    Hello-Lucy Module Microphone not working
    56 Posts 6 Posters 29.2k Views 7 Watching
      sdetweil @Linas123
      @Linas123 yep, i do support most of the time, maintain the installer/updater scripts…
      have a pi0, 3, 4, odroid, jetson nano I use the odroid in a production photoframe/info kiosk on the wall in my hall (no mirror glass or enclosure)
      • L Offline
        Linas123 @sdetweil
        I put a lot of effort into building the Magic Mirror (even a frameless Magic Mirror). Without self-praise I have seen many other Magic Mirrors but mine is by far the most beautiful one and finally a voice control is part of it. It is also completely designed for a Raspberry Pi, so I don’t want to change anything now.
          sdetweil @Linas123
          @Linas123 cool… glad you are happy with your project… it takes a lot of energy!..
          • L Offline
            Linas123 @sdetweil
            @sdetweil Yes, I’am a bit proud of me. It’s very cool that in this forum are so helpful and nice guys.
            • V Offline
              varad wattamwar
              Guys can you please help me out! @Mykle1 @Linas123 @sdetweil @TheGeekfather
              My rpi model 3b+
              I have installed Hello lucy correctly, executed npm install.
              My mic card and device number is 1,0
              My mic and speaker both are working fine, tested: arecord test.wav
              Whenever I start my MM and speak hello lucy , lucy don’t detect my voice he don’t respond.
              So I tried:
              In asoundrc file I changed “hw:1,0” to “plughw:1,0”
              But the result is same lucy is not responding.
                Mykle1 Project Sponsor Module Developer @varad wattamwar
                @varad-wattamwar said in Hello-Lucy Module Microphone not working:
                Uhh, that is not how the dependencies are installed, according to the readme.
                Please keep your questions about this subject to 1 topic. This is the third topic your posting to for the same issue
                  cq0q
                  Guys can you please help me out with this @Mykle1 @Linas123 @sdetweil @TheGeekfather
                  i’m new in all of this so please take it easy with me … so i installed MMM-hello lucy module but after i installed it and got the config right and i put my mic card and speaker device and all set … but after i launched magic mirror it shows up the microphone icon and says error … and it hangs like this like there is no solution … it’s like lucy is not detecting or something … and before i say anything the error just shows up …
                  and if i installed MMM-voice and make it like MMM-hello lucy and MMM-voice together in the magic mirror, will it work ? and how will it be if i make both of them in my magic mirror?
                  I’d be so glad if anyone could help me out with this …
                    sdetweil @cq0q
                    @cq0q Lucy is MMM-Voice plus some stuff… no, no can’t do both
                    u need to walk thru the steps
                    arecord -l (for list)
                    will list the input devices
                    aplay -l will list the output devices
                    so, do
                    arecord test.wav
                    say something
                    ctrl-x to end recording
                    aplay test.wav
                    did u hear what you said…
                    provides the mic works…
                    now, what device is it (from the arecord list)
                    is that where Lucy is configured ?
                    Voice/Lucy use the sphinx voice reco library, which is ok, but sensitive to the voice model.
                    i stopped using it , cause it was accurate maybe 50% of the time… and I had to repeat myself a lot…
                      cq0q @sdetweil
                      @sdetweil yes i did that and i heared myself and made the config but the error still shows …
                      but what is sphinx voice reco library ? and how can i use it/install it ? and is it important for the module ?
                      and why you had to repeat yourself alot ? is the problem from the module itself or ?
                      • do i need sphinx to use MMM-voice module as well or it’s just for lucy module ?
                        sdetweil @cq0q
                        @cq0q the library is installed and used by mmm-voice and Lucy. u don’t have to do anything. that is the voice reco library they both use.
                        why repeat, cause it doesn’t so very well in my opinion
                          cq0q
                          @sdetweil so what should i do to fix that problem ?1597832940471-capture.png
                            sdetweil @cq0q
                            @cq0q I do not know. is the mic number in arecord -l the same in config.js for Lucy?
                              cq0q
                              @sdetweil yes it is
                                cq0q
                                well … it just fixed by itself … but as you said… i need to repeat myself and that’s bad actually …
                                what do you think of MMM-voice module ? is it better than this one ? or MMM-voice commands
                                S Mykle1M 2 Replies Last reply Reply Quote 0
                                  sdetweil @cq0q
                                  @cq0q mmm-voice has the same mic/library/reco problem
                                    Mykle1 Project Sponsor Module Developer @cq0q
                                    @cq0q said in Hello-Lucy Module Microphone not working:
                                    Magic!
                                    @sdetweil is correct. Hello-Lucy is a stripped down version of MMM-voice (removed most of its functionality) and added the ability to hide and show individual modules and pages of modules. Simplified the process of adding any module to this functionality. Modules can share regions. Etc,
                                    The recognition is average at best. Lucy (and voice) have trouble with certain accents, Norwegian in particular, (My friend can attest to that). Even I had some early trouble with non-recognition and/or false positives. I’ve learned ‘how’ to speak to Lucy after quite some time using her (3 years?). She also likes a completely quiet environment. With that said, she will never be as accurate, or work as well, as an Alexa or Google device.
                                    Lastly, I don’t use Lucy on a Pi. The pi’s inherent delay is too aggravating and frustrating. Now, using Lucy on more robust hardware is quite a different experience. Very satisfying, for me at least.
                                    • 3 / 3
