    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 126.0k Views 27 Watching
      A Former User @cowboysdude
      @cowboysdude said in MMM-Instagram - Pull and animate photos from Instagram feed:
      Well we’re certainly glad it worked for you…however…
      module: ‘MMM-Instagram’,
      position: ‘top_right’,
      access_token: ‘API_KEY from instagram’,
      count: 200,
      min_timestamp: 0,
      animationSpeed: 2500,
      updateInterval: 12500
      Replaced ‘API_KEY …’
      and followed all directions and it still sits there and says “Loading…”…
      Same
      • K
        kapsolas Module Developer
        What are you guys seeing in the console log? If you are not anything… then I will have to send you a version of the module with debug comments in it to see where the issue is.
        FYI - I had a similar issue with the Module for Traffic and never solved it. It just sat on Loading…
        • cowboysdudeC
          cowboysdude Module Developer @kapsolas
          @kapsolas Well gosh darn it LOL SOLVE IT MAN! Lives are hangin in the balance…
          No I have run it in dev mode and I see or get no errors… so perhaps using a version with debug would be best :)
          • cowboysdudeC
            OH I stand corrected… here’s an error:
              A Former User
              How do you get it to show in a browser??
              • cowboysdudeC
                cowboysdude Module Developer @Guest
                @wjdw87 said in MMM-Instagram - Pull and animate photos from Instagram feed:
                restart your mirror like this:
                npm start dev
                  A Former User
                  cool thanks
                  • cowboysdudeC
                    @wjdw87 You’re welcome :) NOW if he can solve the problem it’ll work! :)
                    • K
                      Hmm. that tempimpage variable is not found in my code.
                      Did you modify the code at all? The code should look as below. In the error message it shows tempimpage which is not a valid variable. This would cause the script to not work.
                         var tempimage = this.images.photo[this.activeItem];
                          // image
                          var imageLink = document.createElement('div');
                          imageLink.id = "MMM-Instagram-image";
                          imageLink.innerHTML = "<img src='" + tempimage.photolink + "'>";
                          imageDisplay.appendChild(imageLink);
                          wrapper.appendChild(imageDisplay);
                      cowboysdudeC ? 2 Replies Last reply
                      • cowboysdudeC
                        @kapsolas no didn’t modify. So what I’ll do is delete what’s there and recopy it since I already did the npm install.
                        Thank you!! 😊
                          A Former User @kapsolas
                          @kapsolas Where is this “added code” that needs to be removed, sorry missed that.
                            A Former User
                            Remove " + tempimage.photolink + “'>”" ?
                            /* global Module */
                            /* Magic Mirror
                            • Module: MMM-Instagram
                            • By Jim Kapsalis https://github.com/kapsolas
                            • MIT Licensed.
                            Module.register(‘MMM-Instagram’, {
                            defaults: {
                                format: 'json',
                                lang: 'en-us',
                                animationSpeed: 1000,
                                updateInterval: 60000, // 10 minutes
                                access_token: '',
                                count: 200,
                                min_timestamp: 0,
                                loadingText: 'Loading...'
                            // Define required scripts
                            getScripts: function() {
                                return ["moment.js"];
                            // Define required translations
                            getTranslations: function() {
                                return false;
                            // Define start sequence
                            start: function() {
                                Log.info('Starting module: ' + this.name);
                                this.data.classes = 'bright medium';
                                this.loaded = false;
                                this.images = {};
                                this.activeItem = 0;
                                this.url = 'https://api.instagram.com/v1/users/self/media/recent' + this.getParams();
                                this.grabPhotos();
                            grabPhotos: function() {
                                // the notifications are not working for some reason... so we won't do anything asynchronously
                                // we will just make the call to the method to get the object with photo links....
                                //Log.info('sending socket notification: INSTAGRAM_GET and URL: ' + this.url);
                                this.sendSocketNotification("INSTAGRAM_GET", this.url);
                                // this may not be needed... need to think about it.
                                //setTimeout(this.grabPhotos, this.config.interval, this);
                            getStyles: function() {
                                return ['instagram.css', 'font-awesome.css'];
                            // Override the dom generator
                            getDom: function() {
                                var imageDisplay = document.createElement('div'); //support for config.changeColor
                                if (!this.loaded) {
                                    wrapper.innerHTML = this.config.loadingText;
                                    return wrapper;
                                // set the first item in the list...
                                if (this.activeItem >= this.images.photo.length) {
                                // image
                                return wrapper;
                            /* scheduleUpdateInterval()
                             * Schedule visual update.
                            scheduleUpdateInterval: function() {
                                var self = this;
                                Log.info("Scheduled update interval set up...");
                                self.updateDom(self.config.animationSpeed);
                                setInterval(function() {
                                    Log.info("incrementing the activeItem and refreshing");
                                    self.activeItem++;
                                }, this.config.updateInterval);
                             * getParams()
                             * returns the query string required for the request to flickr to get the
                             * photo stream of the user requested
                            getParams: function() {
                                var params = '?';
                                params += 'count=' + this.config.count;
                                params += '&min_timestamp=' + this.config.min_timestamp;
                                params += '&access_token=' + this.config.access_token;
                                return params;
                            // override socketNotificationReceived
                                //Log.info('socketNotificationReceived: ' + notification);
                                if (notification === 'INSTAGRAM_IMAGE_LIST')
                                    //Log.info('received INSTAGRAM_IMAGE_LIST');
                                    this.images = payload;
                                    //Log.info("count: " +  this.images.photo.length);
                                    // we want to update the dom the first time and then schedule next updates
                                    if (!this.loaded) {
                                    this.updateDom(1000);
                                        this.scheduleUpdateInterval();
                                    this.loaded = true;
                              A Former User
                              K 1 Reply Last reply
                              • K
                                kapsolas Module Developer @Guest
                                @wjdw87 Based on the code you have provided above, it looks correct. It does not have the tempimpage anywhere.
                                I did not ask you to delete any code, but somehow the code you were running had tempimage misspelled to tempimpage.
                                The messages you are showing in the screenshot, are from the core system, but does show that the instagram feed module is running. So there is something else.
                                To confirm:
                                1. You cloned the module from github
                                2. You generated a token for instragram
                                3. Configured the config.js file, configuration for the module appropriately
                                • cowboysdudeC
                                  I’m all good… I have NO idea where I got that version from but I copied over your original and it fired up…
                                  Thank you!
                                  I believe that version is yoless fork… someone wanted the ability to adjust width and height… which is not a bad idea … ;)
                                  • K
                                    Awesome! Glad to hear we got it all set up! Enjoy the module!
                                    • cowboysdudeC
                                      @kapsolas said in MMM-Instagram - Pull and animate photos from Instagram feed:
                                      I really do! Thanks for all your hard work!
                                        A Former User
                                        Hmm… from here : https://github.com/kapsolas/MMM-Instagram
                                        Do you have to install : https://www.npmjs.com/package/request - How?
                                        To confirm:
                                        You cloned the module from github - YES
                                        You generated a token for instragram - YES
                                        Configured the config.js file, configuration for the module appropriately - YES
                                        reply
                                        strawberry 3.141S cowboysdudeC 2 Replies Last reply
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @Guest
                                          @wjdw87
                                          cd ~/MagicMirror/modules/MMM-Instagram
                                          npm install
                                          • cowboysdudeC
                                            To confirm:
                                            reply
                                            OH that’s the easy part ;)
                                            In the terminal window [the one you type in ‘npm start’ to start the mirror]… go to the modules dir then the MMM-Instagram dir
                                            type in without quotes “npm install”
                                            Once that’s finished go back to the MagicMirror and start your mirror :)
                                            • 2 / 5
