    MMM-SunRiseSet
    Scheduled Pinned Locked Moved Education
    51 Posts 10 Posters 35.4k Views 10 Watching
      Mykle1 Project Sponsor Module Developer @justjim1220
      @justjim1220 said in MMM-SunRiseSet:
      when you asked for others to email them, I did about 5 or 6 times
      I thank you very much for that. :thumbsup:
      • justjim1220J Offline
        justjim1220 Module Developer @Mykle1
        @mykle1 yep!
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          0_1549154963174_Screenshot from 2019-02-02 18-34-15.png -
          • cowboysdudeC Offline
            Looks really good and I really like it! So I can use either if I’d like? I like the earth as it’s on a black background and it would look cool sitting on my 32" Mirror ;)
              @cowboysdude
              Yes, you can use either image. They both update to show the movement of the sun on the earth.
                @mykle1 have you ever tried setting the movement to 500ms?
                its kinda cool, if your device can handle it!
                I actually tried it with the Earth module…
                Jim Hallock - 1995
                  @justjim1220
                  Yes, I have. I used to run it at 1000ms. It’s pretty bad ass if your graphics can handle it
                  justjim1220J 1 Reply Last reply Reply Quote 1
                    @mykle1 when I did it, it was a mistake! But the outcome was cool!
                    It actually froze my dev machine after about 45 minutes!
                    Jim Hallock - 1995
                      @justjim1220
                      Jimbo is back! :-)
                        mrdenmark
                        i can’t to seem to get some images to show, i just get surise/sunset and time of day,if i select static i get the diagram but nothing with world or map
                        	disabled: false,
                        	module: "MMM-SunRiseSet",
                        		lat: "-44.57",      // Your latitude (for the data)
                        		lng: "168.50",     // Your longitude (for the data)
                        		image: "world",          // "world" (animation), "map" (animation), "static" (graph)
                        		imageOnly: "no",       // no = all data, yes = only animated world or map
                        		dayOrNight: "day",   // "night" approaching, "day" approaching (imageOnly: must be "yes", image: must be "world")
                        		useHeader: false,      // true if you want a header
                        		header: "Header",      // useHeader must be true
                        		maxWidth: "515px",
                        • V Offline
                          Vauxdvihl
                          @Mykle1
                          Me too
                          I have the same issue
                          No images are shown
                          Can you please help
                          Thanks a lot
                            Mykle1 Project Sponsor Module Developer @mrdenmark
                            @Vauxdvihl
                            @mrdenmark said in MMM-SunRiseSet:
                            My apologies.
                            The API in use for this module, http://api.usno.navy.mil, is down for maintenance. They have set a date of April, 2020 for completion. This also affects MMM-Lunartic but at least I was able to fashion a fix for that one. Not so in this case.
                            F V 2 Replies Last reply Reply Quote 0
                            • F Offline
                              ForeverBrewing @Mykle1
                              @Mykle1 So any way of getting rid of the images completely? I’ve tried updating the custom CSS as you have suggested on the issue raised on GitHub but I don’t know how to format it correctly for it to take effect. Thanks in advance!
                              • F Offline
                                ForeverBrewing @ForeverBrewing
                                @ForeverBrewing Ignore this; I have worked it out. The code that you previously prided needs to be placed OUTSIDE of the “body {}”
                                  Mykle1 Project Sponsor Module Developer @ForeverBrewing
                                  @ForeverBrewing said in MMM-SunRiseSet:
                                  It sure does. :thumbsup:
                                  • V Offline
                                    Vauxdvihl @Mykle1
                                    @Mykle1
                                    Thanks for your feedback
                                    ok
                                    we need to wait…it is a great module for the kids
                                    Thanks a lot
                                      For those that be using MMM-SunRiseSet, please forgive the outage of the API. You can still use the module, albeit without the animated images. You can still use the module without the image by adding this to your custom.css file. This will remove the broken link from appearing.
                                      .MMM-SunRiseSet .img {
                                        display: none;
                                      Example along with MMM-EyeCandy. Animation is seamless loop in the module
                                        What is that a brain sucker starving to death? LOL
                                          @cowboysdude
                                          Yessir. :-)
                                            Unfortunately, the api for this module is down for at least a few more months along with MMM-Lunartic. MMM-Lunartic continues to work with a temporary workaround.
