    MMM-SunRiseSet
    Scheduled Pinned Locked Moved Education
    51 Posts 10 Posters 39.1k Views 10 Watching
    • justjim1220J
      justjim1220 Module Developer @Mykle1
      @mykle1 yep!
      Jim Hallock - 1995
      • Mykle1M
        0_1549154963174_Screenshot from 2019-02-02 18-34-15.png -
        • cowboysdudeC
          Looks really good and I really like it! So I can use either if I’d like? I like the earth as it’s on a black background and it would look cool sitting on my 32" Mirror ;)
          Mykle1M 1 Reply Last reply
          • Mykle1M
            @cowboysdude
            Yes, you can use either image. They both update to show the movement of the sun on the earth.
            justjim1220J 1 Reply Last reply
            • justjim1220J
              @mykle1 have you ever tried setting the movement to 500ms?
              its kinda cool, if your device can handle it!
              I actually tried it with the Earth module…
              Jim Hallock - 1995
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @justjim1220
                @justjim1220
                Yes, I have. I used to run it at 1000ms. It’s pretty bad ass if your graphics can handle it
                • justjim1220J
                  @mykle1 when I did it, it was a mistake! But the outcome was cool!
                  It actually froze my dev machine after about 45 minutes!
                  Jim Hallock - 1995
                  • Mykle1M
                    @justjim1220
                    Jimbo is back! :-)
                      mrdenmark
                      i can’t to seem to get some images to show, i just get surise/sunset and time of day,if i select static i get the diagram but nothing with world or map
                      	disabled: false,
                      	module: "MMM-SunRiseSet",
                      		lat: "-44.57",      // Your latitude (for the data)
                      		lng: "168.50",     // Your longitude (for the data)
                      		image: "world",          // "world" (animation), "map" (animation), "static" (graph)
                      		imageOnly: "no",       // no = all data, yes = only animated world or map
                      		dayOrNight: "day",   // "night" approaching, "day" approaching (imageOnly: must be "yes", image: must be "world")
                      		useHeader: false,      // true if you want a header
                      		header: "Header",      // useHeader must be true
                      		maxWidth: "515px",
                      • V
                        Vauxdvihl
                        @Mykle1
                        Me too
                        I have the same issue
                        No images are shown
                        Can you please help
                        Thanks a lot
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @mrdenmark
                          @Vauxdvihl
                          @mrdenmark said in MMM-SunRiseSet:
                          My apologies.
                          The API in use for this module, http://api.usno.navy.mil, is down for maintenance. They have set a date of April, 2020 for completion. This also affects MMM-Lunartic but at least I was able to fashion a fix for that one. Not so in this case.
                          F V 2 Replies Last reply
                          • F
                            ForeverBrewing @Mykle1
                            @Mykle1 So any way of getting rid of the images completely? I’ve tried updating the custom CSS as you have suggested on the issue raised on GitHub but I don’t know how to format it correctly for it to take effect. Thanks in advance!
                            F 1 Reply Last reply
                            • F
                              ForeverBrewing @ForeverBrewing
                              @ForeverBrewing Ignore this; I have worked it out. The code that you previously prided needs to be placed OUTSIDE of the “body {}”
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @ForeverBrewing
                                @ForeverBrewing said in MMM-SunRiseSet:
                                It sure does. :thumbsup:
                                • V
                                  Vauxdvihl @Mykle1
                                  @Mykle1
                                  Thanks for your feedback
                                  ok
                                  we need to wait…it is a great module for the kids
                                  Thanks a lot
                                  • Mykle1M
                                    For those that be using MMM-SunRiseSet, please forgive the outage of the API. You can still use the module, albeit without the animated images. You can still use the module without the image by adding this to your custom.css file. This will remove the broken link from appearing.
                                    .MMM-SunRiseSet .img {
                                      display: none;
                                    Example along with MMM-EyeCandy. Animation is seamless loop in the module
                                    • cowboysdudeC
                                      What is that a brain sucker starving to death? LOL
                                      • Mykle1M
                                        @cowboysdude
                                        Yessir. :-)
                                        • Mykle1M
                                          Unfortunately, the api for this module is down for at least a few more months along with MMM-Lunartic. MMM-Lunartic continues to work with a temporary workaround.
                                          • uros76U
                                            uros76
                                            Hi. Is there a way to show 24hr format of sunrise and sunset times?
                                            By the way, it still works great without images.
