that is the reason? thx you very much for any feedabck guys!!
                                    @bibi did you try it with the instructions from paviro:
                                    I don’t think that this warn is your problem. I have so many times these warnings :-D
                                    You sould send us whats in your pm2 logs mm
                                      bibi @Bangee
                                      @Bangee yes i follow his and yours… quite the same… regarding this npm warning I do nothing then as understood?
                                      I will send you the log later when I’m home
                                      Thx bangee! Appreciated!
                                        bibi @Bangee
                                        @Bangee so as expected the pm2 log mm just show that the file has syntax error… here is my config file, i put the module at the end…
                                        thx again :)
                                        • strawberry 3.141S Offline
                                          strawberry 3.141 Project Sponsor Module Developer @bibi
                                          @bibi powerSaving: true
                                            bibi @strawberry 3.141
                                            @strawberry-3.141 right was a typo but still the config file is “not created” :((
                                            • 3 / 5
