V2.10.0 - Impressive...
18 Posts 3 Posters 3.8k Views 3 Watching
    BKeyport Module Developer
    First time EVER I’ve seen this… Great job in squashing vulnerabilities
    “found 0 vulnerabilities”
    smooth as silk upgrade, too.
    S 1 Reply Last reply Jan 2, 2020, 4:39 AM Reply Quote 0
      sdetweil @BKeyport
      @BKeyport how did u do the upgrade?
        git pull && npm install per instructions.
        S 1 Reply Last reply Jan 2, 2020, 12:55 PM Reply Quote 0
          sdetweil @BKeyport
          @BKeyport any reason u didn’t use the upgrade script?
          B 1 Reply Last reply Jan 2, 2020, 1:10 PM Reply Quote 0
            @sdetweil because I read the post, saw “Note: This update uses new dependencies. Please update using the following command: git pull && npm install”, and TL;DR the rest.
            S 1 Reply Last reply Jan 2, 2020, 1:11 PM Reply Quote 0
              sdetweil @BKeyport
              @BKeyport thanks
              B 1 Reply Last reply Jan 2, 2020, 1:15 PM Reply Quote 0
                @sdetweil honestly, I forgot about your script work - twice over… Just recently installed a test install of MM too, and I was gonna use your work - That pi is annoying me a bit, so I may reinstall.
                As I get update notices, I pop on here to make sure I’m gonna do things right, then follow the post instructions after a quick read to confirm.
                S 2 Replies Last reply Jan 2, 2020, 2:00 PM Reply Quote 0
                  sdetweil @BKeyport
                  @BKeyport yeh, I posted updated instructions shortly after Mich posted
                    sdetweil @BKeyport
                    @BKeyport the 2.10 release installer is the updated one, so u won’t miss it anymore!
                      chassain 0
                      hello sdetweil,
                      After your script i have this
                      0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                      0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
                      0|mm | A JavaScript error occurred in the main process
                      0|mm | Uncaught Exception:
                      it’s ok for the new version of magic but no start mm…
                      happy new year
                      S 1 Reply Last reply Jan 2, 2020, 2:32 PM Reply Quote 0
