Use npm for module installs
Scheduled Pinned Locked Moved Feature Requests
16 Posts 6 Posters 9.9k Views 4 Watching
    MichMich Admin @paviro
    @paviro Yes, but that doesn’t mean they are in a specific folder. That would mean all modules will be installed in ~/MagicMirror/modules/node_modules/. - I don’t think that is what we want.
      paviro Admin
      That’s correct but would that be a real problem?
      – The Doctor
      M 1 Reply Last reply May 3, 2016, 12:03 PM Reply Quote 0
        @paviro Yes,it has to big of an impact on the file structure. This would require a lot of rewriting. (And besides that, it’s extremely ugly :))
          paviro Admin
          I agree on the ugly part :D your are right I guess, would just be easier for the users :) but probably not enough to be worth it.
          – The Doctor
            MichMich Admin
            It’s not that it’s not worth it. It’s just not cleanest solution.
            • N Offline
              nogE
              if it could be possible to build a Management Interface like iobroker (www.iobroker.org), it would be much more comfortable to use. Good node update und plugin design.
                Beh
                I’d really like to see some kind of ‘package manager’ for all the mirror modules. A more or less centralized solution for this would be great.
                But I agree with @MichMich that npm is not really the solution for that.
                B 1 Reply Last reply Apr 29, 2017, 7:38 AM Reply Quote 0
                  broberg Project Sponsor @Beh
                  @Beh Maybe a setup page for the MM config file,
                  basically just a script that runs just like the MM page (maybe could be started with npm start config?)
                  where you could access a list of modules (retrieved from an “official” module list that has the right format),
                  And when the module is selected and “install” is clicked the page does the git clone process, npm install and adds the configuration fields to the config.js file according to the instructions gotten from the module list. (all default settings except for location which the user should select before he is able to install the module).
                  Since the format of the config for all modules are more or less the same it shouldn’t be that difficult to have the page retrieve the different config variables from the modules and display it in a more userfriendly way (ie input fields on a html page instead of sorting out the “code”).
                  Because let’s face it, most of the “troubleshooting” for new users are config file related errors (a comma missing or using wrong quotation marks, placing the module code outside the module list etc etc)
                  Shouch a solution would probably not require a rewrite of any MM base code, it would just be a standalone addition.
                  But it would require a compatible modules list with a strict format.
                  S 1 Reply Last reply Apr 29, 2017, 7:48 AM Reply Quote 1
                    strawberry 3.141 Project Sponsor Module Developer @broberg
                    @broberg so whats the difference on what you described to the remote module?
                    B 1 Reply Last reply Apr 29, 2017, 10:22 AM Reply Quote 0
                      broberg Project Sponsor @strawberry 3.141
                      @strawberry-3.141 I have no bloody idea, haven’t tried the remote module.
                      but first off, not remote, second it could fetch a list (database) of modules and execute the git clone commands directly. or is that included in the remote as well?
                      S 1 Reply Last reply Apr 29, 2017, 11:09 AM Reply Quote 0
