    Eeepc instead of raspberry
    7 Posts 4 Posters 1.8k Views 3 Watching
      pnobrega @broberg
      @broberg that’s what I was thinking.
      Thanks for the confirmation
        sdetweil @pnobrega
        @pnobrega use the installer script , see here
          Mykle1 Project Sponsor Module Developer @pnobrega
          @pnobrega said in Eeepc instead of raspberry:
          I have a eeepc
          Use it! You won’t be sorry. I’ve done this with an EeePC about a year ago. The EeePC outperforms any Pi in all aspects. Will you miss the GPIO? Maybe, but the benefits you gain from using the EeePC far outweigh any loss of a GPIO in my opinion
          that runs nicely Linux.
          You don’t need Raspian at all. I am strictly an Ubuntu guy where MM is concerned. I’ve made quite a few MM gifts using laptop boards, Mac and PC. The issues that arise from using a Pi don’t materialize.
          Here’s my EeePC Alarm Clock - https://forum.magicmirror.builders/topic/8640/11-alarm-clock-using-mm-and-hello-lucy
          Here’s my MacMirror - https://forum.magicmirror.builders/topic/6376/macmirror
          Goog luck and keep me posted.
            pnobrega @Mykle1
            @Mykle1 thanks. I’ve seen you post :)
            I went for lubuntu based on 16.0.4 like you suggested there.
            MM is already running, the basics… Now i’m trying to get assistant and other perks to work… so far so good…
            Gonna se if I can do everything I want with just the PS eye camera :)
              I went for ubuntu based on 16.0.4
              16.04 was the most current when I started so I stayed with it. In fact, I’m still running 16.04 on my dev machine. The most current(stable) would work just as well, I’m sure. They’ve made some UI changes that I wasn’t thrilled about but that is not an issue.
              I would suggest staying with the integrated microphone, or an analog microphone if you are going to be using any voice control. Assuming the PS cam is USB, you’d be introducing a bunch of latency that you won’t be happy with. Certainly, use the cam for cam duty.
