    Please help
    29 Posts 6 Posters 24.4k Views 5 Watching
    • K Offline
      KirAsh4 Moderator @leisi
      @leisi said in Please help:
      @darrene said in Please help:
      sudo apt-get update
      After the sudo apt-get update again i get following error again:
      (connection via SSH from Mac / my OS is Raspbian Jessie)
      pi@magicmirror:~ $ cd MagicMirror
      pi@magicmirror:~/MagicMirror $ npm start
      I lost count on how many times this has come up already. You can not start the mirror using that command when you are remotely SSHd into the rpi. The rpi simply does not know what monitor to use, yours, or the one connected to it. You have to tell it that:
      DISPLAY=:0 npm start
      Use the correct command, and then figure out what the problems are.
      • L Offline
        leisi @KirAsh4
        @KirAsh4 oh fucking, yes, you´re right, thanks very much for your help.
        • cowboysdudeC Offline
          cowboysdude Module Developer @leisi
          While I find it humorous please be careful with replies… we don’t know how many youngsters we have roaming around here. Appreciate it! :)
          • L Offline
            leisi @cowboysdude
            @cowboysdude ok, pardon, my mistkake, i´ll do it next time, i´m so proud of my new magicmirror…
              LOL I’m happy you are getting it working!! It’s a pretty awesome feeling, isn’t it? :)
              Anytime you need help please feel free to ask and there are many people here that love to help!
              No worries, no harm done, you made no mistake it happens and it’s okay!
              Glad you’re here!
                moris
                With me still the same error synonymous with the command DISPLAY =: 0 npm start but the same error
                • L Offline
                  leisi @moris
                  @moris do you tried it from the terminal on raspberry or via Mac or Windows? Try this command only in raspberrys terminal…
                    moris @leisi
                    On the raspi terminal
                      moris
                      I log in cd MagicMirror
                      In cd MagicMirror write DISPLAY=:0 npm start is this korrekt?
                      • L Offline
                        leisi @moris
                        @moris yes, my mirror starts with these commands on raspberrys terminal
                          moris
                          By me the same error list. Somewhere is an error or is not installed what can it be?
                            moris
                            So now I have pixel aufpspielen and behold there because it works. Now I have to install module sorry for the stupid question but how do I get it? On the readme page is the man config / config.js must open and should enter only where is the config.js? And how should I enter? Can you give me an example for clock?
                              bhepler Module Developer @moris
                              @moris The basic installation of MagicMirror includes a sample config.js file. It’s located at ~/MagicMirror/config/config.sample.js
                              If you copy or rename that file to config.js that should help get you started. cp ~/MagicMirror/config/config.sample/js ~/MagicMirror/config/config.js Once you have it copied, you can restart your mirror and it should use that simple config.js to run the mirror software.
                              Installing other modules is pretty simple. Navigate to the modules directory: cd ~/MagicMirror/modules and then clone the module repository git clone [module url]. Follow the directions at the GitHub repository for that module in case there is anything special about installing that module.
