Use npm for module installs
Do you guys think it would be possible to use npm for installing modules? This forum software can do it, so it has to be possible somehow.
The biggest issue is that you can specifically mention where to install modules.
By the way, when MM2 is stable, it will be available for installation using
npm install magic mirror
@MichMich the forum also installs it’s modules into node_modules but it still somehow manages to find them and let the user activate them
@paviro Yes, but that doesn’t mean they are in a specific folder. That would mean all modules will be installed in
~/MagicMirror/modules/node_modules/.
- I don’t think that is what we want. -
That’s correct but would that be a real problem?
@paviro Yes,it has to big of an impact on the file structure. This would require a lot of rewriting. (And besides that, it’s extremely ugly :))
I agree on the ugly part your are right I guess, would just be easier for the users but probably not enough to be worth it.
It’s not that it’s not worth it. It’s just not cleanest solution.
if it could be possible to build a Management Interface like iobroker (www.iobroker.org), it would be much more comfortable to use. Good node update und plugin design.
