    MMM-MyGarbage
    62 Posts 28 Posters 53.2k Views 30 Watching
    • W Offline
      werffje
      OMG I’m such a noob forgive me, I forgot the alert: 4 line in my config.js
      It works great now, thanks !!
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH Offline
        htilburgs @werffje
        @werffje :thumbs_up_light_skin_tone:
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          rvanuden
          best module ever :-)
            htilburgs @rvanuden
            @rvanuden :hugging_face: :thumbs_up_light_skin_tone:
              RdP
              We have 4 garbage bins. (Green,Black, Bleu and Yellow), is it possible to use 4 types instead of 3?
                htilburgs @RdP
                @RdP
                You can use this module by creating your own Garbage Schedule file with the name garbage_schedule.csv An example file garbage_schedule.csv is added.
                Create a CSV based on the following template:
                WeekStarting,green,gray,blue
                03/07/18,1,0,1
                03/14/18,1,1,1
                03/21/18,1,0,1
                03/28/18,1,1,1
                Default there are 3 bins defined (green, gray and blue) If you need more garbage bins, simply add an extra column in the garbage_schedule.csv file. The name is the color you like the bin to have. In you case ‘yellow’.
                Add lines for each garbage pickup date as needed. The date format needs to be specified as MM/DD/YY (e.g.: 05/28/18 for 28-May-2018)
                Succes!
                  RdP @htilburgs
                  @htilburgs
                  Yes works like a charm…
                  Thank you
                    htilburgs @RdP
                    @RdP, great it worked out for you!
                    • twosquirrelsT Offline
                      twosquirrels
                      This is great! It’s since replaced MMM-MyWastePickup as that no longer works .
                        mistered
                        Hi guys i know this is an old topic but maybe i can get an answer anayway
                        i want 4 bins but just adding a color and and a 1 or 0 in the csv file does not work
                          mistered
                          ok got it to work now
                          • K Offline
                            kalin
                            Hello guys!
                            could anyone help and check what is wrong with my configuration of this module? Under the title I have only message: loading
                            My configuration looks like:
                            module: ‘MMM-MyGarbage’,
                            position: ‘bottom_left’,
                            header: ‘My Garbage Calendar’,
                            alert: 3,
                            weeksToDisplay: 2,
                            limitTo: 99,
                            fade: true,
                            dateFormat: “dddd”,
                            fadePoint: 0.25
                              ReD1470
                              Hey there,
                              Great work on this module. But you say you are not an experienced programmer? well, compared to me…
                              not to sound lazy, but any change you could convert from csv to json query like thingy?
                              as seen on the home automation sites, people query http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=&street=&huisnummer=&toevoeging=&platform=phone&langs=nl&
                              and get the results needed
                              (https://community.home-assistant.io/t/garbage-pickup-date-mijnafvalwijzer-nl-custom-component/34631/12)
                              please be honest, no is also an answer and I would completely understand.
                              … but i thought you might like a challenge ;-)
                              • L Offline
                                lodam @htilburgs
                                @htilburgs : thanks a lot for this module !
                                this is super useful and well done.
                                I would like to change color for bins, i did the custom.css file and restarted MM2 but that does not change.
                                Do i have to do something else ?
                                thanks a lot for your help.
                                Here you can file a translation for French if this could help :
                                “GARBAGEENTRIESLEFT”: “Il reste {entriesLeft} dates dans le calendrier des ordures”,
                                “REMEMBERADDINGPICKUPS”: “Veuillez ajouter de nouvelles dates pour l’utiliser”
                                REBR 1 Reply Last reply Reply Quote 0
                                • REBR Offline
                                  REB @lodam
                                  @lodam said in MMM-MyGarbage:
                                  You can change the colour of the bin icons in the garbage_schedule.csv file like so. The top row defines the colour of the icons. In my case below they are green, dark grey and light blue.
                                  WeekStarting,#00FF00,#D3D3D3,#87CEEB
                                  03/31/20,0,0,1
                                  04/07/20,0,1,0
                                  04/14/20,0,0,1
                                  04/21/20,0,1,0
                                  04/28/20,0,0,1
                                  05/05/20,0,1,0
                                  • L Offline
                                    lodam
                                    thanks for your help @REB but in my case, i have
                                    "WeekStarting,GreenBin, GarbageBin, Paperbin,
                                    So i guess i have to change that somewhere else ;)
                                    • L Offline
                                      lodam
                                      oups so sorry, i misunderstood…
                                      You are 100% right, i just changed and did the same as you did.
                                      thanks a lot !
                                        Sezer84
                                        Hallo leute ,ich weiss das ist ziemlich alt das thema aber ich habe es jetzt erst endeckt.
                                        ich habe dieses modul installiert wie es beschrieben wurde aber es zeigte erst nur eine tonne und heute zeigt er zwei. und die farbe gelb ,orange, blau und braun brächte ich für deutschland.wie kriege ich es hin vier tonnen in den gewünschten farben hinzukriegen.
                                        bedanke mich im vorraus.
                                        Feedy88F 1 Reply Last reply Reply Quote 0
                                        • Feedy88F Offline
                                          Feedy88 @Sezer84
                                          @Sezer84
                                          Öffne deine garbage_shedule.csv und ersetze die Farben in der Kopfzeile, entweder durch andere Farben oder durch Hex-Codes. Für Gelb und Blau finde ich die Standardwerte gut, für Braun habe ich den code genommen: #663300. Orange nutze ich nicht, statt dessen Grau mit Codierung #7d7d7d.
                                          Die Hex-Codes kannst du hier finden. Einfach ne Farbe aussuchen und den Wert mit der # Aufschreiben. Die CSV sollte am Ende dann so ähnlich aussehen:
                                          WeekStarting,#7d7d7d,yellow,#663300,blue
                                          07/20/20,1,1,0,0
                                          07/27/20,0,0,1,1
                                          08/03/20,1,1,0,0
                                          VG
                                          • Feedy88F Offline
                                            Feedy88
                                            Guys, I would need some help with this module. I understood that currently the Trash-Icon is hard-coded in the module folder and embedded into the JS. I would like to know if it is possible to add a second (potentially third) icon which shall be used. Background: In my city we have Pickup always on the same Weekday, unless there is s a bank holiday. For this instances I would like to add a red exclamation mark to the pickup row. I can work with a red Trash Icon as a quick fix but would be great to find a neater solution.
                                            Thanks in advance.
                                            • 2 / 4
