    mmm-suncalc - Text only display of sunrise, sunset and other sun events
    29 Posts 8 Posters 16.9k Views 8 Watching
    • SnilleS Offline
      Snille Module Developer
      @yawns Working! :) Thank you!
        jag
        Thx for downloading and very useful feedback :).
        Uploaded new version.
        Added support for css classes.
        Font size defaults to small.
          retroflex Project Sponsor Module Developer
          Just found this old module and added it to my mirror. With some unicode and html the result is pretty nice, so I thought I’d share it:
          Ok, in Swedish, but it basically says “The sun… rises: / sets:”. I used dawn-sunrise and sunset-dusk for the time intervals. This gives approximately the time from when it’s almost dark to full day and vice versa.
          Config:
          			module: 'mmm-suncalc',
          			position: 'top_left',
          			header: 'Solen',
          				latitude: xx.xxxx,
          				longitude: xx.xxxx,
          				text: '<table>' +
          								'<tr><td>& #9728;</td><td>Går upp:</td><td style="text-align: right">[dawn] - [sunrise]</td></tr>' +
          								'<tr><td>& #9790;</td><td>Går ner:</td><td style="text-align: right">[sunset] - [dusk]</td></tr>' +
          							 '</table>'
          Note that you need to remove the space between & and # in the config above. It was impossible to write the code in the forum otherwise. Also you need to change [ … ] to < … > for dawn, sunset etc.
            dankerthrone
            Hey, total newbie to everything coding- and mirror-related here. I tried to get suncalc to work while also trying @retroflex 's suggested layout, but whatever I do, nothing ever show’s up on my MM screen. The module just doesn’t do anything. Do I need to also clone the original suncalc repository? Where to, if so?
            So far, what I got is this:
            			position: "lower_third",
            			//classes: "default everyone small dimmed",
            			header: "Sonne",
            				latitude: 51.03586,
            				longitude: 7.06379,
            				text: "Aufgang: <dawn> - <sunrise>. Untergang: <sunset> - <dusk>"
            				//'<table>' +
            				//'<tr><td>&#9728;</td><td>Går upp:</td><td><dawn> - <sunrise></td></tr>' +
            				//'<tr><td>&#9790;</td><td>Går ner:</td><td><sunset> - <dusk></td></tr>' +
            				//'</table>'
            Does that look alright?
              sdetweil @dankerthrone
              @dankerthrone the module is on github
              https://github.com/janbanan007/mmm-suncalc
              the readme shows a simple start
                dankerthrone
                Thanks. I think in general people know to cd to the module folder to be installed and then run
                npm install
                but I didn’t get that from the readme, thus ran the install command from the ~/MagicMirror folder and as a result never installed anything. No wonder the thing doesn’t run :D
                It does now, though, so thanks again!
                • LordyL Offline
                  Lordy
                  can sunrise and sunset be colored, if so, can you please tell me the line (command) for css?
                    retroflex Project Sponsor Module Developer @Lordy
                    @Lordy There are no css names to distinguish sunrise and sunset. But you can add html directly to the config instead. See my previous answer to this thread for an example. So something like:
                    text: 'Sunrise < span style="color: #ffff00" >< sunrise >< /span >
                    Remove the extra spaces next to the brackets. Had to include them or otherwise the forum would show nothing.
                    LordyL 1 Reply Last reply Reply Quote 1
                    • LordyL Offline
                      Lordy @retroflex
                      @retroflex
                      Where exactly? Here my config:
                      text: ‘
                      ☀Sonnenaufgang: -
                      ☾Sonnenuntergang: -
                      LordyL 1 Reply Last reply Reply Quote 0
                      • LordyL Offline
                        Lordy @Lordy
                          @Lordy Aha. Then change one of the < td > to < td style=“color: #ffff00” >
                          • LordyL Offline
                            Lordy @retroflex
                            @retroflex
                            Thank U,that’s it. :thumbs_up_light_skin_tone:
                            • LordyL Offline
                              Lordy @Lordy
                                @Lordy Great that it worked out! I like the idea, I’ll colorize mine too now.
                                • LordyL Offline
                                  Lordy @retroflex
                                  @retroflex said in mmm-suncalc - Text only display of sunrise, sunset and other sun events:
                                  Enjoying working and i would like to see the results.:grinning_face_with_smiling_eyes:
                                    LordyL 2 Replies Last reply Reply Quote 0
                                    • LordyL Offline
                                      Lordy @retroflex
                                      @retroflex
                                      Nice:thumbs_up_light_skin_tone: That’s exactly how I put forward it.
                                      • LordyL Offline
                                        Lordy @retroflex
                                        @retroflex
                                        I hope you can help me again?
                                        I try to change the font size, but I can’t get any further. Can you please tell me my mistake?
                                        At the moment the module is going under compared to the other modules.
                                        My css entry:
                                        .mmm-suncalc text {font-size: 30px}
                                        R S 2 Replies Last reply Reply Quote 0
                                          @Lordy Where does “text” come from? Try:
                                          .mmm-suncalc {
                                            font-size: 30px
                                          • LordyL Offline
                                            Lordy @retroflex
                                            .mmm-suncalc {
                                            font-size: 30px
                                            I had tried that too. Unfortunately without success. “Text” appears in the config.
                                            Do you have another suggestion?
