    MMM-WeatherChart
    42 Posts 16 Posters 37.5k Views 15 Watching
    • paphkoP
      paphko
      @gshimself glad to hear that it’s fixed for you. Yes, because update interval must be specified in ms.
      @amanzimdwini you could try to add a scale option, but I’m not sure how to properly implement it for both cases, with and without border. If you found a proper solution for it, tell me or create a pull request :-)
        racampbellky
        Great module! Is there anyway to present in Fahrenheit?
        paphkoP 1 Reply Last reply
        • paphkoP
          paphko @racampbellky
          @racampbellky I don’t think so. But you may check the website of yr.no, maybe you find a setting to use Fahrenheit in that diagram: http://www.yr.no/place/United_States/New_York/New_York/hour_by_hour.html
          If so, it should be possible.
          • A
            AxLed Module Developer
            i wanted to try the module today, but i dont work i get some error “del missing” or similar.
            Could it be that there is the file package.json missing on the github link, as there are some depencies in node_helper.js
            var http = require('http');
            var fs = require('fs');
            var del = require('del');
            var request = require('request');
            var NodeHelper = require("node_helper");
            Greets AxLED
            • A
              found a solution myself, there is a fork of this module: https://github.com/szech/mmm-weatherchart
              Installation:
              cd ~/MagicMirror/modules
              git clone https://github.com/szech/mmm-weatherchart.git
              cd mmm-weatherchart
              npm install
              Greets
              AxLED
              M 1 Reply Last reply
                Stellanova
                If you replace grayscale with hue-rotate(190deg) in the mmm-weatherchart.js. You get the colors partially back and still have whitelines.
                if (this.config.negativeImage) {
                img.style[“-webkit-filter”] = “invert(100%) hue-rotate(190deg)”;
                • V
                  Vauxdvihl
                  @Stellanova said in MMM-WeatherChart:
                  is there a possibility to increase the size?
                  Thanks a lot
                  Regards
                  • brobergB
                    broberg Project Sponsor
                    @Vauxdvihl
                    Yes, But it will get fuzzy since the original image is only 828 × 272 pixels in size.
                    increase by 25%
                    .MMM-WeaterChart img{
                    width: 1035px !important;
                    height: 340px !important;
                    (To be clear, this go in to the custom.css file, not changing the module files)
                    • V
                      Vauxdvihl
                      @broberg
                      hmm
                      seems to me not working
                      Strange is also that the editor does not “hightlight” the functions
                      .mmm-weatherchart img{
                      width: 1035px;
                      height: 340px;
                      brobergB 1 Reply Last reply
                      • brobergB
                        broberg Project Sponsor @Vauxdvihl
                        @Vauxdvihl the module name is case sensitive
                        So .mmm-weathermodule is not the same as .MMM-WeatherModule
                        And you might have to add !important after the height and width for it to override the height specified in the module.
                        • V
                          Vauxdvihl
                          @broberg
                          Yes i know ;-)
                          Look …i though it would be the correct way
                          • brobergB
                            @Vauxdvihl
                            It is, nevermind the above post then.
                            but do try the !important addition, it is sometimes needed when the size is defined in the document and not in the css files.
                            • prototype0815P
                              prototype0815
                              I need help with mmm-weatherchart:
                              https://forum.magicmirror.builders/topic/12204/black-screen-when-insert-https-github-com-paphko-mmm-weatherchart/3
                                sdetweil @prototype0815
                                @prototype0815 I reqplied in your other topic with instructions to download my fixed repo that resolves both problems… black screen and no image shown
                                • V
                                  Vauxdvihl
                                  Hi friends,
                                  i have seen in the dev mode that the modules gets the png from color from
                                  here:
                                  www.yr.no/place/Germany/Bavaria/Pöcking/meteogram.png
                                  Can i use it also in color in the mm?
                                  Thanks a lot
                                  Regards
                                  lavolp3L 1 Reply Last reply
                                  • lavolp3L
                                    lavolp3 Module Developer @Vauxdvihl
                                    @Vauxdvihl have you tried setting the option
                                    negativeImage: false, // whether or not the default white image should be inverted
                                    How to troubleshoot modules
                                    MMM-soccer v2, MMM-AVStock
                                    • V
                                      Vauxdvihl
                                      @lavolp3
                                      Works fine
                                      Thanks a lot
                                      One more question
                                      Using the code :
                                      > width: 1035px;
                                      > height: 340px;
                                      in my custom css it only “zoomed in” the image itself.
                                      But the area on the screen stay the same.
                                      I want to make this img viewable over the hole screen.
                                      Can please somebody help me?
                                      Thanks a lot
                                      • lavolp3L
                                        @Vauxdvihl that is most probably due to the region.
                                        If you want the image to cover the whole screen give the module the position: “fullscreen_above” or position: “fullscreen_behind”. Or position: “top_bar” to not overlap with other modules.
                                        Just an example.
                                        Otherwise you would need to give the region more space to show the rest of the image.
                                        • V
                                          Vauxdvihl
                                          @lavolp3
                                          ok
                                          this is strange for me
                                          using also modules like “iss live” or “rain map”
                                          I put them in the Top_center and increase the “width and height” datas.
                                          These modules then take there place on the screen (like adjusted to these datas width and heigt)
                                          I will play a around…lets see
                                          thanks
                                            MajorC Project Sponsor @AxLed
                                            @AxLed I find your fork very useful.
                                            Can you tell me, how to use: rgba(0,0,0,0.06); as background-color?
                                            • 2 / 3
