    Can't clone from GitHub
    107 Posts 3 Posters 86.3k Views 3 Watching
      MMRPi1 @sdetweil
      @sdetweil Don’t think so, it says ‘policy accept’ on all three entrys
        sdetweil @MMRPi1
        @MMRPi1 weird… didn’t expect it… but u couldn’t access from ios…
          MMRPi1 @sdetweil
          @sdetweil I used to be able to about a week ago (both on the PC and iOS). It’s only very recently that it doesn’t let me in
            bhepler Module Developer
            Have you tried bouncing your router? If it thinks your devices are on different subnets it may be what’s keeping your network devices from connecting.
              sdetweil @bhepler
              @bhepler but their addresses are 192.168.0.x so shouldn’t be different subnets, but worth a try I suppose
                bhepler Module Developer @sdetweil
                @sdetweil - Yeah, shouldn’t. The router should manage it all through DHCP but something is really weird here. Especially if it all worked before and suddenly the routing stopped to the point where the two devices can’t even ping each other.
                  Hrm. Okay, basic connectivity check. From the pi, please try the following two commands and tell us the results of each:
                  ifconfig | grep inet
                  and
                  curl www.abc.com
                    MMRPi1 @bhepler
                    @bhepler Thanks so much. I feel rather silly knowing that a simple reboot would resolve the SSH issue. Unfortunately, I still can’t access git though.
                      sdetweil @MMRPi1
                      @MMRPi1 said in Can't clone from GitHub:
                      one thing at a time!..
                        MMRPi1 @sdetweil
                        @sdetweil You’re right, the SSH is all sorted
                          sdetweil @MMRPi1
                          @MMRPi1 eh? ‘all sorted’ means working to me
                            MMRPi1 @sdetweil
                            @sdetweil Yes I can SSH into the pi fine now.
                              sdetweil @MMRPi1
                              @MMRPi1 ok, I missed that … what did u reboot? the pi, or the router?
                              let remove git and reinstall it
                              sudo apt-get remove git
                              sudo apt-get install git
                                MMRPi1 @sdetweil
                                @sdetweil I rebooted the router.
                                  MMRPi1 @sdetweil
                                  @sdetweil I tried reinstalling git and I got the same error.
                                    sdetweil @MMRPi1
                                    @MMRPi1 just to recheck
                                    git clone https://github.com/sdetweil/MagicMirror_scripts.git
                                    fails with the same error…
                                    do this
                                    cat ~/.gitconfig
                                    is there a
                                    [http]
                                        proxy = http://mydomain\\myusername:mypassword@myproxyserver:8080
                                      MMRPi1 @sdetweil
                                      @sdetweil I got this instead: [http]
                                      sslVerify = false
                                        sdetweil @MMRPi1
                                        @MMRPi1
                                        https://stackoverflow.com/questions/51088635/git-clone-error-gnutls-handshake-failed-an-unexpected-tls-packet-was-receive
                                        ok, here is a solution I think… second response, recompile git with openssl
                                        link to script that does the work.
                                          MMRPi1 @sdetweil
                                          @sdetweil what do I put instead of <my_proxy>
                                            MMRPi1 @MMRPi1
                                            @MMRPi1 my_proxy
                                            • 3 / 6
