V2.10.0 - Impressive...
18 Posts 3 Posters 3.7k Views 3 Watching
    sdetweil @BKeyport
    @BKeyport how did u do the upgrade?
      BKeyport Module Developer
      git pull && npm install per instructions.
      S 1 Reply Last reply Jan 2, 2020, 12:55 PM Reply Quote 0
        sdetweil @BKeyport
        @BKeyport any reason u didn’t use the upgrade script?
        B 1 Reply Last reply Jan 2, 2020, 1:10 PM Reply Quote 0
          @sdetweil because I read the post, saw “Note: This update uses new dependencies. Please update using the following command: git pull && npm install”, and TL;DR the rest.
          S 1 Reply Last reply Jan 2, 2020, 1:11 PM Reply Quote 0
            sdetweil @BKeyport
            @BKeyport thanks
            B 1 Reply Last reply Jan 2, 2020, 1:15 PM Reply Quote 0
              @sdetweil honestly, I forgot about your script work - twice over… Just recently installed a test install of MM too, and I was gonna use your work - That pi is annoying me a bit, so I may reinstall.
              As I get update notices, I pop on here to make sure I’m gonna do things right, then follow the post instructions after a quick read to confirm.
              S 2 Replies Last reply Jan 2, 2020, 2:00 PM Reply Quote 0
                sdetweil @BKeyport
                @BKeyport yeh, I posted updated instructions shortly after Mich posted
                  sdetweil @BKeyport
                  @BKeyport the 2.10 release installer is the updated one, so u won’t miss it anymore!
                    chassain 0
                    hello sdetweil,
                    After your script i have this
                    0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                    0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
                    0|mm | A JavaScript error occurred in the main process
                    0|mm | Uncaught Exception:
                    it’s ok for the new version of magic but no start mm…
                    happy new year
                    S 1 Reply Last reply Jan 2, 2020, 2:32 PM Reply Quote 0
                      sdetweil @chassain 0
                      @chassain-0 can u post the installers/upgrade.log
                      looks like one of the modules is having trouble…
                      someone else reported a problem with the MMM-PIR-Sensor module…
