    Can't clone from GitHub
    107 Posts 3 Posters 88.5k Views 3 Watching
      and I assume you can ping the router
      route -n
      Kernel IP routing table
      Destination Gateway Genmask Flags Metric Ref Use Iface
      0.0.0.0 192.168.2.1 0.0.0.0 UG 100 0 0 enp5s0
      so in my case 192.168.2.1
      M 1 Reply Last reply
        MMRPi1 @sdetweil
        @sdetweil yes I can ping the router
          sdetweil @MMRPi1
          @MMRPi1 I assume you can ping router from windows (
          ipconfig /all,
           Default Gateway . . . . . . . . . : 192.168.2.1)
          but can’t ping the pi.
          is there a firewall on the pi? open a terminal window and do
          sudo iptables -L
            MMRPi1 @sdetweil
            @sdetweil Don’t think so, it says ‘policy accept’ on all three entrys
              sdetweil @MMRPi1
              @MMRPi1 weird… didn’t expect it… but u couldn’t access from ios…
                MMRPi1 @sdetweil
                @sdetweil I used to be able to about a week ago (both on the PC and iOS). It’s only very recently that it doesn’t let me in
                  bhepler Module Developer
                  Have you tried bouncing your router? If it thinks your devices are on different subnets it may be what’s keeping your network devices from connecting.
                  S M 2 Replies Last reply
                    sdetweil @bhepler
                    @bhepler but their addresses are 192.168.0.x so shouldn’t be different subnets, but worth a try I suppose
                    B 1 Reply Last reply
                      bhepler Module Developer @sdetweil
                      @sdetweil - Yeah, shouldn’t. The router should manage it all through DHCP but something is really weird here. Especially if it all worked before and suddenly the routing stopped to the point where the two devices can’t even ping each other.
                        Hrm. Okay, basic connectivity check. From the pi, please try the following two commands and tell us the results of each:
                        ifconfig | grep inet
                        and
                        curl www.abc.com
                          MMRPi1 @bhepler
                          @bhepler Thanks so much. I feel rather silly knowing that a simple reboot would resolve the SSH issue. Unfortunately, I still can’t access git though.
                            sdetweil @MMRPi1
                            @MMRPi1 said in Can't clone from GitHub:
                            one thing at a time!..
                              MMRPi1 @sdetweil
                              @sdetweil You’re right, the SSH is all sorted
                                sdetweil @MMRPi1
                                @MMRPi1 eh? ‘all sorted’ means working to me
                                  MMRPi1 @sdetweil
                                  @sdetweil Yes I can SSH into the pi fine now.
                                    sdetweil @MMRPi1
                                    @MMRPi1 ok, I missed that … what did u reboot? the pi, or the router?
                                    let remove git and reinstall it
                                    sudo apt-get remove git
                                    sudo apt-get install git
                                      MMRPi1 @sdetweil
                                      @sdetweil I rebooted the router.
                                        MMRPi1 @sdetweil
                                        @sdetweil I tried reinstalling git and I got the same error.
                                          sdetweil @MMRPi1
                                          @MMRPi1 just to recheck
                                          git clone https://github.com/sdetweil/MagicMirror_scripts.git
                                          fails with the same error…
                                          do this
                                          cat ~/.gitconfig
                                          is there a
                                          [http]
                                              proxy = http://mydomain\\myusername:mypassword@myproxyserver:8080
                                            MMRPi1 @sdetweil
                                            @sdetweil I got this instead: [http]
                                            sslVerify = false
                                            • 3 / 6
