    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 543.9k Views 29 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Egnos
      @Egnos
      Well, first a question. Does it work with the default config entry after you’ve done the temporary fix?
      E 1 Reply Last reply
      • E
        Egnos @Mykle1
        @Mykle1 said in MMM-Lunartic:
        @Egnos
        Yes, if you comment the line
        //	pages: {Prova: "top_left"},
        the module seems to work correctly.
        I did this test using a new “config.js”, without the other 21 modules.
        It is also possible that Lunartic conflicts with some other module.
        Here are the modules I installed:
        MMM-iFrame-Ping
        MMM-Page-Selector
        MM-orrery
        MMM-DarkSkyForecast
        MMM-ISS
        MMM-RTSPStream
        planetrise
        MMM-EARTH-Live
        MMM-ISS-Live
        MMM-Screencast
        MMM-Formula1
        MMM-Lunartic
        MMM-SoccerLiveScore
        MMM-Globe
        MMM-MyCommute
        mmm-suncalc
        MMM-GoogleMapsTraffic
        MMM-page-indicator
        MMM-Voice-Commands
        Thanks.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @Egnos said in MMM-Lunartic:
          Sure, it’s possible. Anything is possible. However, Lunartic works, without issue, with every other module (as far as I know). I don’t use MMM-Page-Selector. I use Hello-Lucy for my page selections and Lunartic lives happily there. No issues. No conflicts.
          With that said, I’ll see if I can discover anything.
          In the meantime, you can uncomment the pages: {Prova: "top_left"}, line and start you mirror with npm start dev. Report any errors from the dev console that appears.
          • E
            Egnos @Mykle1
            @Mykle1 Hello Lucy allows you to create pages like MMM-Page Selector?
            Is it possible to change the pages automatically after a set time?
            Many thanks @Mykle1.
            PS: I try your advice as soon as possible!👍
            • Mykle1M
              @Egnos
              I’m not familiar with MMM-PageSelector so I don’t know how things work within that module.
              Changing pages after a set time is not a feature that I have a use for. I can simply change a page with a voice command any time I want. Feel free to fork the module and make any changes your like. Send a PR if you like.
              I think there are already modules that might do that.
              • E
                Egnos
                HI @Mykle1
                I don’t know why but the module started working!
                I have some questions:
                • How should I modify the config.js to not display the image of the moon but only the text?
                • I am Italian, how can I translate the text?
                • If you want to use “Hello Lucy” to call up the page with my voice, could you recommend a good microphone?
                Thank you so much for your patience.:winking_face:
                • Mykle1M
                  Uhh, I don’t know why either.
                  Well, you can achieve that this way. Add this to you custom.css file:
                  .MMM-Lunartic img.photo {
                    display: none;
                  You can contribute to this module by replacing the Spanish in the following file with Italian. I will then add it to the module. By doing so, you make Italian available to everyone that uses this module.
                  "Distance from Earth's core = ": "Distancia desde la Tierra: ",
                  "Distance from sun = ": "Distancia desde el Sol: ",
                  "The next full moon is ": "Próxima Luna llena ",
                  "The next new moon is ": "Próxima Luna nueva: ",
                  "The current moon is ": "La fase actual lleva ",
                  "The moon is ": "Esta Luna está  ",
                  "% illuminated": "% iluminada",
                  " days old": " dias transcurridos",
                  "New Moon Phase": "Luna Nueva",
                  "Waxing Crescent Moon": "Luna Creciente",
                  "First Quarter Half Moon": "Primer cuarto de media luna",
                  "Waxing Gibbous Moon": "Luna creciente Gibosa",
                  "Full Moon": "Luna Llena",
                  "Waning Gibbous Moon": "Luna Gibosa menguante",
                  "Third Quarter Half Moon": "Tercer cuarto de Media Luna",
                  "Waning Crescent Moon": "Luna creciente menguante",
                  "When the Moon hits your eye . . .": "Cuando la Luna ilumina tus ojos . . ."
                  Are you using a Pi? I think the PSEye cam works well from what I’ve read here. I really don’t know. I don’t use Pi’s any longer.
                  • E
                    Egnos
                    For you:
                    "Distance from Earth's core = ": "Distanza dal nucleo della Terra",
                    "Distance from sun = ": "Distanza dal Sole",
                    "The next full moon is ": "La prossima Luna piena è",
                    "The next new moon is ": "La prossima Luna nuova è",
                    "The current moon is ": "La fase lunare corrente è",
                    "The moon is ": "La Luna è",
                    "% illuminated": "% illuminata",
                    " days old": "Giorni trascorsi",
                    "New Moon Phase": "Luna Nuova",
                    "Waxing Crescent Moon": "Luna Crescente",
                    "First Quarter Half Moon": "Primo Quarto di Luna",
                    "Waxing Gibbous Moon": "Luna Gibbosa Crescente",
                    "Full Moon": "Luna Piena",
                    "Waning Gibbous Moon": "Luna Gibbosa Calante",
                    "Third Quarter Half Moon": "Ultimo Quarto di Luna",
                    "Waning Crescent Moon": "Luna Calante",
                    "When the Moon hits your eye . . .": "Quando la Luna illumina i tuoi occhi..."
                    No, now for convenience I’m using a virtual machine with VirtualBox, could it work?
                    • Mykle1M
                      MMM-Lunartic now has Italian translation!
                      • Thanks to @Egnos
                      I have no way of testing that.
                      git pull in the MMM-Lunartic directory ot visit https://github.com/mykle1/MMM-Lunartic
                      • Mykle1M
                        Notice from the USNO api for MMM-Lunartic
                        “This US Naval Observatory Website is undergoing modernization and will be offline starting Thursday, 24 October 2019. The expected completion of work and return of service is estimated as 30 April 2020.”
                        So, hopefully, the module will be back to normal soon.
                        StoffbeuteluweS 2 Replies Last reply
                        • StoffbeuteluweS
                          Stoffbeuteluwe Project Sponsor @Mykle1
                          @Mykle1 Super… thanks Mykle
                          • StoffbeuteluweS
                            • Mykle1M
                              What a surprise! The USNO api has not resumed normal operations by the expected completion date. I’ll keep checking the site but it’s anyone’s guess now. :(
                              • Mykle1M
                                So, I went outside just as the sun was setting a little while ago and noticed the sky had cleared (it has been raining for days) and the moon was shining brightly. Ran inside, got my camera, click!
                                • Mykle1M
                                  From the USNO website.
                                  S StoffbeuteluweS 2 Replies Last reply
                                    sdetweil @Mykle1
                                    @Mykle1 can’t help myself.alt text
                                    • Mykle1M
                                      :thumbsup:
                                      • StoffbeuteluweS
                                        @Mykle1 Ohh no:disappointed_but_relieved_face:
                                        • Mykle1M
                                          I found this very interesting.
                                          “You’ve never seen the moon like in this ‘all terminator’ image (and you never will).”
                                          "Shadows creep down the banks of every crater on the near-side of the moon, highlighting the pockmarked face of Earth’s gravitationally-bound buddy with a clarity never before seen.
                                          According to photographer Andrew McCarthy, who posted the stunning image to his Instagram in April, there’s a simple explanation for the unprecedented level of detail in his work — this lunar view is actually “impossible.”
                                          “This moon might look a little funny to you, and that’s because it is an impossible scene,” McCarthy wrote on Instagram. “From two weeks of images of the waxing moon, I took the section of the picture that has the most contrast … aligned and blended them to show the rich texture across the entire surface.”
                                          The high-contrast section of the moon that McCarthy referred to is called the “lunar terminator” — the long line in the sand (or regolith, if you prefer) that divides the moon’s Earth-facing side between darkness and light. This terminator line moves around constantly depending on the phase of the moon, revealing or concealing new sections of the lunar surface each day. Because the terminator line heightens the contrast between the light and dark sides of the moon’s face, shadows look elongated and intensified in craters closest to the terminator.
                                          • Y
                                            yomm
                                            Thanks a lot for your work on this addon.
                                            I would like to hide the information about the distance to get just the image. I read carefully the README but I cannot find this configu trick.
                                            Could you please tell me how ?
                                            Here is my conf :
        disabled: false,
        module: 'MMM-Lunartic',
        position: 'top_center', // Best in left, center, or right regions
        classes: 'scheduler',
        module_schedule: {from: '0 21 * * *', to: '0 8 * * *' },
        mode: "rotating", // rotating or static
        image: "current", // animation, current, DayNight or static
        distance: "km", // miles or km
        sounds: "no", // howling wolf, only on a full moon
        useHeader: false, // true if you want a header
        /* header: "The Lunartic is in my head", // Any text you want*/
        maxWidth: "200px",
        animationSpeed: 10,
        rotateInterval: 15000,
                                            Thanks for advance.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
