    MMM-SunRiseSet
    Scheduled Pinned Locked Moved Education
    51 Posts 10 Posters 38.8k Views 10 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Vauxdvihl
      @Vauxdvihl said in MMM-SunRiseSet:
      May be you can add some pinhead showing lat / lng.
      And maybe there could be some possibilit of zooming.
      I really don’t have any plans to do anything more with MMM-SunRiseSet. Please feel free to try anything you like with it. I’ll honor any PR’s that you send to the repo. :-)
      You can make the image larger or smaller via config and css. Zooming is quite another matter. Be aware that the images are renderings, not actual satellite imagery.
      Peace
      • Mykle1M
        Update
        I am happy to report that the certificate issue with the US Naval Observatory API has been corrected. I don’t know if I had anything to do with the fix but I did keep emailing them and the electron team about updating the certificate stores.
        MMM-SunRiseSet is now working as intended.
        I’m very happy now.
        justjim1220J 1 Reply Last reply
        • justjim1220J
          justjim1220 Module Developer @Mykle1
          @mykle1
          when you asked for others to email them, I did about 5 or 6 times. :winking_face:
          Jim Hallock - 1995
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @justjim1220
            @justjim1220 said in MMM-SunRiseSet:
            I thank you very much for that. :thumbsup:
            • justjim1220J
              @mykle1 yep!
              Jim Hallock - 1995
              • Mykle1M
                0_1549154963174_Screenshot from 2019-02-02 18-34-15.png -
                • cowboysdudeC
                  Looks really good and I really like it! So I can use either if I’d like? I like the earth as it’s on a black background and it would look cool sitting on my 32" Mirror ;)
                  • Mykle1M
                    @cowboysdude
                    Yes, you can use either image. They both update to show the movement of the sun on the earth.
                    • justjim1220J
                      @mykle1 have you ever tried setting the movement to 500ms?
                      its kinda cool, if your device can handle it!
                      I actually tried it with the Earth module…
                      Jim Hallock - 1995
                      • Mykle1M
                        @justjim1220
                        Yes, I have. I used to run it at 1000ms. It’s pretty bad ass if your graphics can handle it
                        • justjim1220J
                          @mykle1 when I did it, it was a mistake! But the outcome was cool!
                          It actually froze my dev machine after about 45 minutes!
                          Jim Hallock - 1995
                          • Mykle1M
                            @justjim1220
                            Jimbo is back! :-)
                              mrdenmark
                              i can’t to seem to get some images to show, i just get surise/sunset and time of day,if i select static i get the diagram but nothing with world or map
                              	disabled: false,
                              	module: "MMM-SunRiseSet",
                              		lat: "-44.57",      // Your latitude (for the data)
                              		lng: "168.50",     // Your longitude (for the data)
                              		image: "world",          // "world" (animation), "map" (animation), "static" (graph)
                              		imageOnly: "no",       // no = all data, yes = only animated world or map
                              		dayOrNight: "day",   // "night" approaching, "day" approaching (imageOnly: must be "yes", image: must be "world")
                              		useHeader: false,      // true if you want a header
                              		header: "Header",      // useHeader must be true
                              		maxWidth: "515px",
                              • V
                                Vauxdvihl
                                @Mykle1
                                Me too
                                I have the same issue
                                No images are shown
                                Can you please help
                                Thanks a lot
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @mrdenmark
                                  @Vauxdvihl
                                  @mrdenmark said in MMM-SunRiseSet:
                                  My apologies.
                                  The API in use for this module, http://api.usno.navy.mil, is down for maintenance. They have set a date of April, 2020 for completion. This also affects MMM-Lunartic but at least I was able to fashion a fix for that one. Not so in this case.
                                  F V 2 Replies Last reply
                                  • F
                                    ForeverBrewing @Mykle1
                                    @Mykle1 So any way of getting rid of the images completely? I’ve tried updating the custom CSS as you have suggested on the issue raised on GitHub but I don’t know how to format it correctly for it to take effect. Thanks in advance!
                                    F 1 Reply Last reply
                                    • F
                                      ForeverBrewing @ForeverBrewing
                                      @ForeverBrewing Ignore this; I have worked it out. The code that you previously prided needs to be placed OUTSIDE of the “body {}”
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @ForeverBrewing
                                        @ForeverBrewing said in MMM-SunRiseSet:
                                        It sure does. :thumbsup:
                                        • V
                                          Vauxdvihl @Mykle1
                                          @Mykle1
                                          Thanks for your feedback
                                          ok
                                          we need to wait…it is a great module for the kids
                                          Thanks a lot
                                          • Mykle1M
                                            For those that be using MMM-SunRiseSet, please forgive the outage of the API. You can still use the module, albeit without the animated images. You can still use the module without the image by adding this to your custom.css file. This will remove the broken link from appearing.
                                            .MMM-SunRiseSet .img {
                                              display: none;
                                            Example along with MMM-EyeCandy. Animation is seamless loop in the module
