    How to hide Splash screen on boot or edit Splash screen on boot?
    12 Posts 7 Posters 13.7k Views 6 Watching
      broberg Project Sponsor
      First hit on google, h
      ttp://www.raspberry-projects.com/pi/pi-operating-systems/raspbian/custom-boot-up-screen
      Don’t know if it works on all PI’s however
      • L Offline
        lolobyte
        Hi, if you have installed the jessie plex version, you have to start
        sudo raspi-config
        At point 3 Boot Options it is possiblr to general disable or enable the splash screen on boot.
        If you have an normal jessie without plex the use a custom splash screen
        sudo apt-get install fbi
        Copy your custom splash image to /etc/ and name it splash.png.
        Next, create an init.d script called “asplashscreen” in “/etc/init.d/”.
        Create now this script with
        sudo nano /etc/init.d/asplashscreen
        #! /bin/sh
        ### BEGIN INIT INFO
        # Provides:          asplashscreen
        # Required-Start:
        # Required-Stop:
        # Should-Start:
        # Default-Start:     S
        # Default-Stop:
        # Short-Description: Show custom splashscreen
        # Description:       Show custom splashscreen
        ### END INIT INFO
        do_start () {
            /usr/bin/fbi -T 1 -noverbose -a /etc/splash.png
            exit 0
        case "$1" in
          start|"")
            do_start
          restart|reload|force-reload)
            echo "Error: argument '$1' not supported" >&2
            exit 3
          stop)
            # No-op
          status)
            exit 0
            echo "Usage: asplashscreen [start|stop]" >&2
            exit 3
        esac
        Then make that script executable and install it for init:
        sudo chmod a+x /etc/init.d/asplashscreen
        sudo insserv /etc/init.d/asplashscreen
        Reboot and watch your custom splash screen:
        sudo reboot
        If you want to hide most of the Boot text then follow this step:
        sudo nano /boot/cmdline.txt
        may look something like this:
        tty3: starts with console 3 to hide the boot messages!
        dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty3 loglevel=3 logo.nologo root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        good luck
        Mod-Edit: Please use markdown, otherwise this becomes totally unreadable.
        N 1 Reply Last reply Reply Quote 1
        • N Offline
          nobita @lolobyte
          @lolobyte Thanks your help,I will try later
          • L Offline
            lolobyte
            Sorry, don’ know who has written this…
            Probably a Moderator.
            What please is “markdown” and how to use it?
              broberg Project Sponsor @lolobyte
              @lolobyte
              Here is a documentation of markdown :
              http://commonmark.org/help/
                schlachtkreuzer6
                The the easiest way to change the splash screen is changing the picture ;) https://pi280.wordpress.com/2016/10/17/about-that-pixel-splash-screen/
                • N Offline
                  nobita @schlachtkreuzer6
                  @schlachtkreuzer6 I mean Splash screen on boot like this0_1486022813410_S__4210701.jpg
                  Y S 2 Replies Last reply Reply Quote 2
                  • Y Offline
                    yawns Moderator @nobita
                    @nobita
                    I did not check, so this is all theory.
                    The splashscreen is using plymouth, so you should be able to change it the “common way”:
                    http://www.bodhilinux.com/w/changing-plymouth-bootsplash/
                      schlachtkreuzer6 @nobita
                      @nobita yeah just change that image to another image (in the standard plymoth directory) and you are fine. i did that like this, before MM v2.1 with the splash screen was released, because that wohle plymouth stuff did not work for me. and there just few comandlines and worked perfectly!
                        bachoo786 @schlachtkreuzer6
                        @schlachtkreuzer6 how do you change the image? In which folder is the image?
                          sdetweil @bachoo786
                          @bachoo786 >In which folder is the image?
                          /usr/share/plymouth/themes
                          this shows the list of available
                           plymouth-set-default-theme --list
                          this resets to default
                          plymouth-set-default-theme --reset
                          see the installer code (and the install.log, as install changed the splash screen image)
