    MMM-WeatherChart
    42 Posts 16 Posters 36.4k Views 15 Watching
      racampbellky
      Great module! Is there anyway to present in Fahrenheit?
        paphko @racampbellky
        @racampbellky I don’t think so. But you may check the website of yr.no, maybe you find a setting to use Fahrenheit in that diagram: http://www.yr.no/place/United_States/New_York/New_York/hour_by_hour.html
        If so, it should be possible.
          AxLed Module Developer
          i wanted to try the module today, but i dont work i get some error “del missing” or similar.
          Could it be that there is the file package.json missing on the github link, as there are some depencies in node_helper.js
          var http = require('http');
          var fs = require('fs');
          var del = require('del');
          var request = require('request');
          var NodeHelper = require("node_helper");
          Greets AxLED
            found a solution myself, there is a fork of this module: https://github.com/szech/mmm-weatherchart
            Installation:
            cd ~/MagicMirror/modules
            git clone https://github.com/szech/mmm-weatherchart.git
            cd mmm-weatherchart
            npm install
            Greets
            AxLED
              Stellanova
              If you replace grayscale with hue-rotate(190deg) in the mmm-weatherchart.js. You get the colors partially back and still have whitelines.
              if (this.config.negativeImage) {
              img.style[“-webkit-filter”] = “invert(100%) hue-rotate(190deg)”;
              • V Offline
                Vauxdvihl
                @Stellanova said in MMM-WeatherChart:
                is there a possibility to increase the size?
                Thanks a lot
                Regards
                  broberg Project Sponsor
                  @Vauxdvihl
                  Yes, But it will get fuzzy since the original image is only 828 × 272 pixels in size.
                  increase by 25%
                  .MMM-WeaterChart img{
                  width: 1035px !important;
                  height: 340px !important;
                  (To be clear, this go in to the custom.css file, not changing the module files)
                  • V Offline
                    Vauxdvihl
                    @broberg
                    hmm
                    seems to me not working
                    Strange is also that the editor does not “hightlight” the functions
                    .mmm-weatherchart img{
                    width: 1035px;
                    height: 340px;
                      broberg Project Sponsor @Vauxdvihl
                      @Vauxdvihl the module name is case sensitive
                      So .mmm-weathermodule is not the same as .MMM-WeatherModule
                      And you might have to add !important after the height and width for it to override the height specified in the module.
                      • V Offline
                        Vauxdvihl
                        @broberg
                        Yes i know ;-)
                        Look …i though it would be the correct way
                          @Vauxdvihl
                          It is, nevermind the above post then.
                          but do try the !important addition, it is sometimes needed when the size is defined in the document and not in the css files.
                            prototype0815
                            I need help with mmm-weatherchart:
                            https://forum.magicmirror.builders/topic/12204/black-screen-when-insert-https-github-com-paphko-mmm-weatherchart/3
                              sdetweil @prototype0815
                              @prototype0815 I reqplied in your other topic with instructions to download my fixed repo that resolves both problems… black screen and no image shown
                              • V Offline
                                Vauxdvihl
                                Hi friends,
                                i have seen in the dev mode that the modules gets the png from color from
                                here:
                                www.yr.no/place/Germany/Bavaria/Pöcking/meteogram.png
                                Can i use it also in color in the mm?
                                Thanks a lot
                                Regards
                                • lavolp3L Offline
                                  lavolp3 Module Developer @Vauxdvihl
                                  @Vauxdvihl have you tried setting the option
                                  negativeImage: false, // whether or not the default white image should be inverted
                                  How to troubleshoot modules
                                  MMM-soccer v2, MMM-AVStock
                                  • V Offline
                                    Vauxdvihl
                                    @lavolp3
                                    Works fine
                                    Thanks a lot
                                    One more question
                                    Using the code :
                                    > width: 1035px;
                                    > height: 340px;
                                    in my custom css it only “zoomed in” the image itself.
                                    But the area on the screen stay the same.
                                    I want to make this img viewable over the hole screen.
                                    Can please somebody help me?
                                    Thanks a lot
                                    • lavolp3L Offline
                                      @Vauxdvihl that is most probably due to the region.
                                      If you want the image to cover the whole screen give the module the position: “fullscreen_above” or position: “fullscreen_behind”. Or position: “top_bar” to not overlap with other modules.
                                      Just an example.
                                      Otherwise you would need to give the region more space to show the rest of the image.
                                      • V Offline
                                        Vauxdvihl
                                        @lavolp3
                                        ok
                                        this is strange for me
                                        using also modules like “iss live” or “rain map”
                                        I put them in the Top_center and increase the “width and height” datas.
                                        These modules then take there place on the screen (like adjusted to these datas width and heigt)
                                        I will play a around…lets see
                                        thanks
                                          MajorC Project Sponsor @AxLed
                                          @AxLed I find your fork very useful.
                                          Can you tell me, how to use: rgba(0,0,0,0.06); as background-color?
                                            it looks like the MMM-WeatherChart works fine, but I get this messages:
                                            loader.js:192 GET http://192.168.2.16:8080/modules/mmm-weatherchart/hashmap.js net::ERR_ABORTED 404 (Not Found)
                                            loader.js:186 Error on loading script: modules/mmm-weatherchart/hashmap.js
                                            web-loaders.js:87 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
                                            Any idea how to solve this errors?
                                            • 2 / 3
