    Please help
    29 Posts 6 Posters 25.6k Views 5 Watching
    • L
      leisi @leisi
      @leisi said in Please help:
      Uahahha, i´ve the same or a similar problem:
      Hardware: Pi3 with following error, Please help me, whats the problem with my mirror?
      I can´t open the config/config.js file for editing and add. i get this error while npm start:
      (An answer in german would be nice, thanks)
      pi@magicmirror:~/MagicMirror $ git pull
      Already up-to-date.
      pi@magicmirror:~/MagicMirror $ git status
      Auf Branch master
      Ihr Branch ist auf dem selben Stand wie ‘origin/master’.
      nichts zu committen, Arbeitsverzeichnis unverändert
      pi@magicmirror:~/MagicMirror $ cp config/config.js.sample config/config.js
      pi@magicmirror:~/MagicMirror $ npm start
      magicmirror@2.0.0 start /home/pi/MagicMirror
      electron js/electron.js
      npm ERR! Linux 4.4.26-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
      npm ERR! node v6.9.1
      npm ERR! npm v3.10.8
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! electron js/electron.js
      npm ERR! npm bugs magicmirror
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      add. applies my display_rotate file is correct, without the “:”:
      “/boot/config.txt should only have =1 and not =:1 for the display_rotate command.”
        darrene
        have you tried a sudo apt-get update ?
        It might be worth giving that a try - afterwards, reboot then try re-running npm start again
        L 1 Reply Last reply
        • L
          leisi @darrene
          @darrene said in Please help:
          sudo apt-get update
          After the sudo apt-get update again i get following error again:
          (connection via SSH from Mac / my OS is Raspbian Jessie)
          pi@magicmirror:~ $ cd MagicMirror
          npm ERR!
          L K 2 Replies Last reply
          • L
            leisi @leisi
            sudo apt-get update
            npm ERR!
            reboot would naturally also done after the update…
            • K
              KirAsh4 Moderator @leisi
              sudo apt-get update
              I lost count on how many times this has come up already. You can not start the mirror using that command when you are remotely SSHd into the rpi. The rpi simply does not know what monitor to use, yours, or the one connected to it. You have to tell it that:
              DISPLAY=:0 npm start
              Use the correct command, and then figure out what the problems are.
              • L
                leisi @KirAsh4
                @KirAsh4 oh fucking, yes, you´re right, thanks very much for your help.
                • cowboysdudeC
                  cowboysdude Module Developer @leisi
                  While I find it humorous please be careful with replies… we don’t know how many youngsters we have roaming around here. Appreciate it! :)
                  • L
                    leisi @cowboysdude
                    @cowboysdude ok, pardon, my mistkake, i´ll do it next time, i´m so proud of my new magicmirror…
                    • cowboysdudeC
                      LOL I’m happy you are getting it working!! It’s a pretty awesome feeling, isn’t it? :)
                      Anytime you need help please feel free to ask and there are many people here that love to help!
                      No worries, no harm done, you made no mistake it happens and it’s okay!
                      Glad you’re here!
                        moris
                        With me still the same error synonymous with the command DISPLAY =: 0 npm start but the same error
                        • L
                          leisi @moris
                          @moris do you tried it from the terminal on raspberry or via Mac or Windows? Try this command only in raspberrys terminal…
                          M 1 Reply Last reply
                            moris @leisi
                            On the raspi terminal
                              moris
                              I log in cd MagicMirror
                              In cd MagicMirror write DISPLAY=:0 npm start is this korrekt?
                              • L
                                leisi @moris
                                @moris yes, my mirror starts with these commands on raspberrys terminal
                                  moris
                                  By me the same error list. Somewhere is an error or is not installed what can it be?
                                    moris
                                    So now I have pixel aufpspielen and behold there because it works. Now I have to install module sorry for the stupid question but how do I get it? On the readme page is the man config / config.js must open and should enter only where is the config.js? And how should I enter? Can you give me an example for clock?
                                    B 1 Reply Last reply
                                      bhepler Module Developer @moris
                                      @moris The basic installation of MagicMirror includes a sample config.js file. It’s located at ~/MagicMirror/config/config.sample.js
                                      If you copy or rename that file to config.js that should help get you started. cp ~/MagicMirror/config/config.sample/js ~/MagicMirror/config/config.js Once you have it copied, you can restart your mirror and it should use that simple config.js to run the mirror software.
                                      Installing other modules is pretty simple. Navigate to the modules directory: cd ~/MagicMirror/modules and then clone the module repository git clone [module url]. Follow the directions at the GitHub repository for that module in case there is anything special about installing that module.
                                      Reply Quote 2
