    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 125.1k Views 27 Watching
    • cowboysdudeC
      cowboysdude Module Developer @Guest
      @wjdw87 said in MMM-Instagram - Pull and animate photos from Instagram feed:
      How do you get it to show in a browser??
      restart your mirror like this:
      npm start dev
        A Former User
        cool thanks
        • cowboysdudeC
          @wjdw87 You’re welcome :) NOW if he can solve the problem it’ll work! :)
          • K
            kapsolas Module Developer
            Hmm. that tempimpage variable is not found in my code.
            Did you modify the code at all? The code should look as below. In the error message it shows tempimpage which is not a valid variable. This would cause the script to not work.
               var tempimage = this.images.photo[this.activeItem];
                // image
                var imageLink = document.createElement('div');
                imageLink.id = "MMM-Instagram-image";
                imageLink.innerHTML = "<img src='" + tempimage.photolink + "'>";
                imageDisplay.appendChild(imageLink);
                wrapper.appendChild(imageDisplay);
            cowboysdudeC ? 2 Replies Last reply Reply Quote 0
            • cowboysdudeC
              cowboysdude Module Developer @kapsolas
              @kapsolas no didn’t modify. So what I’ll do is delete what’s there and recopy it since I already did the npm install.
              Thank you!! 😊
                A Former User @kapsolas
                @kapsolas Where is this “added code” that needs to be removed, sorry missed that.
                  A Former User
                  Remove " + tempimage.photolink + “'>”" ?
                  /* global Module */
                  /* Magic Mirror
                  • Module: MMM-Instagram
                  • By Jim Kapsalis https://github.com/kapsolas
                  • MIT Licensed.
                  Module.register(‘MMM-Instagram’, {
                  defaults: {
                      format: 'json',
                      lang: 'en-us',
                      animationSpeed: 1000,
                      updateInterval: 60000, // 10 minutes
                      access_token: '',
                      count: 200,
                      min_timestamp: 0,
                      loadingText: 'Loading...'
                  // Define required scripts
                  getScripts: function() {
                      return ["moment.js"];
                  // Define required translations
                  getTranslations: function() {
                      return false;
                  // Define start sequence
                  start: function() {
                      Log.info('Starting module: ' + this.name);
                      this.data.classes = 'bright medium';
                      this.loaded = false;
                      this.images = {};
                      this.activeItem = 0;
                      this.url = 'https://api.instagram.com/v1/users/self/media/recent' + this.getParams();
                      this.grabPhotos();
                  grabPhotos: function() {
                      // the notifications are not working for some reason... so we won't do anything asynchronously
                      // we will just make the call to the method to get the object with photo links....
                      //Log.info('sending socket notification: INSTAGRAM_GET and URL: ' + this.url);
                      this.sendSocketNotification("INSTAGRAM_GET", this.url);
                      // this may not be needed... need to think about it.
                      //setTimeout(this.grabPhotos, this.config.interval, this);
                  getStyles: function() {
                      return ['instagram.css', 'font-awesome.css'];
                  // Override the dom generator
                  getDom: function() {
                      var imageDisplay = document.createElement('div'); //support for config.changeColor
                      if (!this.loaded) {
                          wrapper.innerHTML = this.config.loadingText;
                          return wrapper;
                      // set the first item in the list...
                      if (this.activeItem >= this.images.photo.length) {
                      // image
                      return wrapper;
                  /* scheduleUpdateInterval()
                   * Schedule visual update.
                  scheduleUpdateInterval: function() {
                      var self = this;
                      Log.info("Scheduled update interval set up...");
                      self.updateDom(self.config.animationSpeed);
                      setInterval(function() {
                          Log.info("incrementing the activeItem and refreshing");
                          self.activeItem++;
                      }, this.config.updateInterval);
                   * getParams()
                   * returns the query string required for the request to flickr to get the
                   * photo stream of the user requested
                  getParams: function() {
                      var params = '?';
                      params += 'count=' + this.config.count;
                      params += '&min_timestamp=' + this.config.min_timestamp;
                      params += '&access_token=' + this.config.access_token;
                      return params;
                  // override socketNotificationReceived
                      //Log.info('socketNotificationReceived: ' + notification);
                      if (notification === 'INSTAGRAM_IMAGE_LIST')
                          //Log.info('received INSTAGRAM_IMAGE_LIST');
                          this.images = payload;
                          //Log.info("count: " +  this.images.photo.length);
                          // we want to update the dom the first time and then schedule next updates
                          if (!this.loaded) {
                          this.updateDom(1000);
                              this.scheduleUpdateInterval();
                          this.loaded = true;
                    A Former User
                    • K
                      kapsolas Module Developer @Guest
                      @wjdw87 Based on the code you have provided above, it looks correct. It does not have the tempimpage anywhere.
                      I did not ask you to delete any code, but somehow the code you were running had tempimage misspelled to tempimpage.
                      The messages you are showing in the screenshot, are from the core system, but does show that the instagram feed module is running. So there is something else.
                      To confirm:
                      1. You cloned the module from github
                      2. You generated a token for instragram
                      3. Configured the config.js file, configuration for the module appropriately
                      • cowboysdudeC
                        I’m all good… I have NO idea where I got that version from but I copied over your original and it fired up…
                        Thank you!
                        I believe that version is yoless fork… someone wanted the ability to adjust width and height… which is not a bad idea … ;)
                        • K
                          Awesome! Glad to hear we got it all set up! Enjoy the module!
                          • cowboysdudeC
                            @kapsolas said in MMM-Instagram - Pull and animate photos from Instagram feed:
                            I really do! Thanks for all your hard work!
                              A Former User
                              Hmm… from here : https://github.com/kapsolas/MMM-Instagram
                              Do you have to install : https://www.npmjs.com/package/request - How?
                              To confirm:
                              You cloned the module from github - YES
                              You generated a token for instragram - YES
                              Configured the config.js file, configuration for the module appropriately - YES
                              reply
                              strawberry 3.141S cowboysdudeC 2 Replies Last reply Reply Quote 0
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @Guest
                                @wjdw87
                                cd ~/MagicMirror/modules/MMM-Instagram
                                npm install
                                • cowboysdudeC
                                  To confirm:
                                  reply
                                  OH that’s the easy part ;)
                                  In the terminal window [the one you type in ‘npm start’ to start the mirror]… go to the modules dir then the MMM-Instagram dir
                                  type in without quotes “npm install”
                                  Once that’s finished go back to the MagicMirror and start your mirror :)
                                    A Former User
                                    Many Thanks @cowboysdude , @strawberry-3-141
                                    I just did a fresh install oof the module, then the dependency.
                                    Still no luck :( 0_1477600708301_Screenshot 2016-10-28 03.37.16.png
                                    • cowboysdudeC
                                      @wjdw87
                                      Ok hang in there kid… just about there…
                                        A Former User
                                          A Former User
                                          I guess for security can change the API key once i’m all up and running :) - many thanks @cowboysdude !
                                          • K
                                            Just an FYI - You do not want to just post your config to the world.
                                            That access token can allow someone to impersonate you now! The config.js contains confidential information for accessing the services our mirrors are using. Refrain from publishing it to the world with out redacting the app ids.
                                            ? 1 Reply Last reply Reply Quote 2
                                            • 2 / 5
