      BD0G
      Did you run npm install in the MMM-NOAA3 directory? YES
      Tried deleting and recloning the module from guthub? YES!
      Still not working at this point
      Disabling your other modules? YES! Disabled every other module and restarted Magic Mirror.
      Now the MMM-NOAA3 module is displayed !
      So there appears to be a conflict with another module.
      Next steps are to enable each module one by one and restart after doing so with each one.
      I wonder which one it is?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @BD0G
        @BD0G said in MMM-NOAA - Another Weather Module:
        You only need restart MM, not your entire system. That shouldn’t take too long. Let me know your findings.
        B 1 Reply Last reply
          BD0G @Mykle1
          @Mykle1 Yup. I just do a PM2 restart 0. :)
          • Mykle1M
            @BD0G
            Hope you’re having some success getting a fresh config.js.sample. Remember never to modify this file. Only use “copies” of it that you rename to config.js.
            Here you can see that the calendar and noaa3 run happily together. Talk tomorrow. Peace.
            • cowboysdudeC
              Good things happen when your config.js is working ;)
              • Mykle1M
                @cowboysdude
                What’s a config.js?
                  BD0G
                  Now that I have scrapped my Pi Zero W and have done a fresh install of “Buster” and MM on my Pi 3 B Plus everything is playing together nicely!
                  Reply Quote 2
                  • Mykle1M
                    Well done sir!
                      seramik
                      I’ve juste update with ‘git pull’
                      and look what arrived at the name ‘today’ ☹️
                      Lien vers mon image
                      any idéa ?
                        seramik
                        • cowboysdudeC
                          Description:
                          Added a new condensed format for NOAA3 … it uses MMM-NOAA5.css file. To set that please see readme~
                          Please follow Readme on Github!
                          To update just do a ‘git pull’ in the MagicMirror/modules/MMM-NOAA3 directory
                          Version 3.4.2
                          Download:
                          [card:cowboysdude/MMM-NOAA3]
                          Mykle1M 2 Replies Last reply
                          • Mykle1M
                            @cowboysdude
                            Still the best weather module. No others come close. Not even mine. I hate you for that. :-)
                              seramik
                              sorry
                              my upgrade was not complete
                              tomorrow i will post you a photo
                                doogy_rev
                                I ran the upgrade this morning which worked great, however the 4 day forecast seems to have moved vertically. it was default and no custom changes made.
                                Is there an easy way to revert it?
                                • Mykle1M
                                  @cowboysdude
                                  Fired right up for me. :thumbsup:
                                    seramik
                                    now i’ve got the same trouble as doogy_rev
                                    • cowboysdudeC
                                      cowboysdude Module Developer @doogy_rev
                                      @doogy_rev said in MMM-NOAA - Another Weather Module:
                                      Yes just use one of the other css files ;) That’s MMM-NOAA5.css file … it may be interferring with other css for some reason.
                                      • cowboysdudeC
                                        cowboysdude Module Developer @seramik
                                        @seramik same thing just revert back to another css file…
                                        I have uploaded MMM-NOAA3 - Copy.js file.
                                        Download it and rename it to MMM-NOAA3.js and over write the js file in the MMM-NOAA3 dir, make sure you change your config.js to the css you want to use. That will revert it back.
                                        D 1 Reply Last reply
                                          doogy_rev @cowboysdude
                                          @cowboysdude Awesome thank you!
                                            doogy_rev
                                            I have another question, if the AQI is not available in my area does it default to “Severely Polluted” as shown in my screen capture ^^ . . . I am assuming yes
                                            The only pollution I am in danger of is fresh air and mountains :face_with_tears_of_joy:
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 32 / 35
