    Finally, my first mirror is complete!
    10 Posts 6 Posters 6.8k Views 5 Watching
    • T Offline
      tbouron Module Developer @bhepler
      @bhepler Thanks! The slots fo the mirror give a neat finish but I’m sure there are easier technics to achieve this effect without the hassle (it wasn’t the easiest job to do the frame assembly)
      That being said, it was good woodworking practice :)
        seramik
        lovely one
        maybe juste try with a white cable for power
        • FoziF Offline
          Fozi Project Sponsor
          Very nice and clean design! I love that sort of simplicity. I went the same route regarding the frame, but had to use two ready-made RIBBA frames, as I have no facility to build it myself. A Glas mirror is definitely the next upgrade you should consider. It really makes a significant difference. Maybe you could also try to move the power plug inside the frame to hide the massive cable shaft, which goes into the mirror plug. Or cut and strip the cable plug and wire it directly inside the frame, with a white cord of course.
          • T Offline
            Thanks @seramik, @Fozi. I already planned to have a white cable, it just hasn’t arrived yet so I used a black one as a temporary measure.
            I’ll consider upgrade to glass but later, once I get bored of the current version.
              PaulB
              Dear @tbouron , what a great idea to include the airtraffic data.
              Please allow me one question: Did you use an antenna or how did you get the data? I tried to follow the github instructions but failing misearbly.
              Kind regards,
              Paul
                Mahieedaboss
                It looks so cool but could try adding more slides or something if you haven’t already
                • T Offline
                  tbouron Module Developer @PaulB
                  @PaulB I use the antenna that came with the USB dongle. Works like a charm
                  • T Offline
                    tbouron Module Developer @Mahieedaboss
                    @Mahieedaboss not sure what you mean by more slides?
