    PIR-Sensor - put your mirror to sleep if not used
    utilitygpiomotion-sensorpower-saving
    56 Posts 32 Posters 121.6k Views 47 Watching
    • K
      KirAsh4 Moderator
      For troubleshooting or HOWTO questions, please post in the Troubleshooting thread:
      https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/1
        sameershah23
        I was wondering if there is a way to toggle the power to the TV via HDMI CEC commands (sent by pi) and integrating a PIR sensor?
        Example setup: The pi is always powered on. I walk into the room, the PIR senses me, and sends a power on signal to my TV via HDMI CEC command, and the mirror modules are displayed.
        After a set duration, if no activity sensed by PIR sensor, a power off CEC command is sent to the TV by PI.
        Has this been done before?
        Any guidance would be much appreciated.
        P T 2 Replies Last reply
        • K
          KirAsh4 Moderator
          Please do not cross-post the same question across multiple categories. Answers will get lost in the various posts.
            paviro @sameershah23
            @sameershah23 Should be possible. There already is a function that turns of the HDMI output of the Pi you would just need to replace that part (or add a new mode) that sends a command to the monitor. Feel free to send a pull request!
            – The Doctor
              sameershah23 @paviro
              @paviro I am fairly new to the programming world, but i was wondering what I need to add to the “//Detected Movement” & “//No movement” parts so that it sends the appropriate power toggle CEC signal to my TV?
              Do I need to install the CEC library? How do I initialize this CEC library in your node_helper.js file?
              After some googling, i found this library for CEC.
              https://github.com/Pulse-Eight/libcec/issues/84
              Will this library work for this application?
              Any help would be greatly appreciated. :)
              • K
                KirAsh4 Moderator
                Assuming your monitor/TV supports proper HDMI CEC commands, you need to first install the necessary binaries on your rpi and test that yourself - that’s outside of MM².
                Once you figured out that it works, then you need to write (or ask someone else to write) a module that interacts with the CEC binaries sending the proper commands. - that’s MM² related.
                • T
                  tyho @sameershah23
                  @sameershah23 maybe power off and on your hdmi signal and let your monitor/tv go to sleep mode when no signal.
                  The command will be:
                  OFF:
                  /opt/vc/bin/tvservice --off
                  ON:
                  /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
                  You can easily execute commands in node.js
                  • I
                    IngmarSwart
                    Using motion detection to switch your mirror on and off is very appealing. PIRs are a good option and Paviro’s module does a wonderful job. However, for an aesthetic point of view, I would like to mount the motion sensor behind the mirror, i.e. in such a way you can’t see the sensor. Since glass absorbs the light the PIR is sensitive to, PIRs (or at least the ones I tested, played with sensitivities as well) are not the best option. I played around a bit and found an alternative solution based on the Picamera, OpenCV and Paviro’s MMM-PIR module.
                    Downsides include having to run a python program next to the Magic Mirror. On a RPi3 it this is not a problem and is in my view therefore a rather minor drawback. If you run your MM on a RPi2, this may be an issue. Getting this to work also requires a non-trivial installation of OpenCV. However, thanks to the fantastic people over at PyImageSearch, detailed instructions are available. Upsides of this solution are: motion detection using a camera from behind the glass and the possibility to upload a photo taken by the camera each time it detects motion to your dropbox account.
                    Steps to follow:
                    • Disable the red LED on the Picamera by adding disable_camera_led = 1 to \boot\config.txt
                      (you don’t want to see red LED of the camera when looking at your mirror)
                    • Install a full version of OpenCV on the RPi. Detailed instructions can be found here
                    • Follow the two part tutorial on writing a python based code for motion detection: Part I and Part II
                    • Modify the python program found on the second page to generate a 3.3 V signal on a specified pin when the camera detects motion. This pin (pin 4 below) is then connected by a wire to the pin you specified in the MMM-PIR section of the MM config.js file. My modifications to the python code are:
                    On line 14 of the python code, add:
                    import RPi.GPIO as GPIO
                    GPIO.setmode(GPIO.BCM)
                    OPENCV_pin = 4 # specify whatever pin you want to generate the 3.3 V at when motion is detected.
                    GPIO.setup(OPENCV_pin, GPIO.OUT)
                    On line 26 add:
                    UnoccupiedCounter = 0
                    NumUnoccFramesSwitchOff = conf["fps"] * conf["time_to_switch_off"]
                    On line 108 insert:
                    if GPIO.input(OPENCV_pin) == 0 # check if openCV pin is high or low. If low, turn high
                             GPIO.output(OPENCV_pin,1)
                             print "Switched Mirror ON"
                    On line 137 insert:
                    UnoccupiedCounter =  UnoccupiedCounter + 1
                    if UnoccupiedCounter = numUnoccFramesSwitchOff and GPIO.input(OPENCV_pin)==1:
                             GPIO.output(OPENCV_pin, 0)
                             print "Switched Mirror OFF"
                    • Add "time_to_switch_off": 30 to the conf.json file. Don’t forget to add the comma behind the previous entry.
                    • Optional but recommended to get a clean exit:
                      Insert the whole for loop in a try statement.
                      Between line 53 and 54, add
                    try:
                    Don’t forget to indent all the code that comes next. Add the very bottom, add:
                    except KeyboardInterrupt:
                          print "Stopped camera surveillance" # exit the program when you press CNRL +C
                    except:
                          print "Other error or exception occurred!" # catch all other errors
                    finally:
                         GPIO.cleanup() # this ensures a clean exit.
                    I hope the above is of use to some of you.
                    D 1 Reply Last reply
                    Reply Quote 6
                      DirkS
                      HI @IngmarSwart,
                      great hack!! Did you use the original Camera behind the glass? Noir or without the IR Filter?
                      I’m using a PI2, can you specify why this should be an issue?
                      Best regards
                      Dirk
                      I 1 Reply Last reply
                      • I
                        IngmarSwart @DirkS
                        Hi @DirkS,
                        I use a standard first generation RPi camera board. In other words, this solution works perfectly fine with IR filter on the camera.
                        The reason I think there might be issues with the RPi2: you should realize that this solution requires the RPi to analyze 10 images per second (give or take a few, you can specify the frame rate) using OpenCV routines. This causes a significant bump in processor load (approximately 33% on the RPi3 on top of everything else, if I’m not mistaken). I simply don’t know if the processor of the RPi2 is fast enough to do the image analysis, run the MM and the operating system simultaneously. The only way to know for sure is to test. I can’t help you with that as I don’t own a RPi2. Should the RPi2 struggle, perhaps you can get away with analyzing fewer frames (5 or maybe even 2). I encourage you to try and report back!
                        Best wishes,
                        Ingmar
                          samydp
                          my module is not working, I have the pir sensor connected to Pin 7 and when you start the screen stays white and nothing happens when I take the pir of the config it goes again.
                          Z 1 Reply Last reply
                          • Z
                            zam @samydp
                            @samydp Maybe you can find the answer here :After rebooting, run MM with pm2 and shows “White Screen”, I checked the pm2 error log shows something like “Expected 49, got 48” as before,
                            Run “npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49” in the MMM-PIR-Sensor folder,
                            Run “pm2 restart mm” and it works.”
                              samydp
                              it is not’ve tried as it stands anyway thanks for your help
                                Defibrillat0r @IngmarSwart
                                @IngmarSwart Thats a really nice solution. Did you use the virtual environment from the tutorials? If you did so, how did you wrap them together? Is it even possible? Thanks
                                  bibi
                                  Since IngmarSwart didn’t connect since few months, maybe someone can just explain me the reason why a PIR sensor is still needed in his config? i don’t get the role of the PIR since there is already a cam to detect the move…? if anyone… thx guys!
                                  • I
                                    IngmarSwart
                                    @Defibrillat0r: Thanks. Yes, I use the virtual environment. That being said, I don’t think it is stricktly necessary. In our configuration, the RPi is dedicated to running the MM, so the likelyhood that you need different versions of packages is very small. If you do use the virtual environment, you just have to make sure all the packages listed at the top of the python file are installed for the virtual environment you are working on. Other than that, no special tricks are needed.
                                    @bibi: In my solution a PIR sensor is not needed. You only use @paviro’s module to interface the python code with the MM.
                                    B 1 Reply Last reply
                                      bibi @IngmarSwart
                                      @IngmarSwart ohh ok now it’s clear! thx alot for your reply.
                                      your hack is working perfectly so far?
                                      • I
                                        IngmarSwart
                                        @bibi: I’ve only tested my solution for a couple of days, so I can’t say much about the long term stability. The reason for this is simply that I was in the process of designing a (nearly) frameless mirror the last couple of months. The components have been ordered and I hope to assemble everything in the coming month. It might take a bit longer, as I have quite a few business trips lined up for November.
                                          bibi @IngmarSwart
                                          @IngmarSwart I see i am still getting everything but in meantime i am working on the software side. You solution is nice and i will try to implement it i think… with my noob skills :)))
                                            DirkS
                                            i had big problems by switching off my screen with the PIR or another module with camera. The problem was not the module itself it is a firmware problem of the PI. I could see the same problem outside of MagicMirror as well by trying different things.
                                            Reported also here:
                                            https://github.com/raspberrypi/linux/issues/487
                                            The symptom is that after a while of switching on and off the screen it remains off.
                                            Dmesg reports the problem:
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.138649] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.138665] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.138670] detected fb_set_par error, error code: -22
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.139138] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.139148] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.139152] detected fb_set_par error, error code: -22
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.140642] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.140654] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.140659] detected fb_set_par error, error code: -22
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.140777] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.140785] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.140789] detected fb_set_par error, error code: -22
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.140856] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.140863] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.140868] bcm2708_fb_pan_display(0,0) returns=-22
                                            Nov  1 08:22:00 MagicMirror systemd[1]: Started Getty on tty6.
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.256398] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.256413] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.256418] detected fb_set_par error, error code: -22
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.256758] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.256770] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.256775] bcm2708_fb_pan_display(0,0) returns=-22
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.296428] raspberrypi-firmware soc:firmware: Request 0x00040002 returned status 0x80000001
                                            Nov  1 08:22:00 MagicMirror kernel: [86411.296455] bcm2708_fb soc:fb: bcm2708_fb_blank(0) failed: -22
                                            Switching off the screen with
                                            /opt/vc/bin/tvservice -o
                                            and on with
                                            /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chat 7
                                            does not work reliable! The git issue tells you more about.
                                            The workaround is a not yet described solution inside the config.txt
                                            https://github.com/raspberrypi/documentation/pull/245/files
                                            the option “hdmi_blanking=1” is your friend in this case! :D
                                            Now i’m switching off the screen with
                                            vcgencmd display_power 0
                                            and on with
                                            vcgencmd display_power 1
                                            And it is working now like a charm! Did started to use it one day before this report and it is still working without any issue :)
                                            Honestly speaking i don’t use any MM module for switching off anymore. But maybe my discovered solution will help any other and might be a way to change the module as well.
                                            If you have trouble with on/off as well please check the output of dmesg. If you have the frambuffer problem you can fix it.
                                            My personal solution is to have the PIR state at FHEM and from FHEM i’m using a script to switch the screen. But that’s a special case and for the most people here the usage of a MM Module will be the better way.
                                            regards
                                            Dirk
                                            M 1 Reply Last reply
