    Can't clone from GitHub
    107 Posts 3 Posters 82.9k Views 3 Watching
      MMRPi1 @sdetweil
      @sdetweil I used to be able to about a week ago (both on the PC and iOS). It’s only very recently that it doesn’t let me in
        bhepler Module Developer
        Have you tried bouncing your router? If it thinks your devices are on different subnets it may be what’s keeping your network devices from connecting.
          sdetweil @bhepler
          @bhepler but their addresses are 192.168.0.x so shouldn’t be different subnets, but worth a try I suppose
            bhepler Module Developer @sdetweil
            @sdetweil - Yeah, shouldn’t. The router should manage it all through DHCP but something is really weird here. Especially if it all worked before and suddenly the routing stopped to the point where the two devices can’t even ping each other.
              Hrm. Okay, basic connectivity check. From the pi, please try the following two commands and tell us the results of each:
              ifconfig | grep inet
              and
              curl www.abc.com
                MMRPi1 @bhepler
                @bhepler Thanks so much. I feel rather silly knowing that a simple reboot would resolve the SSH issue. Unfortunately, I still can’t access git though.
                  sdetweil @MMRPi1
                  @MMRPi1 said in Can't clone from GitHub:
                  one thing at a time!..
                    MMRPi1 @sdetweil
                    @sdetweil You’re right, the SSH is all sorted
                      sdetweil @MMRPi1
                      @MMRPi1 eh? ‘all sorted’ means working to me
                        MMRPi1 @sdetweil
                        @sdetweil Yes I can SSH into the pi fine now.
                          sdetweil @MMRPi1
                          @MMRPi1 ok, I missed that … what did u reboot? the pi, or the router?
                          let remove git and reinstall it
                          sudo apt-get remove git
                          sudo apt-get install git
                            MMRPi1 @sdetweil
                            @sdetweil I rebooted the router.
                              MMRPi1 @sdetweil
                              @sdetweil I tried reinstalling git and I got the same error.
                                sdetweil @MMRPi1
                                @MMRPi1 just to recheck
                                git clone https://github.com/sdetweil/MagicMirror_scripts.git
                                fails with the same error…
                                do this
                                cat ~/.gitconfig
                                is there a
                                [http]
                                    proxy = http://mydomain\\myusername:mypassword@myproxyserver:8080
                                  MMRPi1 @sdetweil
                                  @sdetweil I got this instead: [http]
                                  sslVerify = false
                                    sdetweil @MMRPi1
                                    @MMRPi1
                                    https://stackoverflow.com/questions/51088635/git-clone-error-gnutls-handshake-failed-an-unexpected-tls-packet-was-receive
                                    ok, here is a solution I think… second response, recompile git with openssl
                                    link to script that does the work.
                                      MMRPi1 @sdetweil
                                      @sdetweil what do I put instead of <my_proxy>
                                        MMRPi1 @MMRPi1
                                        @MMRPi1 my_proxy
                                          I still want that connectivity check. The Pi can see the Windows box, but I want confirmation that the Pi can see the internet.
                                            MMRPi1 @bhepler
                                            @bhepler Oh yeah sorry, I did that and it worked fine, I got a bit of html
                                            • 3 / 6
