Solved MM on Ubuntu
Start by changing the language at the beginning of the config.
Mine:
language: "en",
Find a newsfeed that is relevant to you for the newsfeed module.
Use the search feature of the forum to see if your questions have already been answered
When you do ask a question, be as specific as you can.
@Mykle1 but files from snap store are all “only read”. How can I change that? I tried every methods and nothing
I’ve never heard of the “snap store”. I suspect you are using software other than MagicMirror
@Mykle1 seems its a new library (never heard of it before either)
https://snapcraft.io/store -
@Mykle1 how do I install without snap store? I tried to follow an old tutorial from you here in a old post but i had a lot of errors
@goncalovsc use the install script from here
https://github.com/sdetweil/MagicMirror_scripts -
@sdetweil thanks, it worked fine!
But, I edited the compliments and the config file and nothing changed, what should I do?
I already restarted the pc -
@goncalovsc said in MM on Ubuntu:
please show your changes… thx
(u should not edit the compliments.js file, right, only the config.js
@sdetweil https://gyazo.com/0d971f9417655c6753c26a538fa702ff
nothing changed -
@goncalovsc i am confused…
u said you edited the files, but nothing changed on restart…
so, I want to see what you edited in the files…
