    MMM-WeatherChart
    42 Posts 16 Posters 37.5k Views 15 Watching
    • V
      Vauxdvihl
      @broberg
      Yes i know ;-)
      Look …i though it would be the correct way
      brobergB 1 Reply Last reply
      • brobergB
        broberg Project Sponsor @Vauxdvihl
        @Vauxdvihl
        It is, nevermind the above post then.
        but do try the !important addition, it is sometimes needed when the size is defined in the document and not in the css files.
        • prototype0815P
          prototype0815
          I need help with mmm-weatherchart:
          https://forum.magicmirror.builders/topic/12204/black-screen-when-insert-https-github-com-paphko-mmm-weatherchart/3
            sdetweil @prototype0815
            @prototype0815 I reqplied in your other topic with instructions to download my fixed repo that resolves both problems… black screen and no image shown
            • V
              Vauxdvihl
              Hi friends,
              i have seen in the dev mode that the modules gets the png from color from
              here:
              www.yr.no/place/Germany/Bavaria/Pöcking/meteogram.png
              Can i use it also in color in the mm?
              Thanks a lot
              Regards
              lavolp3L 1 Reply Last reply
              • lavolp3L
                lavolp3 Module Developer @Vauxdvihl
                @Vauxdvihl have you tried setting the option
                negativeImage: false, // whether or not the default white image should be inverted
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                • V
                  Vauxdvihl
                  @lavolp3
                  Works fine
                  Thanks a lot
                  One more question
                  Using the code :
                  > .mmm-weatherchart img{
                  > width: 1035px;
                  > height: 340px;
                  in my custom css it only “zoomed in” the image itself.
                  But the area on the screen stay the same.
                  I want to make this img viewable over the hole screen.
                  Can please somebody help me?
                  Thanks a lot
                  • lavolp3L
                    @Vauxdvihl that is most probably due to the region.
                    If you want the image to cover the whole screen give the module the position: “fullscreen_above” or position: “fullscreen_behind”. Or position: “top_bar” to not overlap with other modules.
                    Just an example.
                    Otherwise you would need to give the region more space to show the rest of the image.
                    • V
                      Vauxdvihl
                      @lavolp3
                      ok
                      this is strange for me
                      using also modules like “iss live” or “rain map”
                      I put them in the Top_center and increase the “width and height” datas.
                      These modules then take there place on the screen (like adjusted to these datas width and heigt)
                      I will play a around…lets see
                      thanks
                        MajorC Project Sponsor @AxLed
                        @AxLed I find your fork very useful.
                        Can you tell me, how to use: rgba(0,0,0,0.06); as background-color?
                          it looks like the MMM-WeatherChart works fine, but I get this messages:
                          loader.js:192 GET http://192.168.2.16:8080/modules/mmm-weatherchart/hashmap.js net::ERR_ABORTED 404 (Not Found)
                          loader.js:186 Error on loading script: modules/mmm-weatherchart/hashmap.js
                          web-loaders.js:87 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
                          Any idea how to solve this errors?
                            sdetweil @MajorC
                            @majorc did u run npm install in the module folder after cloning the module?
                            M 1 Reply Last reply
                              MajorC Project Sponsor @sdetweil
                              @sdetweil I was not sure, so I did it again.
                              But the error is still the same.
                                @paphko do you have any idea what this error could be:
                                loader.js:201 GET http://192.168.2.16:8080/modules/mmm-weatherchart/hashmap.js net::ERR_ABORTED 404 (Not Found)
                                loader.js:195 Error on loading script: modules/mmm-weatherchart/hashmap.js
                                Thank you!
                                  sdetweil @MajorC
                                  @majorc which version are you using.
                                  his is 5 years old
                                  I published a fork last year
                                  https://github.com/sdetweil/mmm-weatherchart
                                  • H
                                    hogedir
                                    @sdetweil can you update the module, the URL in yr.no just changed. your module is excellent, i like it. just need a little update to work. thanks.
                                      sdetweil @hogedir
                                      @hogedir well it’s not my module, I just fixed a problem.
                                      if you can tell me more about the changes
                                      I’ve got a lot going on right now, maybe get a chance next week.
                                      • H
                                        hogedir
                                        this module is working on the last version of MMM? thanks
                                        S S 2 Replies Last reply
                                          sdetweil @hogedir
                                          @hogedir from where?
                                          git remote -v
                                            Snyider @hogedir
                                            @hogedir
                                            Yes the Modul works fine in my Case. :)
                                            Kr. Chris
                                            • 2 / 3
