    Can't clone from GitHub
    107 Posts 3 Posters 74.8k Views 3 Watching
      MMRPi1 @sdetweil
      @sdetweil I’ll try
        MMRPi1 @sdetweil
        @sdetweil Alright so it says ‘the authenticity of localhost cannot be established’ but it lets me in
          sdetweil @MMRPi1
          @MMRPi1 ok, so ssh server is running… 1 thing we know
            and I assume you can ping the router
            route -n
            Kernel IP routing table
            Destination Gateway Genmask Flags Metric Ref Use Iface
            0.0.0.0 192.168.2.1 0.0.0.0 UG 100 0 0 enp5s0
            so in my case 192.168.2.1
              MMRPi1 @sdetweil
              @sdetweil yes I can ping the router
                sdetweil @MMRPi1
                @MMRPi1 I assume you can ping router from windows (
                ipconfig /all,
                 Default Gateway . . . . . . . . . : 192.168.2.1)
                but can’t ping the pi.
                is there a firewall on the pi? open a terminal window and do
                sudo iptables -L
                  MMRPi1 @sdetweil
                  @sdetweil Don’t think so, it says ‘policy accept’ on all three entrys
                    sdetweil @MMRPi1
                    @MMRPi1 weird… didn’t expect it… but u couldn’t access from ios…
                      MMRPi1 @sdetweil
                      @sdetweil I used to be able to about a week ago (both on the PC and iOS). It’s only very recently that it doesn’t let me in
                      • bheplerB Offline
                        bhepler Module Developer
                        Have you tried bouncing your router? If it thinks your devices are on different subnets it may be what’s keeping your network devices from connecting.
                          sdetweil @bhepler
                          @bhepler but their addresses are 192.168.0.x so shouldn’t be different subnets, but worth a try I suppose
                          • bheplerB Offline
                            bhepler Module Developer @sdetweil
                            @sdetweil - Yeah, shouldn’t. The router should manage it all through DHCP but something is really weird here. Especially if it all worked before and suddenly the routing stopped to the point where the two devices can’t even ping each other.
                            • bheplerB Offline
                              Hrm. Okay, basic connectivity check. From the pi, please try the following two commands and tell us the results of each:
                              ifconfig | grep inet
                              and
                              curl www.abc.com
                                MMRPi1 @bhepler
                                @bhepler Thanks so much. I feel rather silly knowing that a simple reboot would resolve the SSH issue. Unfortunately, I still can’t access git though.
                                  sdetweil @MMRPi1
                                  @MMRPi1 said in Can't clone from GitHub:
                                  one thing at a time!..
                                    MMRPi1 @sdetweil
                                    @sdetweil You’re right, the SSH is all sorted
                                      sdetweil @MMRPi1
                                      @MMRPi1 eh? ‘all sorted’ means working to me
                                        MMRPi1 @sdetweil
                                        @sdetweil Yes I can SSH into the pi fine now.
                                          sdetweil @MMRPi1
                                          @MMRPi1 ok, I missed that … what did u reboot? the pi, or the router?
                                          let remove git and reinstall it
                                          sudo apt-get remove git
                                          sudo apt-get install git
                                            MMRPi1 @sdetweil
                                            @sdetweil I rebooted the router.
                                            • 3 / 6
