    PIR-Sensor - put your mirror to sleep if not used
    utilitygpiomotion-sensorpower-saving
    56 Posts 32 Posters 121.3k Views 47 Watching
    • I
      IngmarSwart @DirkS
      Hi @DirkS,
      I use a standard first generation RPi camera board. In other words, this solution works perfectly fine with IR filter on the camera.
      The reason I think there might be issues with the RPi2: you should realize that this solution requires the RPi to analyze 10 images per second (give or take a few, you can specify the frame rate) using OpenCV routines. This causes a significant bump in processor load (approximately 33% on the RPi3 on top of everything else, if I’m not mistaken). I simply don’t know if the processor of the RPi2 is fast enough to do the image analysis, run the MM and the operating system simultaneously. The only way to know for sure is to test. I can’t help you with that as I don’t own a RPi2. Should the RPi2 struggle, perhaps you can get away with analyzing fewer frames (5 or maybe even 2). I encourage you to try and report back!
      Best wishes,
      Ingmar
        samydp
        my module is not working, I have the pir sensor connected to Pin 7 and when you start the screen stays white and nothing happens when I take the pir of the config it goes again.
        Z 1 Reply Last reply Reply Quote 0
        • Z
          zam @samydp
          @samydp Maybe you can find the answer here :After rebooting, run MM with pm2 and shows “White Screen”, I checked the pm2 error log shows something like “Expected 49, got 48” as before,
          Run “npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49” in the MMM-PIR-Sensor folder,
          Run “pm2 restart mm” and it works.”
            samydp
            it is not’ve tried as it stands anyway thanks for your help
              Defibrillat0r @IngmarSwart
              @IngmarSwart Thats a really nice solution. Did you use the virtual environment from the tutorials? If you did so, how did you wrap them together? Is it even possible? Thanks
                bibi
                Since IngmarSwart didn’t connect since few months, maybe someone can just explain me the reason why a PIR sensor is still needed in his config? i don’t get the role of the PIR since there is already a cam to detect the move…? if anyone… thx guys!
                • I
                  IngmarSwart
                  @Defibrillat0r: Thanks. Yes, I use the virtual environment. That being said, I don’t think it is stricktly necessary. In our configuration, the RPi is dedicated to running the MM, so the likelyhood that you need different versions of packages is very small. If you do use the virtual environment, you just have to make sure all the packages listed at the top of the python file are installed for the virtual environment you are working on. Other than that, no special tricks are needed.
                  @bibi: In my solution a PIR sensor is not needed. You only use @paviro’s module to interface the python code with the MM.
                    bibi @IngmarSwart
                    @IngmarSwart ohh ok now it’s clear! thx alot for your reply.
                    your hack is working perfectly so far?
                    • I
                      IngmarSwart
                      @bibi: I’ve only tested my solution for a couple of days, so I can’t say much about the long term stability. The reason for this is simply that I was in the process of designing a (nearly) frameless mirror the last couple of months. The components have been ordered and I hope to assemble everything in the coming month. It might take a bit longer, as I have quite a few business trips lined up for November.
                        bibi @IngmarSwart
                        @IngmarSwart I see i am still getting everything but in meantime i am working on the software side. You solution is nice and i will try to implement it i think… with my noob skills :)))
                          DirkS
                          i had big problems by switching off my screen with the PIR or another module with camera. The problem was not the module itself it is a firmware problem of the PI. I could see the same problem outside of MagicMirror as well by trying different things.
                          Reported also here:
                          https://github.com/raspberrypi/linux/issues/487
                          The symptom is that after a while of switching on and off the screen it remains off.
                          Dmesg reports the problem:
                          Nov  1 08:22:00 MagicMirror kernel: [86411.138649] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                          Nov  1 08:22:00 MagicMirror kernel: [86411.138665] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                          Nov  1 08:22:00 MagicMirror kernel: [86411.138670] detected fb_set_par error, error code: -22
                          Nov  1 08:22:00 MagicMirror kernel: [86411.139138] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                          Nov  1 08:22:00 MagicMirror kernel: [86411.139148] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                          Nov  1 08:22:00 MagicMirror kernel: [86411.139152] detected fb_set_par error, error code: -22
                          Nov  1 08:22:00 MagicMirror kernel: [86411.140642] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                          Nov  1 08:22:00 MagicMirror kernel: [86411.140654] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                          Nov  1 08:22:00 MagicMirror kernel: [86411.140659] detected fb_set_par error, error code: -22
                          Nov  1 08:22:00 MagicMirror kernel: [86411.140777] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                          Nov  1 08:22:00 MagicMirror kernel: [86411.140785] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                          Nov  1 08:22:00 MagicMirror kernel: [86411.140789] detected fb_set_par error, error code: -22
                          Nov  1 08:22:00 MagicMirror kernel: [86411.140856] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                          Nov  1 08:22:00 MagicMirror kernel: [86411.140863] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                          Nov  1 08:22:00 MagicMirror kernel: [86411.140868] bcm2708_fb_pan_display(0,0) returns=-22
                          Nov  1 08:22:00 MagicMirror systemd[1]: Started Getty on tty6.
                          Nov  1 08:22:00 MagicMirror kernel: [86411.256398] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                          Nov  1 08:22:00 MagicMirror kernel: [86411.256413] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                          Nov  1 08:22:00 MagicMirror kernel: [86411.256418] detected fb_set_par error, error code: -22
                          Nov  1 08:22:00 MagicMirror kernel: [86411.256758] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                          Nov  1 08:22:00 MagicMirror kernel: [86411.256770] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                          Nov  1 08:22:00 MagicMirror kernel: [86411.256775] bcm2708_fb_pan_display(0,0) returns=-22
                          Nov  1 08:22:00 MagicMirror kernel: [86411.296428] raspberrypi-firmware soc:firmware: Request 0x00040002 returned status 0x80000001
                          Nov  1 08:22:00 MagicMirror kernel: [86411.296455] bcm2708_fb soc:fb: bcm2708_fb_blank(0) failed: -22
                          Switching off the screen with
                          /opt/vc/bin/tvservice -o
                          and on with
                          /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chat 7
                          does not work reliable! The git issue tells you more about.
                          The workaround is a not yet described solution inside the config.txt
                          https://github.com/raspberrypi/documentation/pull/245/files
                          the option “hdmi_blanking=1” is your friend in this case! :D
                          Now i’m switching off the screen with
                          vcgencmd display_power 0
                          and on with
                          vcgencmd display_power 1
                          And it is working now like a charm! Did started to use it one day before this report and it is still working without any issue :)
                          Honestly speaking i don’t use any MM module for switching off anymore. But maybe my discovered solution will help any other and might be a way to change the module as well.
                          If you have trouble with on/off as well please check the output of dmesg. If you have the frambuffer problem you can fix it.
                          My personal solution is to have the PIR state at FHEM and from FHEM i’m using a script to switch the screen. But that’s a special case and for the most people here the usage of a MM Module will be the better way.
                          regards
                          Dirk
                          • N
                            nemesismega @paviro
                            @paviro said in PIR-Sensor - put your mirror to sleep if not used:
                            MMM-PIR-Sensor will monitor a connected PIR-sensor and putt your mirror to sleep if no one uses it either by disabling HDMI output or by turning of a relay.
                            Developer note
                            If you are a developer and want to pause your module while no one uses it (if it is processor intense), you can listen to the USER_PRESENCE broadcast. It will return true or false as its payload.
                            will vga / dvi monitor work with this module?
                            [card:paviro/MMM-PIR-Sensor]
                            • T
                              Them Russians
                              • F
                                fox
                                i have bought a sensor.
                                This is not a troubleshooting post. I want only know how to connect it.
                                Please add this to the description.
                                Three wires from the sensor and to which raspi port?
                                Issues With MMM-WatchDog known?
                                https://forum.magicmirror.builders/post/29827
                                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                • T
                                  Them Russians @fox
                                  @fox pop the plastic dome off and you’ll see the labeling. I believe the middle pin is the digital output and the ground and 5V power are on the outside.
                                  • F
                                    fox @Them Russians
                                    @Them-Russians said in PIR-Sensor - put your mirror to sleep if not used:
                                    The sensor is labeled. But on which pin on the raspi? Have i missed something in the module how-to?
                                    • T
                                      Them Russians @fox
                                      @fox You define the pin in the config.js file.
                                      Make sure you sue the GPIO pin number, and not the generic pin number.
                                      For instance, in the pin diagram the pin 1 down from the top left is GPIO pin 2, but regular pin 3. In the config file, you would define it a SensorPIN = 2.
                                      • F
                                        fox @Them Russians
                                        Thank you very much. I understood.
                                        Does someone control this with a timeout? Or when switches the script the HDMI Port off? Perhaps some want x minutes to be shown?
                                        Edit. I am a noob. I just have to adjust the delay knob on the PIR-Sensor PCB :)
                                        • K
                                          krauthamer
                                          Love this Module, thanks.
                                          I’m a noob and looking for some assistance to add a delay to turn off the display. Ideally the display would turn off 30 seconds after the last detected movement. Any help would be greatly appreciated.
                                          • A
                                            AAPS
                                            I originally wasn’t going to use this module, but it seems pretty cool, so I’ll try. I, however, have no clue how to physically connect the raspberry pi to the PIR sensor without a breadboard. I understand that I must specify the GPIO pins I connect to in the config file, but that will only help me if I figure out how to connect everything (soldering?). Could someone help me? I’m completely new to motion detection. :dizzy_face:
