    mmm-suncalc - Text only display of sunrise, sunset and other sun events
    29 Posts 8 Posters 17.0k Views 8 Watching
      jag
      No so much screenshots.
      This is a text only module.
      Using a template, like “Sunrise at , sunset at , highest point at ”
      Will be displayed as “Sunrise at 09:15, sunset at 15:34, highest point at 12:25”.
      Time format is the same as is globally.
        paviro
        I see :D It still would be nice to see it in context with a clock for example :)
        – The Doctor
        • SnilleS Offline
          Snille Module Developer
          Hi!
          Thank you for this module! :)
          I can’t get it to change the “text”.
          My config looks like this:
          		module: "mmm-suncalc",
          		classes: "default everyone small dimmed",
          		latitude: 56.1171367,
          		longitude: 12.9543434,
          		text: "Soluppgång sunrise, Solnedgång sunset, Solen högst solarNoon, Gryning dusk, Skymmning dawn"
          But the actual screen looks like this:
          What am I missing…?
          PS: The example conf on your git repo has one m to too much in the module name and when you “clone” it it’s all in non capitals “mmm-suncalc” (most modules have MMM-Modname). :)
          Obs: had to remove the " > " "< " for the conf to show correct here…
          Thank you.
          • Y Offline
            yawns Moderator @Snille
            Should work with these settings.
            • SnilleS Offline
              @yawns Working! :) Thank you!
                jag
                Thx for downloading and very useful feedback :).
                Uploaded new version.
                Added support for css classes.
                Font size defaults to small.
                  retroflex Project Sponsor Module Developer
                  Just found this old module and added it to my mirror. With some unicode and html the result is pretty nice, so I thought I’d share it:
                  Ok, in Swedish, but it basically says “The sun… rises: / sets:”. I used dawn-sunrise and sunset-dusk for the time intervals. This gives approximately the time from when it’s almost dark to full day and vice versa.
                  Config:
                  			module: 'mmm-suncalc',
                  			position: 'top_left',
                  			header: 'Solen',
                  				latitude: xx.xxxx,
                  				longitude: xx.xxxx,
                  				text: '<table>' +
                  								'<tr><td>& #9728;</td><td>Går upp:</td><td style="text-align: right">[dawn] - [sunrise]</td></tr>' +
                  								'<tr><td>& #9790;</td><td>Går ner:</td><td style="text-align: right">[sunset] - [dusk]</td></tr>' +
                  							 '</table>'
                  Note that you need to remove the space between & and # in the config above. It was impossible to write the code in the forum otherwise. Also you need to change [ … ] to < … > for dawn, sunset etc.
                    dankerthrone
                    Hey, total newbie to everything coding- and mirror-related here. I tried to get suncalc to work while also trying @retroflex 's suggested layout, but whatever I do, nothing ever show’s up on my MM screen. The module just doesn’t do anything. Do I need to also clone the original suncalc repository? Where to, if so?
                    So far, what I got is this:
                    			position: "lower_third",
                    			//classes: "default everyone small dimmed",
                    			header: "Sonne",
                    				latitude: 51.03586,
                    				longitude: 7.06379,
                    				text: "Aufgang: <dawn> - <sunrise>. Untergang: <sunset> - <dusk>"
                    				//'<table>' +
                    				//'<tr><td>&#9728;</td><td>Går upp:</td><td><dawn> - <sunrise></td></tr>' +
                    				//'<tr><td>&#9790;</td><td>Går ner:</td><td><sunset> - <dusk></td></tr>' +
                    				//'</table>'
                    Does that look alright?
                      sdetweil @dankerthrone
                      @dankerthrone the module is on github
                      https://github.com/janbanan007/mmm-suncalc
                      the readme shows a simple start
                        dankerthrone
                        Thanks. I think in general people know to cd to the module folder to be installed and then run
                        npm install
                        but I didn’t get that from the readme, thus ran the install command from the ~/MagicMirror folder and as a result never installed anything. No wonder the thing doesn’t run :D
                        It does now, though, so thanks again!
                        • LordyL Offline
                          Lordy
                          can sunrise and sunset be colored, if so, can you please tell me the line (command) for css?
                            retroflex Project Sponsor Module Developer @Lordy
                            @Lordy There are no css names to distinguish sunrise and sunset. But you can add html directly to the config instead. See my previous answer to this thread for an example. So something like:
                            text: 'Sunrise < span style="color: #ffff00" >< sunrise >< /span >
                            Remove the extra spaces next to the brackets. Had to include them or otherwise the forum would show nothing.
                            LordyL 1 Reply Last reply Reply Quote 1
                            • LordyL Offline
                              Lordy @retroflex
                              @retroflex
                              Where exactly? Here my config:
                              text: ‘
                              ☀Sonnenaufgang: -
                              ☾Sonnenuntergang: -
                              LordyL 1 Reply Last reply Reply Quote 0
                              • LordyL Offline
                                Lordy @Lordy
                                  @Lordy Aha. Then change one of the < td > to < td style=“color: #ffff00” >
                                  • LordyL Offline
                                    Lordy @retroflex
                                    @retroflex
                                    Thank U,that’s it. :thumbs_up_light_skin_tone:
                                    • LordyL Offline
                                      Lordy @Lordy
                                        @Lordy Great that it worked out! I like the idea, I’ll colorize mine too now.
                                        • LordyL Offline
                                          Lordy @retroflex
                                          @retroflex said in mmm-suncalc - Text only display of sunrise, sunset and other sun events:
                                          Enjoying working and i would like to see the results.:grinning_face_with_smiling_eyes:
                                            LordyL 2 Replies Last reply Reply Quote 0
