    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 121.7k Views 27 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @kapsolas
      @kapsolas no didn’t modify. So what I’ll do is delete what’s there and recopy it since I already did the npm install.
      Thank you!! 😊
        [[global:former-user]] @kapsolas
        @kapsolas Where is this “added code” that needs to be removed, sorry missed that.
          Remove " + tempimage.photolink + “'>”" ?
          /* global Module */
          /* Magic Mirror
          • Module: MMM-Instagram
          • By Jim Kapsalis https://github.com/kapsolas
          • MIT Licensed.
          Module.register(‘MMM-Instagram’, {
          defaults: {
              format: 'json',
              lang: 'en-us',
              animationSpeed: 1000,
              updateInterval: 60000, // 10 minutes
              access_token: '',
              count: 200,
              min_timestamp: 0,
              loadingText: 'Loading...'
          // Define required scripts
          getScripts: function() {
              return ["moment.js"];
          // Define required translations
          getTranslations: function() {
              return false;
          // Define start sequence
          start: function() {
              Log.info('Starting module: ' + this.name);
              this.data.classes = 'bright medium';
              this.loaded = false;
              this.images = {};
              this.activeItem = 0;
              this.url = 'https://api.instagram.com/v1/users/self/media/recent' + this.getParams();
              this.grabPhotos();
          grabPhotos: function() {
              // the notifications are not working for some reason... so we won't do anything asynchronously
              // we will just make the call to the method to get the object with photo links....
              //Log.info('sending socket notification: INSTAGRAM_GET and URL: ' + this.url);
              this.sendSocketNotification("INSTAGRAM_GET", this.url);
              // this may not be needed... need to think about it.
              //setTimeout(this.grabPhotos, this.config.interval, this);
          getStyles: function() {
              return ['instagram.css', 'font-awesome.css'];
          // Override the dom generator
          getDom: function() {
              var imageDisplay = document.createElement('div'); //support for config.changeColor
              if (!this.loaded) {
                  wrapper.innerHTML = this.config.loadingText;
                  return wrapper;
              // set the first item in the list...
              if (this.activeItem >= this.images.photo.length) {
              var tempimage = this.images.photo[this.activeItem];
              // image
          	var imageLink = document.createElement('div');
          		imageLink.id = "MMM-Instagram-image";
          		imageLink.innerHTML = "<img src='" + tempimage.photolink + "'>";
          		imageDisplay.appendChild(imageLink);
          		wrapper.appendChild(imageDisplay);
              return wrapper;
          /* scheduleUpdateInterval()
           * Schedule visual update.
          scheduleUpdateInterval: function() {
              var self = this;
              Log.info("Scheduled update interval set up...");
              self.updateDom(self.config.animationSpeed);
              setInterval(function() {
                  Log.info("incrementing the activeItem and refreshing");
                  self.activeItem++;
              }, this.config.updateInterval);
           * getParams()
           * returns the query string required for the request to flickr to get the
           * photo stream of the user requested
          getParams: function() {
              var params = '?';
              params += 'count=' + this.config.count;
              params += '&min_timestamp=' + this.config.min_timestamp;
              params += '&access_token=' + this.config.access_token;
              return params;
          // override socketNotificationReceived
              //Log.info('socketNotificationReceived: ' + notification);
              if (notification === 'INSTAGRAM_IMAGE_LIST')
                  //Log.info('received INSTAGRAM_IMAGE_LIST');
                  this.images = payload;
                  //Log.info("count: " +  this.images.photo.length);
                  // we want to update the dom the first time and then schedule next updates
                  if (!this.loaded) {
                  this.updateDom(1000);
                      this.scheduleUpdateInterval();
                  this.loaded = true;
            • K Offline
              kapsolas Module Developer @Guest
              @wjdw87 Based on the code you have provided above, it looks correct. It does not have the tempimpage anywhere.
              I did not ask you to delete any code, but somehow the code you were running had tempimage misspelled to tempimpage.
              The messages you are showing in the screenshot, are from the core system, but does show that the instagram feed module is running. So there is something else.
              To confirm:
              1. You cloned the module from github
              2. You generated a token for instragram
              3. Configured the config.js file, configuration for the module appropriately
                I’m all good… I have NO idea where I got that version from but I copied over your original and it fired up…
                Thank you!
                I believe that version is yoless fork… someone wanted the ability to adjust width and height… which is not a bad idea … ;)
                • K Offline
                  Awesome! Glad to hear we got it all set up! Enjoy the module!
                    @kapsolas said in MMM-Instagram - Pull and animate photos from Instagram feed:
                    I really do! Thanks for all your hard work!
                      Hmm… from here : https://github.com/kapsolas/MMM-Instagram
                      Do you have to install : https://www.npmjs.com/package/request - How?
                      To confirm:
                      You cloned the module from github - YES
                      You generated a token for instragram - YES
                      Configured the config.js file, configuration for the module appropriately - YES
                      reply
                      strawberry 3.141S cowboysdudeC 2 Replies Last reply Reply Quote 0
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @Guest
                        @wjdw87
                        cd ~/MagicMirror/modules/MMM-Instagram
                        npm install
                          cowboysdude Module Developer @Guest
                          @wjdw87 said in MMM-Instagram - Pull and animate photos from Instagram feed:
                          To confirm:
                          reply
                          OH that’s the easy part ;)
                          In the terminal window [the one you type in ‘npm start’ to start the mirror]… go to the modules dir then the MMM-Instagram dir
                          type in without quotes “npm install”
                          Once that’s finished go back to the MagicMirror and start your mirror :)
                            Many Thanks @cowboysdude , @strawberry-3-141
                            I just did a fresh install oof the module, then the dependency.
                            Still no luck :( 0_1477600708301_Screenshot 2016-10-28 03.37.16.png
                              @wjdw87
                              Ok hang in there kid… just about there…
                                  I guess for security can change the API key once i’m all up and running :) - many thanks @cowboysdude !
                                  • K Offline
                                    Just an FYI - You do not want to just post your config to the world.
                                    That access token can allow someone to impersonate you now! The config.js contains confidential information for accessing the services our mirrors are using. Refrain from publishing it to the world with out redacting the app ids.
                                    ? 1 Reply Last reply Reply Quote 2
                                      Thanks, understood, i intend to replace API keys imemdiately on getting it up and running (at the moment just testing as building), hpe not to offend.
                                        That’s ok, that’s not a valid API key… That’s the problem.
                                        Let me explain… you do have an API key but what you need is an Access Token… that’s where the problem is.
                                        In the config it is asking for the Access token… that’s where we both made a mistake!!! :) It’s all good.
                                        We got it! :)
                                        Thanks @kapsolas
                                            @cowboysdude thanks a lot at 4am almost i can sleep ha ha for 2 hours :/
                                            Its working, note for others Access Token key is granted here… http://instagram.pixelunion.net/ (when you get to that stage and have created the developer account)0_1477601791572_Screenshot 2016-10-28 03.53.07.png . :
                                            layout needs tidying up mind but im sure there are some posts on that :)
                                            • 3 / 5
