    MMM-MyGarbage
    62 Posts 28 Posters 55.4k Views 30 Watching
    • twosquirrelsT
      twosquirrels
      This is great! It’s since replaced MMM-MyWastePickup as that no longer works .
        mistered
        Hi guys i know this is an old topic but maybe i can get an answer anayway
        i want 4 bins but just adding a color and and a 1 or 0 in the csv file does not work
          mistered
          ok got it to work now
          • K
            kalin
            Hello guys!
            could anyone help and check what is wrong with my configuration of this module? Under the title I have only message: loading
            My configuration looks like:
            module: ‘MMM-MyGarbage’,
            position: ‘bottom_left’,
            header: ‘My Garbage Calendar’,
            alert: 3,
            weeksToDisplay: 2,
            limitTo: 99,
            fade: true,
            dateFormat: “dddd”,
            fadePoint: 0.25
              ReD1470
              Hey there,
              Great work on this module. But you say you are not an experienced programmer? well, compared to me…
              not to sound lazy, but any change you could convert from csv to json query like thingy?
              as seen on the home automation sites, people query http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=&street=&huisnummer=&toevoeging=&platform=phone&langs=nl&
              and get the results needed
              (https://community.home-assistant.io/t/garbage-pickup-date-mijnafvalwijzer-nl-custom-component/34631/12)
              please be honest, no is also an answer and I would completely understand.
              … but i thought you might like a challenge ;-)
              • L
                lodam @htilburgs
                @htilburgs : thanks a lot for this module !
                this is super useful and well done.
                I would like to change color for bins, i did the custom.css file and restarted MM2 but that does not change.
                Do i have to do something else ?
                thanks a lot for your help.
                Here you can file a translation for French if this could help :
                “GARBAGEENTRIESLEFT”: “Il reste {entriesLeft} dates dans le calendrier des ordures”,
                “REMEMBERADDINGPICKUPS”: “Veuillez ajouter de nouvelles dates pour l’utiliser”
                REBR 1 Reply Last reply Reply Quote 0
                • REBR
                  REB @lodam
                  @lodam said in MMM-MyGarbage:
                  You can change the colour of the bin icons in the garbage_schedule.csv file like so. The top row defines the colour of the icons. In my case below they are green, dark grey and light blue.
                  WeekStarting,#00FF00,#D3D3D3,#87CEEB
                  03/31/20,0,0,1
                  04/07/20,0,1,0
                  04/14/20,0,0,1
                  04/21/20,0,1,0
                  04/28/20,0,0,1
                  05/05/20,0,1,0
                  • L
                    lodam
                    thanks for your help @REB but in my case, i have
                    "WeekStarting,GreenBin, GarbageBin, Paperbin,
                    So i guess i have to change that somewhere else ;)
                    • L
                      lodam
                      oups so sorry, i misunderstood…
                      You are 100% right, i just changed and did the same as you did.
                      thanks a lot !
                        Sezer84
                        Hallo leute ,ich weiss das ist ziemlich alt das thema aber ich habe es jetzt erst endeckt.
                        ich habe dieses modul installiert wie es beschrieben wurde aber es zeigte erst nur eine tonne und heute zeigt er zwei. und die farbe gelb ,orange, blau und braun brächte ich für deutschland.wie kriege ich es hin vier tonnen in den gewünschten farben hinzukriegen.
                        bedanke mich im vorraus.
                        Feedy88F 1 Reply Last reply Reply Quote 0
                        • Feedy88F
                          Feedy88 @Sezer84
                          @Sezer84
                          Öffne deine garbage_shedule.csv und ersetze die Farben in der Kopfzeile, entweder durch andere Farben oder durch Hex-Codes. Für Gelb und Blau finde ich die Standardwerte gut, für Braun habe ich den code genommen: #663300. Orange nutze ich nicht, statt dessen Grau mit Codierung #7d7d7d.
                          Die Hex-Codes kannst du hier finden. Einfach ne Farbe aussuchen und den Wert mit der # Aufschreiben. Die CSV sollte am Ende dann so ähnlich aussehen:
                          WeekStarting,#7d7d7d,yellow,#663300,blue
                          07/20/20,1,1,0,0
                          07/27/20,0,0,1,1
                          08/03/20,1,1,0,0
                          VG
                          • Feedy88F
                            Feedy88
                            Guys, I would need some help with this module. I understood that currently the Trash-Icon is hard-coded in the module folder and embedded into the JS. I would like to know if it is possible to add a second (potentially third) icon which shall be used. Background: In my city we have Pickup always on the same Weekday, unless there is s a bank holiday. For this instances I would like to add a red exclamation mark to the pickup row. I can work with a red Trash Icon as a quick fix but would be great to find a neater solution.
                            Thanks in advance.
                              Cetax
                              Hi, is it possible to integrate the module into the standard calendar, which is on the top left?
                              I have both of my google calendars there and do not want a second view.
                              I hope I understand what I mean …
                              greeting
                              Stefan
                              • Feedy88F
                                Feedy88
                                @Cetax
                                it is not possible to integrate the module right away. What you can do, is to create a local ical file, store in on your device running the magic mirror and call if via localhost. However, this would only help you to display the day of pickup, no different colors for what bins are being picked up.
                                  rkvant
                                  Hello. I only get “loading” on my MagicMirror. When I start up I get this error. Im a beginner and have no clue what’s wrong. Hope someone can help me:)
                                  [2020-11-25 15:42:57.385] [ERROR] CsvError: Invalid Record Length: header length is 4, got 1 on line 58
                                  at Parser.__onRow (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_modules/csv-parse/lib/index.js:636:15)
                                  at Parser.__parse (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_modules/csv-parse/lib/index.js:527:40)
                                  at Parser._flush (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_modules/csv-parse/lib/index.js:352:22)
                                  at Parser.prefinish (_stream_transform.js:140:10)
                                  at Parser.emit (events.js:200:13)
                                  at prefinish (_stream_writable.js:633:14)
                                  at finishMaybe (_stream_writable.js:641:5)
                                  at endWritable (_stream_writable.js:661:3)
                                  at Parser.Writable.end (_stream_writable.js:592:5)
                                  at parse (/home/pi/MagicMirror/modules/MMM-MyGarbage/node_modules/csv-parse/lib/index.js:946:12) {
                                  code: ‘CSV_INVALID_RECORD_LENGTH_DONT_MATCH_COLUMNS’,
                                  column: ‘#FFFF00’,
                                  empty_lines: 0,
                                  header: false,
                                  index: 1,
                                  invalid_field_length: 0,
                                  quoting: false,
                                  lines: 58,
                                  records: 56,
                                  record: [ ‘’ ]
                                  JerryPJ 1 Reply Last reply Reply Quote 0
                                    crush
                                    Hello folks, this tool (module) works great for two month. Last week i did an update on a different module (MMM-Remote-Control) and since then MMM-MyGarbage isn’t working anymore. I tried a fresh install but it only shows “Lade …” (Loading …). Anybody a solution?
                                    • SandrikS
                                      Sandrik
                                      Hi there! The Download Link doesn´t work for me, where can i get the Module?
                                      • JerryPJ
                                        JerryP @Sandrik
                                        @Sandrik
                                        https://github.com/htilburgs/MMM-MyGarbage
                                        • JerryPJ
                                          JerryP @rkvant
                                          @rkvant
                                          edit: /home/pi/MagicMirror/modules/MMM-MyGarbage/garbage_schedule.csv
                                          your must edit i’t on de mirror self. not bij Excel or notepad
                                          and i’t looks like this
                                          WeekStarting,green,gray,blue,orange
                                          11/18/20,0,1,0,1
                                          11/25/20,1,0,0,0
                                          12/02/20,0,1,0,0
                                          12/09/20,1,0,0,0
                                          12/16/20,0,1,0,1
                                          12/23/20,1,0,0,0
                                          12/30/20,0,1,0,0
                                          01/06/21,1,0,0,0
                                          01/13/21,0,1,0,1
                                          01/20/21,1,0,0,0
                                          01/27/21,0,1,0,0
                                          02/03/21,1,0,0,0
                                          02/10/21,0,1,0,1
                                          02/17/21,1,0,0,0
                                          I’m from holland so sorry for my bad English
                                          • L
                                            levente82 @crush
                                            @crush , same problem here. I don’t know if the MMM-Remote-Control module is the problem or not, but i made everything according to description and the module always showing “Loading…”.
                                            • 2 / 4
