    Time format help me please
    help me pleasetime format
    9 Posts 3 Posters 2.0k Views 3 Watching
      Manu85
      Re: MMM-SORT
      Hello Mikle1 and well done for what you do, I live in France and I write with a translator, I installed your MMM-SORT module which is really great and I would like to know if it was possible to have the time format in 24 hours because I am not familiar with the AM PM format, thank you for your help and congratulations again
        Mykle1 Project Sponsor Module Developer @Manu85
        @Manu85
        Je vous remercie pour vos aimables paroles. J’habite à NYC-USA et je vous réponds en utilisant un traducteur. Je pense que je peux le faire. Je vous répondrai dans un jour ou deux. Assez bien?
        Thank you for your kind words. I live in NYC-USA and I am answering you using a translator. I think I can do that. I will get back to you in a day or two. Good enough?
          @Manu85
          Is this what you had in mind?
          Run git pull in the MMM-SORT directory to get the updated files
          Add timeFormat: " HH:mm", to your config entry for MMM-SORT
            Manu85
            Hello Mikle1, you are really AWESOME, Thanks for your help, have a nice day
              Manu85
              hi Mikle1, do you think you can add the tidal coefficient? I think it would be a real advantage, I live on the west coast of France and here most of the inhabitants have boats, as it is the Atlantic Ocean to be able to go out at sea you have to know the coefficients, I think that if you do that you will have a lot of success with this module :-) while waiting bravo for everything
              cordially
                Manu85
                oh excuse me it’s not Mikle1 but Mykle1, sorry
                  sdetweil @Manu85
                  @Manu85 if you use the @ in front of the users name, the system will send them a notification
                    Manu85
                    @sdetweil Thank you very much for that info :thumbs_up:
                      @Manu85 said in Time format help me please:
                      The tidal coefficients are not present in the data from the api.
                      Sample:
                      Array(28)
                      date
                      "2020-04-03T14:52+0000"
                      dt
                      1585925563
                      height
                      -0.725
                      type
                      "Low"
                      __proto__
                      Object
                      date
                      "2020-04-03T20:42+0000"
                      dt
                      1585946563
                      height
                      0.575
                      type
                      "High"
                      __proto__
                      Object
                      date
                      "2020-04-04T03:07+0000"
                      dt
                      1585969622
                      height
                      -0.695
                      type
                      "Low"
                      __proto__
                      Object
                      date
                      "2020-04-04T09:06+0000"
                      dt
                      1585991195
                      height
                      0.813
                      type
                      "High"
                      __proto__
                      Object
                      date
                      "2020-04-04T15:45+0000"
                      dt
                      1586015158
                      height
                      -0.829
                      type
                      "Low"
                      __proto__
                      It took me a few minutes to recover from this. hahaha
                      Please mark the post that solved your first request as solved.
                      Also, this page has a tide coefficient table for the entire year of 2020
                      https://tides4fishing.com/tides/tidal-coefficient
