    mmm-suncalc - Text only display of sunrise, sunset and other sun events
    29 Posts 8 Posters 15.3k Views 8 Watching
    • paviroP Offline
      paviro
      Please add some screenshots! :)
      – The Doctor
        jag
        No so much screenshots.
        This is a text only module.
        Using a template, like “Sunrise at , sunset at , highest point at ”
        Will be displayed as “Sunrise at 09:15, sunset at 15:34, highest point at 12:25”.
        Time format is the same as is globally.
        • paviroP Offline
          paviro
          I see :D It still would be nice to see it in context with a clock for example :)
          – The Doctor
          • SnilleS Offline
            Snille Module Developer
            Hi!
            Thank you for this module! :)
            I can’t get it to change the “text”.
            My config looks like this:
            		module: "mmm-suncalc",
            		classes: "default everyone small dimmed",
            		latitude: 56.1171367,
            		longitude: 12.9543434,
            		text: "Soluppgång sunrise, Solnedgång sunset, Solen högst solarNoon, Gryning dusk, Skymmning dawn"
            But the actual screen looks like this:
            What am I missing…?
            PS: The example conf on your git repo has one m to too much in the module name and when you “clone” it it’s all in non capitals “mmm-suncalc” (most modules have MMM-Modname). :)
            Obs: had to remove the " > " "< " for the conf to show correct here…
            Thank you.
            If you cant find it, make it and share it!
            Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
            • yawnsY Offline
              yawns Moderator @Snille
              Should work with these settings.
              • SnilleS Offline
                @yawns Working! :) Thank you!
                  jag
                  Thx for downloading and very useful feedback :).
                  Uploaded new version.
                  Added support for css classes.
                  Font size defaults to small.
                    retroflex Project Sponsor Module Developer
                    Just found this old module and added it to my mirror. With some unicode and html the result is pretty nice, so I thought I’d share it:
                    Ok, in Swedish, but it basically says “The sun… rises: / sets:”. I used dawn-sunrise and sunset-dusk for the time intervals. This gives approximately the time from when it’s almost dark to full day and vice versa.
                    Config:
                    			module: 'mmm-suncalc',
                    			position: 'top_left',
                    			header: 'Solen',
                    				latitude: xx.xxxx,
                    				longitude: xx.xxxx,
                    				text: '<table>' +
                    								'<tr><td>& #9728;</td><td>Går upp:</td><td style="text-align: right">[dawn] - [sunrise]</td></tr>' +
                    								'<tr><td>& #9790;</td><td>Går ner:</td><td style="text-align: right">[sunset] - [dusk]</td></tr>' +
                    							 '</table>'
                    Note that you need to remove the space between & and # in the config above. It was impossible to write the code in the forum otherwise. Also you need to change [ … ] to < … > for dawn, sunset etc.
                      dankerthrone
                      Hey, total newbie to everything coding- and mirror-related here. I tried to get suncalc to work while also trying @retroflex 's suggested layout, but whatever I do, nothing ever show’s up on my MM screen. The module just doesn’t do anything. Do I need to also clone the original suncalc repository? Where to, if so?
                      So far, what I got is this:
                      			position: "lower_third",
                      			//classes: "default everyone small dimmed",
                      			header: "Sonne",
                      				latitude: 51.03586,
                      				longitude: 7.06379,
                      				text: "Aufgang: <dawn> - <sunrise>. Untergang: <sunset> - <dusk>"
                      				//'<table>' +
                      				//'<tr><td>&#9728;</td><td>Går upp:</td><td><dawn> - <sunrise></td></tr>' +
                      				//'<tr><td>&#9790;</td><td>Går ner:</td><td><sunset> - <dusk></td></tr>' +
                      				//'</table>'
                      Does that look alright?
                        sdetweil @dankerthrone
                        @dankerthrone the module is on github
                        https://github.com/janbanan007/mmm-suncalc
                        the readme shows a simple start
