    MMM-WeatherChart
    42 Posts 16 Posters 37.5k Views 15 Watching
    • prototype0815P
      prototype0815
      I need help with mmm-weatherchart:
      https://forum.magicmirror.builders/topic/12204/black-screen-when-insert-https-github-com-paphko-mmm-weatherchart/3
        sdetweil @prototype0815
        @prototype0815 I reqplied in your other topic with instructions to download my fixed repo that resolves both problems… black screen and no image shown
        • V
          Vauxdvihl
          Hi friends,
          i have seen in the dev mode that the modules gets the png from color from
          here:
          www.yr.no/place/Germany/Bavaria/Pöcking/meteogram.png
          Can i use it also in color in the mm?
          Thanks a lot
          Regards
          lavolp3L 1 Reply Last reply
          • lavolp3L
            lavolp3 Module Developer @Vauxdvihl
            @Vauxdvihl have you tried setting the option
            negativeImage: false, // whether or not the default white image should be inverted
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • V
              Vauxdvihl
              @lavolp3
              Works fine
              Thanks a lot
              One more question
              Using the code :
              > .mmm-weatherchart img{
              > width: 1035px;
              > height: 340px;
              in my custom css it only “zoomed in” the image itself.
              But the area on the screen stay the same.
              I want to make this img viewable over the hole screen.
              Can please somebody help me?
              Thanks a lot
              • lavolp3L
                @Vauxdvihl that is most probably due to the region.
                If you want the image to cover the whole screen give the module the position: “fullscreen_above” or position: “fullscreen_behind”. Or position: “top_bar” to not overlap with other modules.
                Just an example.
                Otherwise you would need to give the region more space to show the rest of the image.
                • V
                  Vauxdvihl
                  @lavolp3
                  ok
                  this is strange for me
                  using also modules like “iss live” or “rain map”
                  I put them in the Top_center and increase the “width and height” datas.
                  These modules then take there place on the screen (like adjusted to these datas width and heigt)
                  I will play a around…lets see
                  thanks
                    MajorC Project Sponsor @AxLed
                    @AxLed I find your fork very useful.
                    Can you tell me, how to use: rgba(0,0,0,0.06); as background-color?
                      it looks like the MMM-WeatherChart works fine, but I get this messages:
                      loader.js:192 GET http://192.168.2.16:8080/modules/mmm-weatherchart/hashmap.js net::ERR_ABORTED 404 (Not Found)
                      loader.js:186 Error on loading script: modules/mmm-weatherchart/hashmap.js
                      web-loaders.js:87 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
                      Any idea how to solve this errors?
                        sdetweil @MajorC
                        @majorc did u run npm install in the module folder after cloning the module?
                        M 1 Reply Last reply
                          MajorC Project Sponsor @sdetweil
                          @sdetweil I was not sure, so I did it again.
                          But the error is still the same.
                            @paphko do you have any idea what this error could be:
                            loader.js:201 GET http://192.168.2.16:8080/modules/mmm-weatherchart/hashmap.js net::ERR_ABORTED 404 (Not Found)
                            loader.js:195 Error on loading script: modules/mmm-weatherchart/hashmap.js
                            Thank you!
                              sdetweil @MajorC
                              @majorc which version are you using.
                              his is 5 years old
                              I published a fork last year
                              https://github.com/sdetweil/mmm-weatherchart
                              • H
                                hogedir
                                @sdetweil can you update the module, the URL in yr.no just changed. your module is excellent, i like it. just need a little update to work. thanks.
                                  sdetweil @hogedir
                                  @hogedir well it’s not my module, I just fixed a problem.
                                  if you can tell me more about the changes
                                  I’ve got a lot going on right now, maybe get a chance next week.
                                  • H
                                    hogedir
                                    this module is working on the last version of MMM? thanks
                                    S S 2 Replies Last reply
                                      sdetweil @hogedir
                                      @hogedir from where?
                                      git remote -v
                                        Snyider @hogedir
                                        @hogedir
                                        Yes the Modul works fine in my Case. :)
                                        Kr. Chris
                                        • 2 / 3
