    V2.10.0 - Impressive...
    18 Posts 3 Posters 4.4k Views 3 Watching
    • BKeyportB Offline
      @sdetweil because I read the post, saw “Note: This update uses new dependencies. Please update using the following command: git pull && npm install”, and TL;DR the rest.
        sdetweil @BKeyport
        @BKeyport thanks
        • BKeyportB Offline
          @sdetweil honestly, I forgot about your script work - twice over… Just recently installed a test install of MM too, and I was gonna use your work - That pi is annoying me a bit, so I may reinstall.
          As I get update notices, I pop on here to make sure I’m gonna do things right, then follow the post instructions after a quick read to confirm.
            sdetweil @BKeyport
            @BKeyport yeh, I posted updated instructions shortly after Mich posted
              sdetweil @BKeyport
              @BKeyport the 2.10 release installer is the updated one, so u won’t miss it anymore!
                chassain 0
                hello sdetweil,
                After your script i have this
                0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
                0|mm | A JavaScript error occurred in the main process
                0|mm | Uncaught Exception:
                it’s ok for the new version of magic but no start mm…
                happy new year
                  sdetweil @chassain 0
                  @chassain-0 can u post the installers/upgrade.log
                  looks like one of the modules is having trouble…
                  someone else reported a problem with the MMM-PIR-Sensor module…
                    chassain 0
                    i’ve seen the log…a "npm instal"l has resolved this…sorry ! thanks
                      @chassain-0 but the upgrade was supposed to handle this… can I see the log?
                      u have to run the script twice, right? once to test and once to apply
                        chassain 0
                        Upgrade started - jeu. janv. 2 00:47:49 CET 2020
                        system is Linux raspberrypi 4.19.83-v7l+ #1277 SMP Mon Nov 11 16:41:20 GMT 2019 armv7l GNU/Linux
                        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                        user requested to apply changes
                        doing test run = false
                        saving custom.css
                        not english or locale not set, set git alias
                        remote name = origin
                        local version 2.10.0 already same as master 2.10.0
                        restoring custom.css
                        removing git alias
                        Upgrade ended - jeu. janv. 2 00:48:00 CET 2020
                        Upgrade started - jeu. janv. 2 01:12:46 CET 2020
                        doing test run = true
                        saving custom.css
                        upgrading from version 2.10.0 to 2.10.0
                        fetching latest revisions
                        git fetch rc=0
                        current branch = master
                        Sur la branche master
                        Votre branche est à jour avec ‘origin/master’.
                        Modifications qui ne seront pas validées :
                        (utilisez “git add …” pour mettre à jour ce qui sera validé)
                        (utilisez “git checkout – …” pour annuler les modifications dans la copie de travail)
                        modifié :         modules/default/calendar/README.md
                        modifié :         modules/default/weather/README.md
                        modifié :         modules/default/weather/current.njk
                        modifié :         modules/default/weather/providers/README.md
                        modifié :         modules/default/weather/providers/darksky.js
                        modifié :         modules/default/weather/providers/openweathermap.js
                        modifié :         modules/default/weather/providers/ukmetoffice.js
                        modifié :         modules/default/weather/providers/weathergov.js
                        modifié :         modules/default/weather/weatherobject.js
                        Fichiers non suivis:
                        (utilisez “git add …” pour inclure dans ce qui sera validé)
                        %logfile
                        css/customDGA.css
                        css/customHF.css
                        css/customboucherie.css
                        css/customboutique.css
                        css/customdefault
                        css/customhome.css
                        css/customimmo.css
                        css/custommedecin.css
                        css/customsalon.css
                        css/customshoes.css
                        css/save_custom.css
                        installers/dumpactivemodulesoldjs
                        modules/default/calendar/calendaroldjs
                        package-lockoldjson
                        aucune modification n’a été ajoutée à la validation (utilisez “git add” ou “git commit -a”)
                        no files different from github version
                        test merge result rc=‘’ , if empty, no conflicts
                        skipping merge, only test run
                        processing for module MMM-DarkSkyForecast please wait
                        skipped processing for MMM-DarkSkyForecast, doing test run
                        processing complete for module MMM-DarkSkyForecast
                        processing for module mmm-suncalc please wait
                        skipped processing for mmm-suncalc, doing test run
                        processing complete for module mmm-suncalc
                        processing for module MMM-MovieListings please wait
                        skipped processing for MMM-MovieListings, doing test run
                        processing complete for module MMM-MovieListings
                        processing for module MMM-soccer please wait
                        skipped processing for MMM-soccer, doing test run
                        processing complete for module MMM-soccer
                        processing for module MMM-rfacts please wait
                        skipped processing for MMM-rfacts, doing test run
                        processing complete for module MMM-rfacts
                        processing for module MMM-SmartWebDisplay3 please wait
                        skipped processing for MMM-SmartWebDisplay3, doing test run
                        processing complete for module MMM-SmartWebDisplay3
                        processing for module MMM-SmartWebDisplay4 please wait
                        skipped processing for MMM-SmartWebDisplay4, doing test run
                        processing complete for module MMM-SmartWebDisplay4
                        processing for module MMM-SmartWebDisplay please wait
                        skipped processing for MMM-SmartWebDisplay, doing test run
                        processing for module MMM-SmartWebDisplay2 please wait
                        skipped processing for MMM-SmartWebDisplay2, doing test run
                        processing complete for module MMM-SmartWebDisplay2
                        processing for module MMM-pages please wait
                        skipped processing for MMM-pages, doing test run
                        processing complete for module MMM-pages
                        removing git alias
                        Upgrade ended - jeu. janv. 2 01:12:49 CET 2020
                        Upgrade started - jeu. janv. 2 01:13:07 CET 2020
                        saving custom.css
                        removing git alias
                        Upgrade ended - jeu. janv. 2 01:13:07 CET 2020
