    The mirror that wasn't a mirror
    25 Posts 10 Posters 25.7k Views 10 Watching
      RedNax Module Developer
      Hi!
      EDIT: It probably has to do with vendor.js… The mm prefers the stock wind icons (older set, lacking some icons) over the ones bundled with the module… looking into a fix for that…
      Is that the most recent MMM-Wunderground module? There are a few icons missing from the display…
      There should be a wind-force icon at the top and an umbrella over the percipiation chance/amount:
        Should be fixed now… Just git pull to update the module
          RB14060 @RedNax
          @RedNax Confirmed working! Thanks for the quick fix.
            paviro @RedNax
            @RedNax shouldn’t we update the vendor ones then? @MichMich?
            – The Doctor
            • MichMichM Offline
              MichMich
              Yeah! Please send me a pull request (including an updated changeling).
              Thanks in advance!
                Bu52 @RB14060
                @RB14060 This is too cool. Good Job.
                  shgmongohh
                  Thanks for charing the config.js. It helps to understand how things works.
                  Sebastian
                    DazDavid
                    Where can i find the Module you are using for your time to arrive somwhere (“MMM-Traffic”)? That is quite cool.
                      DazDavid
                      Ok, found it.
                        Mitchfarino Module Developer @DazDavid
                        @DazDavid
                        For anyone else looking, you can get it here - https://github.com/SamLewis0602/MMM-Traffic
                          DazDavid
                          I just installed the Module as decripted and and set config file options but when I start Serveronly Mode of MM I get the following error Message:
                          Whoops! There was an uncaught exception…
                          TypeError: Cannot read property ‘legs’ of undefined
                          at Request._callback (…/MagicMirror/modules/MMM-Traffic/node_helper.js:47:55)
                          at Request.self.callback (…/MagicMirror/modules/MMM-Traffic/node_modules/request/request.js:187:22)
                          at emitTwo (events.js:106:13)
                          at Request.emit (events.js:191:7)
                          at Request. (…/MagicMirror/modules/MMM-Traffic/node_modules/request/request.js:1048:10)
                          at emitOne (events.js:96:13)
                          at Request.emit (events.js:188:7)
                          at IncomingMessage. (…/MagicMirror/modules/MMM-Traffic/node_modules/request/request.js:969:12)
                          at emitNone (events.js:91:20)
                          at IncomingMessage.emit (events.js:185:7)
                          Any Idea what causes the Problem and how to solve it?
                            bhepler Module Developer @DazDavid
                            @DazDavid Please post the relevant portion of your config.js file. That is a good place to start. Also please use the markdown commands to make your code easier for us to read.
                              DazDavid @bhepler
                              @bhepler
                              Yes you are right, sorry my fault.
                              So I copied the example from the github Page and just entered my Api Key to make sure the Module is working with basic Informations.
                              This is the appropriate part of my config:
                                  module: 'MMM-Traffic',
                                  position: 'bottom_bar',
                                  classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                                      api_key: '******',
                                      mode: 'driving',
                                      origin: '4 Pennsylvania Plaza, New York, NY 10001',
                                      destination: '1 MetLife Stadium Dr, East Rutherford, NJ 07073',
                                      arrival_time: '0800', //optional, but needs to be in 24 hour time if used.
                                      route_name: 'Home to Work',
                                      changeColor: true,
                                      showGreen: false,
                                      limitYellow: 5, //Greater than 5% of journey time due to traffic
                                      limitRed: 20, //Greater than 20% of journey time due to traffic
                                      traffic_model: 'pessimistic',
                                      interval: 120000 //2 minutes
                              Edit: Like this the mirror stucks on “Loading Commute” and the mentioned error is shown on console output continuously. Any idea what could be the Problem?
                                @DazDavid
                                @Notumlord had a similar issue, and when they changed the locations it worked fine
                                Not sure if they’ve made any progress with is - https://forum.magicmirror.builders/topic/446/trafficmaps/36
                                  DazDavid @Mitchfarino
                                  @Mitchfarino thanks for the hint but I´m not sure how exactly to enter the locations. Does anybody have an example for germany? I assume it would be street & no, postalcodd city. So for example Hauptstraße 15, 99090 Erfurt.
                                  Is that correct?
                                    @DazDavid how do you do it usually in Google maps? In the UK I can just put in the postcode and it works.
                                    Go to Google maps, place a pin on your destination and copy the address that it generates.
                                    See if that works
                                      @Mitchfarino i copied from Maps before and now I tryied only with postalcode and Postalcode + City name but still get the same error as written above. I think I have to contact the developer of the module.
                                        @DazDavid try these postcodes
                                        SE1 9SP
                                        SW1A 1AA
                                        See if it gets through the loading commute message
                                          DazDavid
                                          ok, somebody opened a bug report for this problem 20h hours ago so I think im not the only affected person :)
                                            @Mitchfarino Not working also
