    V2.10.0 - Impressive...
    18 Posts 3 Posters 4.3k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      First time EVER I’ve seen this… Great job in squashing vulnerabilities
      “found 0 vulnerabilities”
      smooth as silk upgrade, too.
        sdetweil @BKeyport
        @BKeyport how did u do the upgrade?
        • BKeyportB Offline
          git pull && npm install per instructions.
            sdetweil @BKeyport
            @BKeyport any reason u didn’t use the upgrade script?
            • BKeyportB Offline
              @sdetweil because I read the post, saw “Note: This update uses new dependencies. Please update using the following command: git pull && npm install”, and TL;DR the rest.
                sdetweil @BKeyport
                @BKeyport thanks
                • BKeyportB Offline
                  @sdetweil honestly, I forgot about your script work - twice over… Just recently installed a test install of MM too, and I was gonna use your work - That pi is annoying me a bit, so I may reinstall.
                  As I get update notices, I pop on here to make sure I’m gonna do things right, then follow the post instructions after a quick read to confirm.
                    sdetweil @BKeyport
                    @BKeyport yeh, I posted updated instructions shortly after Mich posted
                      sdetweil @BKeyport
                      @BKeyport the 2.10 release installer is the updated one, so u won’t miss it anymore!
                        chassain 0
                        hello sdetweil,
                        After your script i have this
                        0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                        0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
                        0|mm | A JavaScript error occurred in the main process
                        0|mm | Uncaught Exception:
                        it’s ok for the new version of magic but no start mm…
                        happy new year
