MMM-Fuel
@sdetweil same results without sudo
@Stefan_TR96 yes, does mm run? Do you get output?
@sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
@Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
You can filter by module, by placing part of the module name in the filter field. -
is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
I just released version 2.0.2
Added
- French Translations
- Clarification for config option
updateInterval
in readme
Changed
- Dependency Update
Removed
- Github pages
https://github.com/fewieden/MMM-fuel
[card:fewieden/MMM-Fuel]
@strawberry-3-141 Hi,
is there a way to hide the distance?
Can you tell me where I can comment that out?Thank you for your help.
greeting
Stefan -
@Cetax add this in your custom.css file at
~/MagicMirror/css/custom.css
.MMM-Fuel th:nth-child(3), .MMM-Fuel td:nth-child(3) { display: none; }
@strawberry-3-141 said in MMM-Fuel:
display: none;
}Yeah… :ok_hand:
thank u very much… Thats cool :thumbs_up: -
The map modal was broken for quite some time, I managed to make it work again and switched to MMM-Modal at the same time.
[2.1.0]
Changed
- Using MMM-Modal to display modals like gas station and voice commands.
https://github.com/fewieden/MMM-Fuel
