    Can't clone from GitHub
    107 Posts 3 Posters 84.4k Views 3 Watching
      MMRPi1
      I’ve also tried from Terminus on iOS and that didn’t work either
        sdetweil @MMRPi1
        @MMRPi1 on the pi, if you have a keyboard can u ssh to itself?
        ssh pi@localhost
        works on mine
        still doesn’t fix the ping problem
          MMRPi1 @sdetweil
          @sdetweil I’ll try
            MMRPi1 @sdetweil
            @sdetweil Alright so it says ‘the authenticity of localhost cannot be established’ but it lets me in
              sdetweil @MMRPi1
              @MMRPi1 ok, so ssh server is running… 1 thing we know
                and I assume you can ping the router
                route -n
                Kernel IP routing table
                Destination Gateway Genmask Flags Metric Ref Use Iface
                0.0.0.0 192.168.2.1 0.0.0.0 UG 100 0 0 enp5s0
                so in my case 192.168.2.1
                  MMRPi1 @sdetweil
                  @sdetweil yes I can ping the router
                    sdetweil @MMRPi1
                    @MMRPi1 I assume you can ping router from windows (
                    ipconfig /all,
                     Default Gateway . . . . . . . . . : 192.168.2.1)
                    but can’t ping the pi.
                    is there a firewall on the pi? open a terminal window and do
                    sudo iptables -L
                      MMRPi1 @sdetweil
                      @sdetweil Don’t think so, it says ‘policy accept’ on all three entrys
                        sdetweil @MMRPi1
                        @MMRPi1 weird… didn’t expect it… but u couldn’t access from ios…
                          MMRPi1 @sdetweil
                          @sdetweil I used to be able to about a week ago (both on the PC and iOS). It’s only very recently that it doesn’t let me in
                            bhepler Module Developer
                            Have you tried bouncing your router? If it thinks your devices are on different subnets it may be what’s keeping your network devices from connecting.
                              sdetweil @bhepler
                              @bhepler but their addresses are 192.168.0.x so shouldn’t be different subnets, but worth a try I suppose
                                bhepler Module Developer @sdetweil
                                @sdetweil - Yeah, shouldn’t. The router should manage it all through DHCP but something is really weird here. Especially if it all worked before and suddenly the routing stopped to the point where the two devices can’t even ping each other.
                                  Hrm. Okay, basic connectivity check. From the pi, please try the following two commands and tell us the results of each:
                                  ifconfig | grep inet
                                  and
                                  curl www.abc.com
                                    MMRPi1 @bhepler
                                    @bhepler Thanks so much. I feel rather silly knowing that a simple reboot would resolve the SSH issue. Unfortunately, I still can’t access git though.
                                      sdetweil @MMRPi1
                                      @MMRPi1 said in Can't clone from GitHub:
                                      one thing at a time!..
                                        MMRPi1 @sdetweil
                                        @sdetweil You’re right, the SSH is all sorted
                                          sdetweil @MMRPi1
                                          @MMRPi1 eh? ‘all sorted’ means working to me
                                            MMRPi1 @sdetweil
                                            @sdetweil Yes I can SSH into the pi fine now.
                                            • 3 / 6
