    Hello-Lucy Module Microphone not working
    56 Posts 6 Posters 34.8k Views 7 Watching
    • L
      Linas123
      Thank you for all your help and your fast replays. Now it finally works with long charging times, but it works. Whenever I stop the Magic Mirror with pm2, the card for the microphone changes, but I can live with that because soon it will hang on the wall and then I won’t stop pm2.
        sdetweil @Linas123
        @Linas123 said in Hello-Lucy Module Microphone not working:
        do you mean response times? (time from speak to action)
        charging in english applies to batteries.
        what pi device are you using?
        L 1 Reply Last reply
        • L
          Linas123 @sdetweil
          Sorry, I’am only just 16 years old and not so good in english. I mean response time and use the RPI 3b+.
            sdetweil @Linas123
            a LOT better than my german!!
            wonder what else is running. 3b+ is usually pretty good
            do you use SSH to connect to pi?
            if so, can you do top command to see what is running?
            • L
              Linas123 @sdetweil
              I use realVNC to see what is on my Mirror.
                sdetweil @Linas123
                @Linas123 can u minimize mirror (alt-spacebar, n)
                and then run top in a terminal window (ctrl-alt-t)
                ctrl-c to exit top
                • L
                  Linas123
                  Maybe I just think that response time is slow, although it is fast for a cheap computer like the raspberry.
                  by top:
                  top - 15:54:46 up  1:12,  2 users,  load average: 0,08, 0,10, 0,09
                  Tasks: 145 total,   3 running, 142 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  2,5 us,  2,0 sy,  0,0 ni, 95,3 id,  0,0 wa,  0,0 hi,  0,2 si,  0,0 st
                  MiB Mem :    925,6 total,    165,2 free,    428,2 used,    332,2 buff/cache
                  MiB Swap:    100,0 total,     99,5 free,      0,5 used.    440,4 avail Mem
                    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                    439 root      20   0  158332  53688  36872 R   4,6   5,7   1:22.03 Xorg
                    412 root      20   0   49124  32660  17316 R   3,3   3,4   1:35.48 vncserver+
                   1196 pi        20   0   85152  27404  22580 S   3,3   2,9   0:03.96 x-termina+
                   1171 root      20   0       0      0      0 I   1,7   0,0   0:00.67 kworker/u+
                     69 root     -51   0       0      0      0 S   1,0   0,0   0:05.78 irq/86-mm+
                    459 root      20   0   19576  12284  11788 S   1,0   1,3   0:10.49 vncagent
                   1211 pi        20   0   10188   2840   2472 R   0,7   0,3   0:00.43 top
                    911 pi        20   0  544920 150124  81960 S   0,3  15,8   2:31.64 electron
                    951 pi        20   0  385260 116832  54260 S   0,3  12,3   1:23.20 electron
                   1127 root      20   0       0      0      0 I   0,3   0,0   0:00.11 kworker/3+
                   1176 root      20   0       0      0      0 I   0,3   0,0   0:00.44 kworker/0+
                      1 root      20   0   33732   7972   6412 S   0,0   0,8   0:03.68 systemd
                      2 root      20   0       0      0      0 S   0,0   0,0   0:00.01 kthreadd
                      3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                      4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                      8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu+
                      9 root      20   0       0      0      0 S   0,0   0,0   0:00.12 ksoftirqd+
                    sdetweil @Linas123
                    @Linas123 cool, thx… nothing running really…
                    i also didn’t like the realtime responsiveness of the pi (til pi4)
                    and bought odroid and jetson nano to get more speed.
                    • L
                      Linas123 @sdetweil
                      That’s a cool idea, but I don’t like to change anything on the hardware. I keep that in mind for my next project.
                        sdetweil @Linas123
                        @Linas123 yep, i do support most of the time, maintain the installer/updater scripts…
                        have a pi0, 3, 4, odroid, jetson nano I use the odroid in a production photoframe/info kiosk on the wall in my hall (no mirror glass or enclosure)
                        • L
                          Linas123 @sdetweil
                          I put a lot of effort into building the Magic Mirror (even a frameless Magic Mirror). Without self-praise I have seen many other Magic Mirrors but mine is by far the most beautiful one and finally a voice control is part of it. It is also completely designed for a Raspberry Pi, so I don’t want to change anything now.
                            sdetweil @Linas123
                            @Linas123 cool… glad you are happy with your project… it takes a lot of energy!..
                            • L
                              Linas123 @sdetweil
                              @sdetweil Yes, I’am a bit proud of me. It’s very cool that in this forum are so helpful and nice guys.
                              • V
                                varad wattamwar
                                Guys can you please help me out! @Mykle1 @Linas123 @sdetweil @TheGeekfather
                                My rpi model 3b+
                                I have installed Hello lucy correctly, executed npm install.
                                My mic card and device number is 1,0
                                My mic and speaker both are working fine, tested: arecord test.wav
                                Whenever I start my MM and speak hello lucy , lucy don’t detect my voice he don’t respond.
                                So I tried:
                                In asoundrc file I changed “hw:1,0” to “plughw:1,0”
                                But the result is same lucy is not responding.
                                Mykle1M 1 Reply Last reply
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @varad wattamwar
                                  @varad-wattamwar said in Hello-Lucy Module Microphone not working:
                                  Uhh, that is not how the dependencies are installed, according to the readme.
                                  Please keep your questions about this subject to 1 topic. This is the third topic your posting to for the same issue
                                    cq0q
                                    Guys can you please help me out with this @Mykle1 @Linas123 @sdetweil @TheGeekfather
                                    i’m new in all of this so please take it easy with me … so i installed MMM-hello lucy module but after i installed it and got the config right and i put my mic card and speaker device and all set … but after i launched magic mirror it shows up the microphone icon and says error … and it hangs like this like there is no solution … it’s like lucy is not detecting or something … and before i say anything the error just shows up …
                                    and if i installed MMM-voice and make it like MMM-hello lucy and MMM-voice together in the magic mirror, will it work ? and how will it be if i make both of them in my magic mirror?
                                    I’d be so glad if anyone could help me out with this …
                                      sdetweil @cq0q
                                      @cq0q Lucy is MMM-Voice plus some stuff… no, no can’t do both
                                      u need to walk thru the steps
                                      arecord -l (for list)
                                      will list the input devices
                                      aplay -l will list the output devices
                                      so, do
                                      arecord test.wav
                                      say something
                                      ctrl-x to end recording
                                      aplay test.wav
                                      did u hear what you said…
                                      provides the mic works…
                                      now, what device is it (from the arecord list)
                                      is that where Lucy is configured ?
                                      Voice/Lucy use the sphinx voice reco library, which is ok, but sensitive to the voice model.
                                      i stopped using it , cause it was accurate maybe 50% of the time… and I had to repeat myself a lot…
                                      C 1 Reply Last reply
                                        cq0q @sdetweil
                                        @sdetweil yes i did that and i heared myself and made the config but the error still shows …
                                        but what is sphinx voice reco library ? and how can i use it/install it ? and is it important for the module ?
                                        and why you had to repeat yourself alot ? is the problem from the module itself or ?
                                        • do i need sphinx to use MMM-voice module as well or it’s just for lucy module ?
                                          sdetweil @cq0q
                                          @cq0q the library is installed and used by mmm-voice and Lucy. u don’t have to do anything. that is the voice reco library they both use.
                                          why repeat, cause it doesn’t so very well in my opinion
                                            cq0q
                                            @sdetweil so what should i do to fix that problem ?1597832940471-capture.png
                                            • 3 / 3
