    Can't clone from GitHub
    107 Posts 3 Posters 88.5k Views 3 Watching
      sdetweil @MMRPi1
      @MMRPi1 ok, so ssh server is running… 1 thing we know
        and I assume you can ping the router
        route -n
        Kernel IP routing table
        Destination Gateway Genmask Flags Metric Ref Use Iface
        0.0.0.0 192.168.2.1 0.0.0.0 UG 100 0 0 enp5s0
        so in my case 192.168.2.1
        M 1 Reply Last reply
          MMRPi1 @sdetweil
          @sdetweil yes I can ping the router
            sdetweil @MMRPi1
            @MMRPi1 I assume you can ping router from windows (
            ipconfig /all,
             Default Gateway . . . . . . . . . : 192.168.2.1)
            but can’t ping the pi.
            is there a firewall on the pi? open a terminal window and do
            sudo iptables -L
              MMRPi1 @sdetweil
              @sdetweil Don’t think so, it says ‘policy accept’ on all three entrys
                sdetweil @MMRPi1
                @MMRPi1 weird… didn’t expect it… but u couldn’t access from ios…
                  MMRPi1 @sdetweil
                  @sdetweil I used to be able to about a week ago (both on the PC and iOS). It’s only very recently that it doesn’t let me in
                    bhepler Module Developer
                    Have you tried bouncing your router? If it thinks your devices are on different subnets it may be what’s keeping your network devices from connecting.
                    S M 2 Replies Last reply
                      sdetweil @bhepler
                      @bhepler but their addresses are 192.168.0.x so shouldn’t be different subnets, but worth a try I suppose
                      B 1 Reply Last reply
                        bhepler Module Developer @sdetweil
                        @sdetweil - Yeah, shouldn’t. The router should manage it all through DHCP but something is really weird here. Especially if it all worked before and suddenly the routing stopped to the point where the two devices can’t even ping each other.
                          Hrm. Okay, basic connectivity check. From the pi, please try the following two commands and tell us the results of each:
                          ifconfig | grep inet
                          and
                          curl www.abc.com
                            MMRPi1 @bhepler
                            @bhepler Thanks so much. I feel rather silly knowing that a simple reboot would resolve the SSH issue. Unfortunately, I still can’t access git though.
                              sdetweil @MMRPi1
                              @MMRPi1 said in Can't clone from GitHub:
                              one thing at a time!..
                                MMRPi1 @sdetweil
                                @sdetweil You’re right, the SSH is all sorted
                                  sdetweil @MMRPi1
                                  @MMRPi1 eh? ‘all sorted’ means working to me
                                    MMRPi1 @sdetweil
                                    @sdetweil Yes I can SSH into the pi fine now.
                                      sdetweil @MMRPi1
                                      @MMRPi1 ok, I missed that … what did u reboot? the pi, or the router?
                                      let remove git and reinstall it
                                      sudo apt-get remove git
                                      sudo apt-get install git
                                        MMRPi1 @sdetweil
                                        @sdetweil I rebooted the router.
                                          MMRPi1 @sdetweil
                                          @sdetweil I tried reinstalling git and I got the same error.
                                            sdetweil @MMRPi1
                                            @MMRPi1 just to recheck
                                            git clone https://github.com/sdetweil/MagicMirror_scripts.git
                                            fails with the same error…
                                            do this
                                            cat ~/.gitconfig
                                            is there a
                                            [http]
                                                proxy = http://mydomain\\myusername:mypassword@myproxyserver:8080
                                            • 3 / 6
